Flashing Tegra Fails: When I flash tegra A , failed,and the part of logs is following , How can I do ?
15:41:17 INFO : CUDA on Host : Err:3 file:/var/cuda-repo-9-2-local cuda-cuobjdump-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cuobjdump-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:4 file:/var/cuda-repo-9-2-local cuda-gdb-9-2 9.2.148-1 [2,764 kB]
15:41:17 INFO : CUDA on Host : Err:4 file:/var/cuda-repo-9-2-local cuda-gdb-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-gdb-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:5 file:/var/cuda-repo-9-2-local cuda-nvprof-9-2 9.2.148-1 [4,729 kB]
15:41:17 INFO : CUDA on Host : Err:5 file:/var/cuda-repo-9-2-local cuda-nvprof-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvprof-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:6 file:/var/cuda-repo-9-2-local cuda-memcheck-9-2 9.2.148-1 [137 kB]
15:41:17 INFO : CUDA on Host : Err:6 file:/var/cuda-repo-9-2-local cuda-memcheck-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-memcheck-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:7 file:/var/cuda-repo-9-2-local cuda-cudart-9-2 9.2.148-1 [97.6 kB]
15:41:17 INFO : CUDA on Host : Err:7 file:/var/cuda-repo-9-2-local cuda-cudart-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cudart-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:8 file:/var/cuda-repo-9-2-local cuda-driver-dev-9-2 9.2.148-1 [11.5 kB]
15:41:17 INFO : CUDA on Host : Err:8 file:/var/cuda-repo-9-2-local cuda-driver-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-driver-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:9 file:/var/cuda-repo-9-2-local cuda-cudart-dev-9-2 9.2.148-1 [719 kB]
15:41:17 INFO : CUDA on Host : Err:9 file:/var/cuda-repo-9-2-local cuda-cudart-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cudart-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:10 file:/var/cuda-repo-9-2-local cuda-misc-headers-9-2 9.2.148-1 [643 kB]
15:41:17 INFO : CUDA on Host : Err:10 file:/var/cuda-repo-9-2-local cuda-misc-headers-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-misc-headers-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:11 file:/var/cuda-repo-9-2-local cuda-nvcc-9-2 9.2.148-1 [15.6 MB]
15:41:17 INFO : CUDA on Host : Err:11 file:/var/cuda-repo-9-2-local cuda-nvcc-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvcc-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:12 file:/var/cuda-repo-9-2-local cuda-cupti-9-2 9.2.148-1 [1,537 kB]
15:41:17 INFO : CUDA on Host : Err:12 file:/var/cuda-repo-9-2-local cuda-cupti-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cupti-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:13 file:/var/cuda-repo-9-2-local cuda-gpu-library-advisor-9-2 9.2.148-1 [1,002 kB]
15:41:17 INFO : CUDA on Host : Err:13 file:/var/cuda-repo-9-2-local cuda-gpu-library-advisor-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-gpu-library-advisor-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:14 file:/var/cuda-repo-9-2-local cuda-nvtx-9-2 9.2.148-1 [24.3 kB]
15:41:17 INFO : CUDA on Host : Err:14 file:/var/cuda-repo-9-2-local cuda-nvtx-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvtx-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:15 file:/var/cuda-repo-9-2-local cuda-command-line-tools-9-2 9.2.148-1 [26.2 kB]
15:41:17 INFO : CUDA on Host : Err:15 file:/var/cuda-repo-9-2-local cuda-command-line-tools-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-command-line-tools-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:16 file:/var/cuda-repo-9-2-local cuda-nvprune-9-2 9.2.148-1 [36.8 kB]
15:41:17 INFO : CUDA on Host : Err:16 file:/var/cuda-repo-9-2-local cuda-nvprune-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvprune-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:17 file:/var/cuda-repo-9-2-local cuda-compiler-9-2 9.2.148-1 [2,520 B]
15:41:17 INFO : CUDA on Host : Err:17 file:/var/cuda-repo-9-2-local cuda-compiler-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-compiler-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:18 file:/var/cuda-repo-9-2-local cuda-cublas-9-2 9.2.148-1 [24.8 MB]
15:41:17 INFO : CUDA on Host : Err:18 file:/var/cuda-repo-9-2-local cuda-cublas-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cublas-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:19 file:/var/cuda-repo-9-2-local cuda-cublas-dev-9-2 9.2.148-1 [48.9 MB]
15:41:17 INFO : CUDA on Host : Err:19 file:/var/cuda-repo-9-2-local cuda-cublas-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cublas-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:20 file:/var/cuda-repo-9-2-local cuda-cufft-9-2 9.2.148-1 [51.6 MB]
15:41:17 INFO : CUDA on Host : Err:20 file:/var/cuda-repo-9-2-local cuda-cufft-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cufft-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:21 file:/var/cuda-repo-9-2-local cuda-cufft-dev-9-2 9.2.148-1 [106 MB]
15:41:17 INFO : CUDA on Host : Err:21 file:/var/cuda-repo-9-2-local cuda-cufft-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cufft-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:22 file:/var/cuda-repo-9-2-local cuda-curand-9-2 9.2.148-1 [38.8 MB]
15:41:17 INFO : CUDA on Host : Err:22 file:/var/cuda-repo-9-2-local cuda-curand-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-curand-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:23 file:/var/cuda-repo-9-2-local cuda-curand-dev-9-2 9.2.148-1 [57.8 MB]
15:41:17 INFO : CUDA on Host : Err:23 file:/var/cuda-repo-9-2-local cuda-curand-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-curand-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:24 file:/var/cuda-repo-9-2-local cuda-cusolver-9-2 9.2.148-1 [31.0 MB]
15:41:17 INFO : CUDA on Host : Err:24 file:/var/cuda-repo-9-2-local cuda-cusolver-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cusolver-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:25 file:/var/cuda-repo-9-2-local cuda-cusolver-dev-9-2 9.2.148-1 [8,184 kB]
15:41:17 INFO : CUDA on Host : Err:25 file:/var/cuda-repo-9-2-local cuda-cusolver-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cusolver-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:26 file:/var/cuda-repo-9-2-local cuda-cusparse-9-2 9.2.148-1 [27.7 MB]
15:41:17 INFO : CUDA on Host : Err:26 file:/var/cuda-repo-9-2-local cuda-cusparse-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cusparse-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:27 file:/var/cuda-repo-9-2-local cuda-cusparse-dev-9-2 9.2.148-1 [27.8 MB]
15:41:17 INFO : CUDA on Host : Err:27 file:/var/cuda-repo-9-2-local cuda-cusparse-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-cusparse-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:28 file:/var/cuda-repo-9-2-local cuda-nvrtc-9-2 9.2.148-1 [5,910 kB]
15:41:17 INFO : CUDA on Host : Err:28 file:/var/cuda-repo-9-2-local cuda-nvrtc-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvrtc-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:29 file:/var/cuda-repo-9-2-local cuda-nvrtc-dev-9-2 9.2.148-1 [9,348 B]
15:41:17 INFO : CUDA on Host : Err:29 file:/var/cuda-repo-9-2-local cuda-nvrtc-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvrtc-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:30 file:/var/cuda-repo-9-2-local cuda-npp-9-2 9.2.148-1 [52.0 MB]
15:41:17 INFO : CUDA on Host : Err:30 file:/var/cuda-repo-9-2-local cuda-npp-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-npp-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:31 file:/var/cuda-repo-9-2-local cuda-npp-dev-9-2 9.2.148-1 [52.0 MB]
15:41:17 INFO : CUDA on Host : Err:31 file:/var/cuda-repo-9-2-local cuda-npp-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-npp-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:32 file:/var/cuda-repo-9-2-local cuda-nvgraph-9-2 9.2.148-1 [11.7 MB]
15:41:17 INFO : CUDA on Host : Err:32 file:/var/cuda-repo-9-2-local cuda-nvgraph-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvgraph-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:33 file:/var/cuda-repo-9-2-local cuda-nvgraph-dev-9-2 9.2.148-1 [30.1 MB]
15:41:17 INFO : CUDA on Host : Err:33 file:/var/cuda-repo-9-2-local cuda-nvgraph-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvgraph-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:34 file:/var/cuda-repo-9-2-local cuda-samples-9-2 9.2.148-1 [75.8 MB]
15:41:17 INFO : CUDA on Host : Err:34 file:/var/cuda-repo-9-2-local cuda-samples-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-samples-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:35 file:/var/cuda-repo-9-2-local cuda-documentation-9-2 9.2.148-1 [50.7 MB]
15:41:17 INFO : CUDA on Host : Err:35 file:/var/cuda-repo-9-2-local cuda-documentation-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-documentation-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:36 file:/var/cuda-repo-9-2-local cuda-libraries-dev-9-2 9.2.148-1 [2,598 B]
15:41:17 INFO : CUDA on Host : Err:36 file:/var/cuda-repo-9-2-local cuda-libraries-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-libraries-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:37 file:/var/cuda-repo-9-2-local cuda-nsight-9-2 9.2.148-1 [2,582 B]
15:41:17 INFO : CUDA on Host : Err:37 file:/var/cuda-repo-9-2-local cuda-nsight-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nsight-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:38 file:/var/cuda-repo-9-2-local cuda-nvml-dev-9-2 9.2.148-1 [49.7 kB]
15:41:17 INFO : CUDA on Host : Err:38 file:/var/cuda-repo-9-2-local cuda-nvml-dev-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvml-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:39 file:/var/cuda-repo-9-2-local cuda-nvvp-9-2 9.2.148-1 [2,528 B]
15:41:17 INFO : CUDA on Host : Err:39 file:/var/cuda-repo-9-2-local cuda-nvvp-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-nvvp-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:40 file:/var/cuda-repo-9-2-local cuda-visual-tools-9-2 9.2.148-1 [396 MB]
15:41:17 INFO : CUDA on Host : Err:40 file:/var/cuda-repo-9-2-local cuda-visual-tools-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-visual-tools-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:41 file:/var/cuda-repo-9-2-local cuda-tools-9-2 9.2.148-1 [2,486 B]
15:41:17 INFO : CUDA on Host : Err:41 file:/var/cuda-repo-9-2-local cuda-tools-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-tools-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : Get:42 file:/var/cuda-repo-9-2-local cuda-toolkit-9-2 9.2.148-1 [2,824 B]
15:41:17 INFO : CUDA on Host : Err:42 file:/var/cuda-repo-9-2-local cuda-toolkit-9-2 9.2.148-1
15:41:17 INFO : CUDA on Host : File not found - /var/cuda-repo-9-2-local/./cuda-toolkit-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-license-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-license-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvdisasm-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvdisasm-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cuobjdump-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cuobjdump-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-gdb-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-gdb-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvprof-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvprof-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-memcheck-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-memcheck-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cudart-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cudart-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-driver-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-driver-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cudart-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cudart-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-misc-headers-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-misc-headers-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvcc-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvcc-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cupti-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cupti-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-gpu-library-advisor-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-gpu-library-advisor-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvtx-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvtx-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-command-line-tools-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-command-line-tools-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvprune-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvprune-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-compiler-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-compiler-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cublas-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cublas-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cublas-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cublas-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cufft-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cufft-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cufft-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cufft-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-curand-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-curand-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-curand-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-curand-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cusolver-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cusolver-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cusolver-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cusolver-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cusparse-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cusparse-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-cusparse-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-cusparse-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvrtc-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvrtc-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvrtc-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvrtc-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-npp-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-npp-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-npp-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-npp-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvgraph-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvgraph-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvgraph-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvgraph-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-samples-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-samples-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-documentation-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-documentation-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-libraries-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-libraries-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nsight-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nsight-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvml-dev-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvml-dev-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-nvvp-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-nvvp-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-visual-tools-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-visual-tools-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-tools-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-tools-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Failed to fetch file:/var/cuda-repo-9-2-local/./cuda-toolkit-9-2_9.2.148-1_amd64.deb File not found - /var/cuda-repo-9-2-local/./cuda-toolkit-9-2_9.2.148-1_amd64.deb (2: No such file or directory)
15:41:17 INFO : CUDA on Host : E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
15:41:17 INFO : CUDA on Host : exit status 1
15:41:17 INFO : CUDA on Host : [ Install Finished with Error ]
15:41:17 ERROR : CUDA on Host : NV_CUDA_HOST_COMP apt install failed
15:41:17 INFO : CUDA on Host : [ 4.88 MB used. Disk Avail: 88.41 GB ]
15:41:17 INFO : CUDA on Host : [ NV_CUDA_HOST_COMP install took 1m19s ]
15:41:17 INFO : CUDA on Host : apt install failed
15:41:17 ERROR : CUDA on Host : command terminated with error
15:41:17 ERROR : CUDA on Host : install ‘CUDA on Host’ failure, command < cd ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘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’ -i=‘NV_CUDA_HOST_COMP’ -v=‘9.2’ -l=’/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=’/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘4645’ -u=’/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=’/media/admin123/_D/px2/cuda-repo-ubuntu1604-9-2-local_9.2.88-1_amd64.deb’ > terminated with error
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : Start to install ‘TensorRT (with cuDNN 7.1) on Target’
15:41:17 DEBUG : TensorRT (with cuDNN 7.1) on Target : running command < cd ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘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’ -i=‘NV_TENSORRT_TARGET_COMP’ -v=‘4.0’ -l=’/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=’/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘4645’ -u=’/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=’/media/admin123/_D/px2/drive-t186ref-linux-5.0.10.3-12606092-aarch64-tensorrt-4.0.0.8-1+cuda9.2.run’ >
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : [ Disk Avail:88.41 GB]
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : Using GenericInstaller to install NV_TENSORRT_TARGET_COMP
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : [ Install Started ]
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : runfile installer start to install NV_TENSORRT_TARGET_COMP
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : change working directory to /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : .install/ folder from previously installed component exists and is being removed
15:41:17 INFO : TensorRT (with cuDNN 7.1) on Target : exec_command: /media/admin123/_D/px2/drive-t186ref-linux-5.0.10.3-12606092-aarch64-tensorrt-4.0.0.8-1+cuda9.2.run --noexec
15:41:21 INFO : TensorRT (with cuDNN 7.1) on Target : Verifying archive integrity… All good.
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : Uncompressing drive-t186ref-linux-5.0.10.3-12606092-aarch64-tensorrt…
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : [ Install Finished Successfully ]
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : [ PostInstall Started ]
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : current working directory is /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : root 8805 0.0 0.0 199604 3164 ? Ssl 15:31 0:00 /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/sudo_daemon -installer=4645 -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : exec_command: /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/run_command -c="cd /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK && .install/drive-t186ref-linux--aarch64-tensorrt/gie_startup" -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp -l=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS/NV_TENSORRT_TARGET_COMP.log
15:41:25 INFO : TensorRT (with cuDNN 7.1) on Target : Installing GIE debs …
15:41:26 INFO : TensorRT (with cuDNN 7.1) on Target : Done.
15:41:26 INFO : TensorRT (with cuDNN 7.1) on Target : [ PostInstall Finished Successfully ]
15:41:26 INFO : TensorRT (with cuDNN 7.1) on Target : [ 795.88 MB used. Disk Avail: 87.63 GB ]
15:41:26 INFO : TensorRT (with cuDNN 7.1) on Target : [ NV_TENSORRT_TARGET_COMP install took 8s ]
15:41:26 INFO : TensorRT (with cuDNN 7.1) on Target : command finished successfully
15:41:26 INFO : TensorRT (with cuDNN 7.1) on Target : install ‘TensorRT (with cuDNN 7.1) on Target’ success
15:41:26 INFO : DPX Patch : Start to install ‘DPX Patch’
15:41:26 DEBUG : DPX Patch : running command < cd ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘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’ -i=‘NV_DPX_PATCH_COMP’ -v=‘5.0.10.3’ -l=’/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=’/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘4645’ -u=’/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=’/media/admin123/_D/px2/drive-t186ref-linux-5.0.10.3-12606092-dpx-patch-v0.0.0-sdk.run’ >
15:41:26 INFO : DPX Patch : [ Disk Avail:87.63 GB]
15:41:26 INFO : DPX Patch : Using GenericInstaller to install NV_DPX_PATCH_COMP
15:41:26 INFO : DPX Patch : Skip to install drive-t186ref-linux-5.0.10.3-12606092-dpx-patch-v0.0.0-sdk.run of component NV_DPX_PATCH_COMP
15:41:26 INFO : DPX Patch : [ 4.00 KB used. Disk Avail: 87.63 GB ]
15:41:26 INFO : DPX Patch : [ NV_DPX_PATCH_COMP install took 0s ]
15:41:26 INFO : DPX Patch : command finished successfully
15:41:26 INFO : DPX Patch : install ‘DPX Patch’ success
15:41:26 INFO : DriveWorks on Target : Start to install ‘DriveWorks on Target’
15:41:26 DEBUG : DriveWorks on Target : running command < cd ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘eyJpZCI6Ik5WX0RSSVZFV09SS1NfVEFSR0VUX0NPTVAiLCJuYW1lIjoiRHJpdmVXb3JrcyBvbiBUYXJnZXQiLCJkZXNjcmlwdGlvbiI6Ik5WSURJQSBEcml2ZVdvcmtzIHNvZnR3YXJlIGRldmVsb3BtZW50IGtpdCAoU0RLKSBnaXZlcyBkZXZlbG9wZXJzIGEgZm91bmRhdGlvbiB1cG9uIHdoaWNoIHRvIGJ1aWxkIGFwcGxpY2F0aW9ucywgbGV2ZXJhZ2luZyB0aGUgY29tcHV0YXRpb25hbGx5IGludGVuc2l2ZSBhbGdvcml0aG1zIGZvciBvYmplY3QgZGV0ZWN0aW9uLCBtYXAgbG9jYWxpemF0aW9uLCBhbmQgcGF0aCBwbGFubmluZy4iLCJpc1Zpc2libGUiOnRydWUsImxpY2Vuc2VJZCI6Ik5WX0RSSVZFX1NMQV9PQ1QyMDE3IiwiaXNEZXRlY3RhYmxlSW5zdGFsbCI6ZmFsc2UsImlzSW5zdGFsbFBhdGhDdXN0b21pemFibGUiOnRydWUsInZlcnNpb24iOiIxLjIiLCJvcGVyYXRpbmdTeXN0ZW1zIjpbInVidW50dTE0MDQiLCJ1YnVudHUxNjA0Il0sImluc3RhbGxTaXplTUIiOjE5NjEsImRvd25sb2FkRmlsZXMiOlt7InVybCI6ImRyaXZlLXQxODZyZWYtbGludXgtNS4wLjEwLjMtMTI2MDYwOTItYWFyY2g2NC1kcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LnJ1biIsImZpbGVOYW1lIjoiZHJpdmUtdDE4NnJlZi1saW51eC01LjAuMTAuMy0xMjYwNjA5Mi1hYXJjaDY0LWRyaXZld29ya3MtdjEuMi40MDAtYTdmNTQ3NS00Nzg5NTUucnVuIiwic2l6ZSI6NTAzMjAxNjAwMCwiY2hlY2tzdW0iOiJmOWVhZjA5OWZjYTdiMDE1MmQwMTMwMTcwZDg1NTE5ZiIsImNoZWNrc3VtVHlwZSI6Im1kNSIsImluc3RhbGxQYXJhbWV0ZXJzIjp7Imluc3RhbGxUeXBlIjoicnVuIiwiYWRkaXRpb25hbFBhcmFtZXRlcnMiOnsiaW5zdGFsbERpciI6IkRyaXZlU0RLIiwiaW5zdGFsbENvbW1hbmRBcmd1bWVudHMiOiItLW5vZXhlYyIsInBvc3RJbnN0YWxsQ29tbWFuZHMiOlt7ImFkbWluQ29tbWFuZCI6Ii5pbnN0YWxsL2R3eC1nZW5lcmFsX3N0YXJ0dXAifV19fSwiY2FjaGVkVXJsIjoiaHR0cHM6Ly9kZXZlbG9wZXIubnZpZGlhLmNvbS9kcml2ZS9zZWN1cmUvZHJpdmVfYnVuZGxlcy9Ecml2ZV81MDEwM0xfU0RLX2IxMzVfT1NfR0EvZHJpdmUtdDE4NnJlZi1saW51eC01LjAuMTAuMy0xMjYwNjA5Mi1hYXJjaDY0LWRyaXZld29ya3MtdjEuMi40MDAtYTdmNTQ3NS00Nzg5NTUucnVuIn1dLCJ0YXJnZXRJZHMiOlsiUFgyX0FVVE9DUlVJU0UiLCJQWDJfQVVUT0NIQVVGRkVVUiJdLCJkZXBlbmRlbmNpZXMiOlt7ImlkIjoiTlZfVEVOU09SUlRfVEFSR0VUX0NPTVAiLCJvcGVyYXRvciI6Ij09IiwidmVyIjoiNC4wIn1dLCJleHRlcm5hbF9kZXBlbmRlbmNpZXMiOltdLCJwYXJlbnRJRCI6Ik5WX0RSSVZFX1dPUktTX1RBUkdFVF9HUk9VUCIsImFjdGlvbiI6MSwiZG93bmxvYWRFcnJvcnMiOlt7InVyaSI6Imh0dHBzOi8vZGV2ZWxvcGVyLm52aWRpYS5jb20vZHJpdmUvc2VjdXJlL2RyaXZlX2J1bmRsZXMvRHJpdmVfNTAxMDNMX1NES19iMTM1X09TX0dBL2RyaXZlLXQxODZyZWYtbGludXgtNS4wLjEwLjMtMTI2MDYwOTItYWFyY2g2NC1kcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LnJ1biIsImVycm9yIjpudWxsfV0sImV4ZWMiOiIvbWVkaWEvYWRtaW4xMjMvX0QvcHgyL2RyaXZlLXQxODZyZWYtbGludXgtNS4wLjEwLjMtMTI2MDYwOTItYWFyY2g2NC1kcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LnJ1biIsImluc3RhbGxQYXRoIjoiL2hvbWUvYWRtaW4xMjMvbnZpZGlhL252aWRpYV9zZGsvRFJJVkUvTGludXgvNS4wLjEwLjMvT1MiLCJ2ZXJpZnkiOmZhbHNlfQ==’ -i=‘NV_DRIVEWORKS_TARGET_COMP’ -v=‘1.2’ -l=’/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=’/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘4645’ -u=’/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=’/media/admin123/_D/px2/drive-t186ref-linux-5.0.10.3-12606092-aarch64-driveworks-v1.2.400-a7f5475-478955.run’ >
15:41:26 INFO : DriveWorks on Target : [ Disk Avail:87.63 GB]
15:41:26 INFO : DriveWorks on Target : Using GenericInstaller to install NV_DRIVEWORKS_TARGET_COMP
15:41:26 INFO : DriveWorks on Target : [ Install Started ]
15:41:26 INFO : DriveWorks on Target : runfile installer start to install NV_DRIVEWORKS_TARGET_COMP
15:41:26 INFO : DriveWorks on Target : change working directory to /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK
15:41:26 INFO : DriveWorks on Target : .install/ folder from previously installed component exists and is being removed
15:41:26 INFO : DriveWorks on Target : exec_command: /media/admin123/_D/px2/drive-t186ref-linux-5.0.10.3-12606092-aarch64-driveworks-v1.2.400-a7f5475-478955.run --noexec
15:42:07 INFO : DriveWorks on Target : Verifying archive integrity… All good.
15:43:06 INFO : DriveWorks on Target : Uncompressing drive-t186ref-linux-5.0.10.3-12606092-aarch64-driveworks-v1.2.400-a7f5475-478955…
15:43:06 INFO : DriveWorks on Target : [ Install Finished Successfully ]
15:43:06 INFO : DriveWorks on Target : [ PostInstall Started ]
15:43:06 INFO : DriveWorks on Target : current working directory is /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK
15:43:06 INFO : DriveWorks on Target : root 8805 0.0 0.0 199860 3212 ? Ssl 15:31 0:00 /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/sudo_daemon -installer=4645 -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:43:06 INFO : DriveWorks on Target : exec_command: /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/run_command -c=“cd /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK && .install/dwx-general_startup” -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp -l=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS/NV_DRIVEWORKS_TARGET_COMP.log
15:43:07 INFO : DriveWorks on Target : .install/drive-t186ref-linux
15:43:07 INFO : DriveWorks on Target : Installing DriveWorks debs …
15:43:36 INFO : DriveWorks on Target : Done.
15:43:36 INFO : DriveWorks on Target : [ PostInstall Finished Successfully ]
15:43:36 INFO : DriveWorks on Target : [ 9.00 GB used. Disk Avail: 78.63 GB ]
15:43:36 INFO : DriveWorks on Target : [ NV_DRIVEWORKS_TARGET_COMP install took 2m9s ]
15:43:36 INFO : DriveWorks on Target : command finished successfully
15:43:36 INFO : DriveWorks on Target : install ‘DriveWorks on Target’ success
15:43:36 ERROR : Zombie components detected, please check log
15:43:36 ERROR : DriveWorks Samples : install ‘DriveWorks Samples’ failure due to its dependencies fail to install: CUDA on Host,
15:43:36 ERROR : DriveWorks on Host : install ‘DriveWorks on Host’ failure due to its dependencies fail to install: CUDA on Host,
15:43:36 ERROR : DriveWorks Cross Compilation : install ‘DriveWorks Cross Compilation’ failure due to its dependencies fail to install: CUDA on Host,
15:49:21 INFO : Flash Dual Tegras in Parallel : install ‘Flash Dual Tegras in Parallel’ Skipped
15:49:21 INFO : Flash Tegra A : Start to install ‘Flash Tegra A’
15:49:21 DEBUG : Flash Tegra A : running command < cd ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘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’ -i=‘NV_FLASH_TEGRA_A_COMP’ -v=‘5.0.10.3’ -l=’/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=’/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘4645’ -u=’/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=’/media/admin123/_D/px2’ >
15:49:21 INFO : Flash Tegra A : Using LegacyInstaller to install NV_FLASH_TEGRA_A_COMP
15:49:21 INFO : Flash Tegra A : admin123
15:49:21 INFO : Flash Tegra A : root 8805 0.1 0.0 199860 2256 ? Ssl 15:31 0:01 /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/sudo_daemon -installer=4645 -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:49:21 INFO : Flash Tegra A : exec_command: /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/run_command -c=“cd /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS && rm -f /var/lock/LCK…ttyUSB1” -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:49:21 INFO : Flash Tegra A : exec_command: /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/run_command -c=“cd /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS && rm -f /var/lock/LCK…bootburn_seq” -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:49:22 INFO : Flash Tegra A : root 8805 0.1 0.0 199860 2276 ? Ssl 15:31 0:01 /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/sudo_daemon -installer=4645 -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:49:22 INFO : Flash Tegra A : exec_command: /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/run_command -c=“cd /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS && rm -f /var/lock/LCK…bootburn” -d=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/tmp
15:49:23 INFO : Flash Tegra A : exec_command: ./pdk_flash.sh -b p2379c01-t186a
15:49:23 INFO : Flash Tegra A : p2379c01-t186a will be flashed
15:49:23 INFO : Flash Tegra A : linux will be flashed
15:49:23 INFO : Flash Tegra A : Make sure only one target is connected to USB
15:49:23 INFO : Flash Tegra A : and Aurix port is not open in minicom or another terminal
15:49:23 INFO : Flash Tegra A : make -f Makefile.bind BOARD=p2379c01-t186a PCT=linux >>>>>>
15:49:23 INFO : Flash Tegra A : target SOC is t186
15:49:23 INFO : Flash Tegra A : rm -rf /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.json /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.img /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.img /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.img /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.img /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.img /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.img /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a
15:49:23 INFO : Flash Tegra A : mkdir -p /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a
15:49:23 INFO : Flash Tegra A : make -C /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/ PCT=linux CROSS_COMPILE=/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-
15:49:23 INFO : Flash Tegra A : O=/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/ HYP_SRC="/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x"
15:49:23 INFO : Flash Tegra A : PCT_INC="/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct"
15:49:23 INFO : Flash Tegra A : SOC_PCT_INC="/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc"
15:49:23 INFO : Flash Tegra A : BUILD_DTB_DTC=/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc
15:49:23 INFO : Flash Tegra A : HARDWARE_DIR="/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia"
15:49:23 INFO : Flash Tegra A : make[1]: Entering directory ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a’
15:49:23 INFO : Flash Tegra A : mkdir -p /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MM -MF /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.d -MT /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o pct.c
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -c pct.c -o /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o -nostdlib -Tpct.ld -o /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.elf
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-objcopy -j .conf -O binary /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.elf /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.bin
15:49:23 INFO : Flash Tegra A : gcc -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MM -MF /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem.d -MT /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem pct_mem.c
15:49:23 INFO : Flash Tegra A : gcc -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm pct_mem.c -o /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem > /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem.txt
15:49:23 INFO : Flash Tegra A : cp -f linux/
.cfg* /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0.d -MT /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0 linux/…/single_vm//t186-i2c-server.dts > /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0
15:49:23 INFO : Flash Tegra A : printf “\nlinux/…/single_vm//t186-i2c-server.dts:” >> /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0.d
15:49:23 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0 > /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dtb
15:49:24 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0.d -MT /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0 linux/…/single_vm//t186-vsc-server.dts > /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0
15:49:24 INFO : Flash Tegra A : printf “\nlinux/…/single_vm//t186-vsc-server.dts:” >> /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0.d
15:49:24 INFO : Flash Tegra A : /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0 > /home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dtb
D/px2’ > terminated with error
20:07:52 ERROR : Flash Dual Tegras in Parallel : 18955 blocks
20:07:53 ERROR : Flash Dual Tegras in Parallel : 18955 blocks
20:07:53 ERROR : Flash Dual Tegras in Parallel : Setting Tegra-A on hold… /dev/ttyUSB1: SDKM_INSTALL_ERROR
20:07:56 ERROR : Flash Dual Tegras in Parallel : Setting Tegra-B on hold… /dev/ttyUSB1: SDKM_INSTALL_ERROR
20:07:59 ERROR : Flash Dual Tegras in Parallel : Setting Tegra-A in recovery… /dev/ttyUSB1:
20:08:02 ERROR : Flash Dual Tegras in Parallel : /dev/ttyUSB1:SDKM_INSTALL_ERROR SDKM_INSTALL_ERROR SDKM_INSTALL_ERROR SDKM_INSTALL_ERROR
20:08:05 ERROR : Flash Dual Tegras in Parallel : Setting Tegra-B in recovery… /dev/ttyUSB1:SDKM_INSTALL_ERROR
20:08:08 ERROR : Flash Dual Tegras in Parallel : /dev/ttyUSB1: SDKM_INSTALL_ERROR
20:08:11 ERROR : Flash Dual Tegras in Parallel : Failed to flash device: please check /home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS/flash_2379_parallel.log for more details.
20:08:11 ERROR : Flash Dual Tegras in Parallel : command terminated with error
20:08:11 ERROR : Flash Dual Tegras in Parallel : install ‘Flash Dual Tegras in Parallel’ failure, command < cd ‘/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘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’ -i=‘NV_FLASH_DUAL_TEGRAS_IN_PARALLEL_COMP’ -v=‘5.0.10.3’ -l=’/home/admin123/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=’/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘20664’ -u=’/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=’/media/admin123/_D/px2’ > terminated with error
Dear chengcheng1314,
Could you please upload full log file on this topic?
The files are in you hostPC. Thanks.
~/.nvsdkm/sdkm.log
~/.nvsdkm/logs
Hi
The inside of the log content is too much, I can’t upload, so I take you to see on the packaging to the baidu the tray icon, you can download and see what’s the problem
https://pan.baidu.com/s/1KeA98TMnpExKgc8JuxwEUw
Sorry I can’t access baidu link you provided.
Could you please upload the file on google drive? Thanks.
Hi
You can put your email tell you, I put the files sent to your mailbox
Hi
cat ~/.nvsdkm/sdkm.log
2018-12-05 09:29:50.141 - info: packageJson: /media/admin123/_D/px2/resources/app.asar/package.json
2018-12-05 09:29:50.224 - info: imagesPath: /media/admin123/_D/px2/resources/app.asar/output/dist/electron/images/
2018-12-05 09:29:50.397 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:29:50.426 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=9.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:29:50.456 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_CROSS_COMPILATION_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:29:50.481 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_SAMPLES_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:29:50.528 - info: Using GenericInstaller to query NV_DRIVEWORKS_HOST_COMP
NV_DRIVEWORKS_HOST_COMP driveworks_data-v1.2.400-a7f5475-478955-nogcid-linux-amd64-ubuntu1604.deb installed successfully.
2018-12-05 09:29:50.528 - info: Using GenericInstaller to query NV_CUDA_HOST_COMP
2018-12-05 09:29:50.528 - info: Using GenericInstaller to query NV_DRIVEWORKS_CROSS_COMPILATION_COMP
2018-12-05 09:29:50.528 - info: Using GenericInstaller to query NV_DRIVEWORKS_HOST_SAMPLES_COMP
2018-12-05 09:29:50.574 - error: package [{cuda-toolkit-9-2 9.2}] not installed
2018-12-05 09:29:50.583 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=9.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:29:50.583 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_SAMPLES_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:29:50.705 - error: package [{driveworks_samples 1.2.400}] not installed
2018-12-05 09:29:50.705 - error: package [{driveworks_cross_linux 1.2.400}] not installed
2018-12-05 09:29:50.706 - error: package [{driveworks 1.2.400}] not installed
2018-12-05 09:29:50.706 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:29:50.706 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_CROSS_COMPILATION_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:29:50.852 - info: packageJson: /media/admin123/_D/px2/resources/app.asar/package.json
2018-12-05 09:29:50.862 - info: config:
{ mainRepoURL: ‘https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json’,
PIDServer: ‘P’,
DevZoneServer: ‘P’ }
2018-12-05 09:29:50.869 - info: token has not yet expired, validating with PID
2018-12-05 09:29:50.869 - info: Logging in…
2018-12-05 09:29:50.917 - info: manifest: {“name”:“sdkmanager”,“version”:“0.9.8”,“revision”:“0”,“buildNumber”:“2002”,“release”:false}
2018-12-05 09:29:50.917 - info: Setting GA parameters: title SDK Manager - Beta 0.9.8.2002 version 0.9.8 dev: 0 internal: false offline false
2018-12-05 09:29:50.918 - info: Initializing GA analytics: SDK Manager - Beta 0.9.8.2002 0.9.8.2002 0 false
2018-12-05 09:29:50.920 - info: Initialized GA visitor with: TrackID: UA-59254929-46 UserID 54273746-b23d-5ea9-abb7-d24aba58f63f
2018-12-05 09:29:50.921 - info: GA analytics: setting custom dimensions: UserType, SDKMode, SDKMVersion External UI 0.9.8.2002
2018-12-05 09:29:50.926 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-12-05 09:29:50.928 - info: logging in with l1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-12-05 09:29:51.837 - error: res.statusCode: 400
2018-12-05 09:29:51.838 - error: validateToken sendRequest failed: access denied
2018-12-05 09:29:51.840 - error: validateToken failed token_rejected
2018-12-05 09:29:51.840 - error: pid.tokenValidation failed: token_rejected
2018-12-05 09:29:52.013 - info: devzone signin page did start loading - https://login.developer.nvidia.com/authorize?response_type=code&method=login&state=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&client_id=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-12-05 09:29:55.369 - info: devzone signin page finished loading - https://login.developer.nvidia.com/login?state=g6Fo2SAyTzVYalV3eUxOR3NQSWhPT3lhdkQyandQVTc3VDhWOaN0aWTZMmdhRm8yU0JJU0dsSVpFdElWMnMxYUUxS05XczJkV2N4Yld0SU1VODVXbTVPUWpaYWJBo2NpZNkgNGpsalRlak43Uk1POXN1TDBTMzNnRnJZZ2pIWDBWY1c&client=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&protocol=oauth2&response_type=code&method=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-12-05 09:30:16.504 - info: devzone signin page did start loading - https://login.developer.nvidia.com/login?state=g6Fo2SAyTzVYalV3eUxOR3NQSWhPT3lhdkQyandQVTc3VDhWOaN0aWTZMmdhRm8yU0JJU0dsSVpFdElWMnMxYUUxS05XczJkV2N4Yld0SU1VODVXbTVPUWpaYWJBo2NpZNkgNGpsalRlak43Uk1POXN1TDBTMzNnRnJZZ2pIWDBWY1c&client=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&protocol=oauth2&response_type=code&method=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-12-05 09:30:20.257 - info: Devzone login succeeded
2018-12-05 09:30:20.257 - info: devzone login status - login-success
2018-12-05 09:30:20.288 - info: Logging in with devzone login method…
2018-12-05 09:30:20.322 - info: Retrieving Data…
2018-12-05 09:30:20.323 - info: devzone getUserProfile starts…
2018-12-05 09:30:21.251 - info: devzone getUserProfile success, took 0.928s
2018-12-05 09:30:21.251 - info: the DevZone programs that user can access:
2018-12-05 09:30:21.251 - info: { id: 874688, name: NVIDIA Developer Program }
2018-12-05 09:30:21.252 - info: { id: 876061, name: NVIDIA DRIVE™ Developer Program }
2018-12-05 09:30:21.287 - info: Processing Data…
2018-12-05 09:30:21.335 - info: Begin to create timing task for auto update.
2018-12-05 09:30:21.339 - info: Checking for update with mainRepoURL: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-12-05 09:30:21.448 - info: Create timing task for auto update successfully.
2018-12-05 09:30:22.728 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/admin123/.nvsdkm/dist successfully.
2018-12-05 09:30:23.902 - error: sdkml2_sdkm.json download failed with error:
404 Not Found
404 Not Found
nginx/1.15.6 , request url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKM-APP/sdkml2_sdkm.json 2018-12-05 09:30:23.904 - error: failed to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKM-APP/sdkml2_sdkm.json with error: 404 Not Found
404 Not Found
nginx/1.15.6
2018-12-05 09:30:23.907 - info: level1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-12-05 09:30:24.864 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/admin123/.nvsdkm/dist successfully.
2018-12-05 09:30:25.649 - error: sdkml2_sdkm.json download failed with error:
404 Not Found
404 Not Found
nginx/1.15.6 , request url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKM-APP/sdkml2_sdkm.json 2018-12-05 09:30:25.650 - error: 2018-12-05 09:30:25.651 - error: egGetBundlesList failed. Error: 2018-12-05 09:30:25.684 - error: The user has no permission to any bundle. 2018-12-05 09:30:26.654 - info: sdkml2_drive_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/Linux/sdkml2_drive_linux.json has been downloaded to /home/admin123/.nvsdkm/dist successfully. 2018-12-05 09:30:26.659 - info: validating product line for target OS: Linux 2018-12-05 09:30:26.665 - info: validating release: DRIVE Software 1.0 2018-12-05 09:30:26.669 - info: validating release: DRIVE OS 5.0.10.3 SDK with DriveWorks 2018-12-05 09:30:26.672 - info: validating release: DRIVE OS 5.0.10.3 PDK 2018-12-05 09:30:26.674 - info: validating release: DRIVE OS 5.0.13.0 SDK 2018-12-05 09:30:26.677 - info: validating release: DRIVE OS 5.0.13.0 PDK 2018-12-05 09:30:26.680 - warn: No access to devzone program id 879192 2018-12-05 09:30:26.684 - info: Can access to devzone program id 876061 2018-12-05 09:30:26.685 - warn: No access to devzone program id -1 2018-12-05 09:30:26.687 - warn: Empty devzone program id, user can access this program 2018-12-05 09:30:26.687 - warn: Empty devzone program id, user can access this program 2018-12-05 09:30:26.702 - warn: No access to release DRIVE Software 1.0 2018-12-05 09:30:26.703 - warn: No access to release DRIVE OS 5.0.10.3 PDK 2018-12-05 09:30:27.303 - info: sdkml2_drive_qnx.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/QNX/sdkml2_drive_qnx.json has been downloaded to /home/admin123/.nvsdkm/dist successfully. 2018-12-05 09:30:27.308 - info: validating product line for target OS: QNX 2018-12-05 09:30:27.315 - info: validating release: DRIVE OS 5.0.13.0 SDK 2018-12-05 09:30:27.320 - info: validating release: DRIVE OS 5.0.13.0 PDK 2018-12-05 09:30:27.321 - warn: Empty devzone program id, user can access this program 2018-12-05 09:30:27.321 - warn: Empty devzone program id, user can access this program 2018-12-05 09:30:27.336 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:30:27.337 - warn: No access to release DRIVE OS 5.0.13.0 PDK 2018-12-05 09:30:27.342 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:30:27.343 - warn: No access to release DRIVE OS 5.0.13.0 SDK 2018-12-05 09:30:28.218 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:30:28.219 - warn: No access to release DRIVE OS 5.0.13.0 SDK 2018-12-05 09:30:28.222 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:30:28.223 - warn: No access to release DRIVE OS 5.0.13.0 PDK 2018-12-05 09:31:52.004 - info: level1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json 2018-12-05 09:31:52.023 - info: validating product line for target OS: Linux 2018-12-05 09:31:52.028 - info: validating release: DRIVE Software 1.0 2018-12-05 09:31:52.031 - info: validating release: DRIVE OS 5.0.10.3 SDK with DriveWorks 2018-12-05 09:31:52.034 - info: validating release: DRIVE OS 5.0.10.3 PDK 2018-12-05 09:31:52.038 - info: validating release: DRIVE OS 5.0.13.0 SDK 2018-12-05 09:31:52.041 - info: validating release: DRIVE OS 5.0.13.0 PDK 2018-12-05 09:31:52.046 - info: validating product line for target OS: QNX 2018-12-05 09:31:52.051 - info: validating release: DRIVE OS 5.0.13.0 SDK 2018-12-05 09:31:52.053 - info: validating release: DRIVE OS 5.0.13.0 PDK 2018-12-05 09:31:52.059 - warn: No access to devzone program id 879192 2018-12-05 09:31:52.060 - info: Can access to devzone program id 876061 2018-12-05 09:31:52.061 - warn: No access to devzone program id -1 2018-12-05 09:31:52.061 - warn: Empty devzone program id, user can access this program 2018-12-05 09:31:52.062 - warn: Empty devzone program id, user can access this program 2018-12-05 09:31:52.062 - warn: Empty devzone program id, user can access this program 2018-12-05 09:31:52.062 - warn: Empty devzone program id, user can access this program 2018-12-05 09:31:52.102 - warn: No access to release DRIVE Software 1.0 2018-12-05 09:31:52.103 - warn: No access to release DRIVE OS 5.0.10.3 PDK 2018-12-05 09:31:52.883 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:31:52.884 - warn: No access to release DRIVE OS 5.0.13.0 SDK 2018-12-05 09:31:52.887 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:31:52.888 - warn: No access to release DRIVE OS 5.0.13.0 SDK 2018-12-05 09:31:52.889 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:31:52.890 - warn: No access to release DRIVE OS 5.0.13.0 PDK 2018-12-05 09:31:52.892 - error: {"Message":"Invalid token","Status":"Forbidden","StatusCode":403,"Output":null} 2018-12-05 09:31:52.892 - warn: No access to release DRIVE OS 5.0.13.0 PDK 2018-12-05 09:31:52.896 - error: sdkml2_sdkm.json download failed with error: 404 Not Found
404 Not Found
nginx/1.15.6 , request url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKM-APP/sdkml2_sdkm.json 2018-12-05 09:31:52.896 - error: 2018-12-05 09:31:52.896 - error: egGetBundlesList failed. Error: 2018-12-05 09:31:52.898 - error: The user has no permission to any bundle. 2018-12-05 09:32:01.536 - info: cleaning up engine 2018-12-05 09:32:01.536 - info: installManager cleanup 2018-12-05 09:32:01.552 - info: The overall duration (Download + Install) is 00:02:11
2018-12-05 09:32:01.555 - info:
Download summary of 0 files (0B / 0B)
Download 0 files.
Cached 0 files.
Failed 0 files.
Download started on: .
Download ended on: Wed Dec 05 2018 09:32:01 GMT+0800 (CST).
Download duration: 00:02:11 - avg. download speed: 0B/s (using 2 threads, 3 processes from ).
Download details:
None
2018-12-05 09:32:01.557 - info:
Install summary of 0 components:
Install started on: did not start installing.
Install ended on: 0.
Install duration: 0.000s .
Install idle time: 0.000s .
Real install duration (duration - idle time): 0.000s .
Install 0 components.
- Already Install 0 components.
Install failed 0 files.
Install skipped 0 files.
Install details:
None
2018-12-05 09:32:06.449 - info: packageJson: /media/admin123/_D/px2/resources/app.asar/package.json
2018-12-05 09:32:06.534 - info: imagesPath: /media/admin123/_D/px2/resources/app.asar/output/dist/electron/images/
2018-12-05 09:32:06.718 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=eyJpZCI6Ik5WX0RSSVZFV09SS1NfSE9TVF9DT01QIiwibmFtZSI6IkRyaXZlV29ya3Mgb24gSG9zdCIsImRlc2NyaXB0aW9uIjoiTlZJRElBIERyaXZlV29ya3Mgc29mdHdhcmUgZGV2ZWxvcG1lbnQga2l0IChTREspIGdpdmVzIGRldmVsb3BlcnMgYSBmb3VuZGF0aW9uIHVwb24gd2hpY2ggdG8gYnVpbGQgYXBwbGljYXRpb25zLCBsZXZlcmFnaW5nIHRoZSBjb21wdXRhdGlvbmFsbHkgaW50ZW5zaXZlIGFsZ29yaXRobXMgZm9yIG9iamVjdCBkZXRlY3Rpb24sIG1hcCBsb2NhbGl6YXRpb24sIGFuZCBwYXRoIHBsYW5uaW5nLiIsImlzVmlzaWJsZSI6dHJ1ZSwibGljZW5zZUlkIjoiTlZfRFJJVkVfU0xBX09DVDIwMTciLCJpc0RldGVjdGFibGVJbnN0YWxsIjp0cnVlLCJpc0luc3RhbGxQYXRoQ3VzdG9taXphYmxlIjp0cnVlLCJ2ZXJzaW9uIjoiMS4yIiwib3BlcmF0aW5nU3lzdGVtcyI6WyJ1YnVudHUxNjA0Il0sImluc3RhbGxTaXplTUIiOjg1NCwiZG93bmxvYWRGaWxlcyI6W3sidXJsIjoiZHJpdmV3b3Jrc19kYXRhLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LW5vZ2NpZC1saW51eC1hbWQ2NC11YnVudHUxNjA0LmRlYiIsImZpbGVOYW1lIjoiZHJpdmV3b3Jrc19kYXRhLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LW5vZ2NpZC1saW51eC1hbWQ2NC11YnVudHUxNjA0LmRlYiIsInNpemUiOjI2OTMyMTI5NDgsImNoZWNrc3VtIjoiODc0ZWM3MTk4M2Y1OTllNGUwZGJhMjdlZWM4MDg0ZDgiLCJjaGVja3N1bVR5cGUiOiJtZDUiLCJpbnN0YWxsUGFyYW1ldGVycyI6eyJpbnN0YWxsVHlwZSI6ImRlYiIsImFkZGl0aW9uYWxQYXJhbWV0ZXJzIjp7InBhY2thZ2VzSW5mbyI6W3sibmFtZSI6ImRyaXZld29ya3NfZGF0YSIsInZlcnNpb24iOiIxLjIuNDAwIn1dfX0sImNhY2hlZFVybCI6Imh0dHBzOi8vZGV2ZWxvcGVyLm52aWRpYS5jb20vZHJpdmUvc2VjdXJlL2RyaXZlX2J1bmRsZXMvRHJpdmVfNTAxMDNMX1NES19iMTM1X09TX0dBL2RyaXZld29ya3NfZGF0YS12MS4yLjQwMC1hN2Y1NDc1LTQ3ODk1NS1ub2djaWQtbGludXgtYW1kNjQtdWJ1bnR1MTYwNC5kZWIifSx7InVybCI6ImRyaXZld29ya3MtdjEuMi40MDAtYTdmNTQ3NS00Nzg5NTUtbm9nY2lkLWxpbnV4LWFtZDY0LXVidW50dTE2MDQuZGViIiwiZmlsZU5hbWUiOiJkcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LW5vZ2NpZC1saW51eC1hbWQ2NC11YnVudHUxNjA0LmRlYiIsInNpemUiOjIzNjAwNTgxNTYsImNoZWNrc3VtIjoiYmQ1NDdjNjg4NjMyZTA0Yzc5NmEwOWZlZmRiMjU1YTEiLCJjaGVja3N1bVR5cGUiOiJtZDUiLCJpbnN0YWxsUGFyYW1ldGVycyI6eyJpbnN0YWxsVHlwZSI6ImRlYiIsImFkZGl0aW9uYWxQYXJhbWV0ZXJzIjp7InBhY2thZ2VzSW5mbyI6W3sibmFtZSI6ImRyaXZld29ya3MiLCJ2ZXJzaW9uIjoiMS4yLjQwMCJ9XX19LCJjYWNoZWRVcmwiOiJodHRwczovL2RldmVsb3Blci5udmlkaWEuY29tL2RyaXZlL3NlY3VyZS9kcml2ZV9idW5kbGVzL0RyaXZlXzUwMTAzTF9TREtfYjEzNV9PU19HQS9kcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LW5vZ2NpZC1saW51eC1hbWQ2NC11YnVudHUxNjA0LmRlYiJ9XSwidGFyZ2V0SWRzIjpbIlBYMl9BVVRPQ1JVSVNFIiwiUFgyX0FVVE9DSEFVRkZFVVIiXSwiZGVwZW5kZW5jaWVzIjpbeyJpZCI6Ik5WX1RFTlNPUlJUX0hPU1RfQ09NUCIsIm9wZXJhdG9yIjoiPT0iLCJ2ZXIiOiI0LjAifV0sImV4dGVybmFsX2RlcGVuZGVuY2llcyI6W10sInBhcmVudElEIjoiTlZfRFJJVkVfV09SS1NfSE9TVF9HUk9VUCIsImluc3RhbGxQYXRoIjoiL2hvbWUvYWRtaW4xMjMvbnZpZGlhL252aWRpYV9zZGsiLCJhY3Rpb24iOjEsImRvd25sb2FkRXJyb3JzIjpbeyJ1cmkiOiJodHRwczovL2RldmVsb3Blci5udmlkaWEuY29tL2RyaXZlL3NlY3VyZS9kcml2ZV9idW5kbGVzL0RyaXZlXzUwMTAzTF9TREtfYjEzNV9PU19HQS9kcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LW5vZ2NpZC1saW51eC1hbWQ2NC11YnVudHUxNjA0LmRlYiIsImVycm9yIjpudWxsfSx7InVyaSI6Imh0dHBzOi8vZGV2ZWxvcGVyLm52aWRpYS5jb20vZHJpdmUvc2VjdXJlL2RyaXZlX2J1bmRsZXMvRHJpdmVfNTAxMDNMX1NES19iMTM1X09TX0dBL2RyaXZld29ya3NfZGF0YS12MS4yLjQwMC1hN2Y1NDc1LTQ3ODk1NS1ub2djaWQtbGludXgtYW1kNjQtdWJ1bnR1MTYwNC5kZWIiLCJlcnJvciI6bnVsbH1dLCJ2ZXJpZnkiOmZhbHNlLCJleGVjIjoiL21lZGlhL2FkbWluMTIzL19EL3B4Mi9kcml2ZXdvcmtzLXYxLjIuNDAwLWE3ZjU0NzUtNDc4OTU1LW5vZ2NpZC1saW51eC1hbWQ2NC11YnVudHUxNjA0LmRlYiJ9 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:32:06.741 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=9.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:32:06.763 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_CROSS_COMPILATION_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:32:06.771 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_SAMPLES_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-12-05 09:32:06.820 - info: Using GenericInstaller to query NV_DRIVEWORKS_HOST_COMP
2018-12-05 09:32:06.821 - info: Using GenericInstaller to query NV_CUDA_HOST_COMP
2018-12-05 09:32:06.821 - info: Using GenericInstaller to query NV_DRIVEWORKS_CROSS_COMPILATION_COMP
2018-12-05 09:32:06.821 - info: Using GenericInstaller to query NV_DRIVEWORKS_HOST_SAMPLES_COMP
2018-12-05 09:32:07.019 - error: package [{driveworks_samples 1.2.400}] not installed
2018-12-05 09:32:07.022 - info: NV_DRIVEWORKS_HOST_COMP driveworks_data-v1.2.400-a7f5475-478955-nogcid-linux-amd64-ubuntu1604.deb installed successfully.
2018-12-05 09:32:07.022 - error: package [{cuda-toolkit-9-2 9.2}] not installed
2018-12-05 09:32:07.022 - error: package [{driveworks_cross_linux 1.2.400}] not installed
2018-12-05 09:32:07.023 - error: package [{driveworks 1.2.400}] not installed
2018-12-05 09:32:07.026 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:32:07.026 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=9.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:32:07.026 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_CROSS_COMPILATION_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:32:07.026 - info: finishing /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_SAMPLES_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/admin123/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-12-05 09:32:07.164 - info: packageJson: /media/admin123/_D/px2/resources/app.asar/package.json
2018-12-05 09:32:07.176 - info: config:
PIDServer: ‘P’,
2018-12-05 09:32:07.182 - info: token has not yet expired, validating with PID
2018-12-05 09:32:07.183 - info: Logging in…
2018-12-05 09:32:07.233 - info: manifest: {“name”:“sdkmanager”,“version”:“0.9.8”,“revision”:“0”,“buildNumber”:“2002”,“release”:false}
2018-12-05 09:32:07.233 - info: Setting GA parameters: title SDK Manager - Beta 0.9.8.2002 version 0.9.8 dev: 0 internal: false offline false
2018-12-05 09:32:07.233 - info: Initializing GA analytics: SDK Manager - Beta 0.9.8.2002 0.9.8.2002 0 false
2018-12-05 09:32:07.235 - info: Initialized GA visitor with: TrackID: UA-59254929-46 UserID 54273746-b23d-5ea9-abb7-d24aba58f63f
2018-12-05 09:32:07.235 - info: GA analytics: setting custom dimensions: UserType, SDKMode, SDKMVersion External UI 0.9.8.2002
2018-12-05 09:32:07.237 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-12-05 09:32:07.237 - info: logging in with l1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-12-05 09:32:08.031 - error: res.statusCode: 400
2018-12-05 09:32:08.032 - error: validateToken sendRequest failed: access denied
2018-12-05 09:32:08.032 - error: validateToken failed token_rejected
2018-12-05 09:32:08.032 - error: pid.tokenValidation failed: token_rejected
2018-12-05 09:32:10.004 - info: devzone signin page did start loading - https://login.developer.nvidia.com/authorize?response_type=code&method=login&state=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&client_id=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-12-05 09:32:59.477 - info: cleaning up engine
2018-12-05 09:32:59.477 - info: installManager cleanup
2018-12-05 09:32:59.503 - info: The overall duration (Download + Install) is 00:00:53
2018-12-05 09:32:59.505 - info:
Download 0 files.
Cached 0 files.
Failed 0 files.
Download ended on: Wed Dec 05 2018 09:32:59 GMT+0800 (CST).
Download duration: 00:00:53 - avg. download speed: 0B/s (using 2 threads, 3 processes from ).
Download details:
None
2018-12-05 09:32:59.509 - info:
Install details:
None
2018-12-05 09:33:07.154 - info: packageJson: /media/admin123/_D/px2/resources/app.asar/package.json
2018-12-05 09:33:07.241 - info: imagesPath: /media/admin123/_D/px2/resources/app.asar/output/dist/electron/images/
2018-12-05 09:33:07.425 - info: running /media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/media/admin123/_D/px2/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=eyJpZCI6Ik5WX0RSSVZFV09SS1NfSE9TVF9DT01QIiwibmFtZSI6IkRyaXZlV29ya3Mgb24gSG9zdCIsImRlc2NyaXB0aW9uIjoiTlZJRElBIERyaXZlV29ya3Mgc29mdHdhcmUgZGV2ZWxvcG1lbnQga2l0IChTREspIGdpdmVzIGRldmVsb3BlcnMgYSBmb3VuZGF0aW9uIHVwb24gd2hpY2ggdG8gYnVpbGQgYXBwbGljYXRpb25zLCBsZXZlcmFnaW5nIHRoZSBjb21wdXRhdGlvbmFsbHkgaW50ZW5zaXZlIGFsZ29yaXRobXMgZm9yIG9iamVjdCBkZXRlY3Rpb24sIG1hcCBsb2NhbGl6YXRpb24sIGFuZCBwYXRoIHBsYW
Hi
I’ve put the file package uploaded to Google drive
Dear chengcheng1314,
From the log, it looks like your apt repositories broken or apt database failed to update.
Could you install any package by apt-get command?
Possible cause: CUDA add a foreign architecture “arm64” that makes apt-get update failure.
  1. Please check if ARCH arm64 exists in the system arch list. Run sudo dpkg --print-foreign-architectures
  2. If Yes. Run sudo apt-get purge “*:arm64”, all arm64 package will be removed.
  3. Then sudo dpkg --remove-architecture arm64, remove ARCH arm64 from system arch list.
  4. Then “sudo apt-get update” should end with success.
Could you let me know if you use proxy? Thanks.
