Hello, I am using JetPack 3.2.1 to flash the TX2 with an Orbitty carrier board. The TX2 has 28.1 on it and I would like 28.2.
I installed JetPack on my host but flashing to the device fails. When following the NVIDIA instructions here, at step 14 a terminal appears and tells me to put the TX2 into force recovery mode. I do and it proceeds to print a long list of directories and files in this format:
Making system.img...
rm: cannot remove 'mnt/README.txt': Read-only file system
rm: cannot remove 'mnt/home/nvidia/examples.desktop': Read-only file system
rm: cannot remove 'mnt/home/nvidia/.bashrc': Read-only file system
rm: cannot remove 'mnt/home/nvidia/report_ip_to_host.sh': Read-only file system
rm: cannot remove 'mnt/home/nvidia/.profile': Read-only file system
rm: cannot remove 'mnt/home/nvidia/.bash_logout': Read-only file system
rm: cannot remove 'mnt/home/ubuntu/Downloads': Read-only file system
rm: cannot remove 'mnt/home/ubuntu/.gnupg/private-keys-v1.d': Read-only file system
rm: cannot remove 'mnt/etc/NetworkManager/VPN/nm-pptp-service.name': Read-only file system
rm: cannot remove 'mnt/etc/NetworkManager/conf.d/10-ubuntu-fan.conf': Read-only file system
rm: cannot remove 'mnt/etc/NetworkManager/system-connections': Read-only file system
rm: cannot remove 'mnt/etc/NetworkManager/dnsmasq.d': Read-only file system
rm: cannot remove 'mnt/etc/passwd': Read-only file system
rm: cannot remove 'mnt/etc/nsswitch.conf': Read-only file system
rm: cannot remove 'mnt/media': Read-only file system
rm: cannot remove 'mnt/mnt': Read-only file system
clearing ext4 mount point failed.
CTI’s instructions for the Orbitty board (see “CTI-L4T BSPs for TX2 and TX2i L4T V28.2 and Higher” section) result in the same output. I believe NVIDIA’s installer runs the same flash.sh script that CTI’s instructions tell you to run from the command line.
Inside the flash.sh script I believe these errors are coming from the
build_fsmsg()
function but I’m not exactly sure what it is doing. Googling has been no help.
How can I flash 28.2 to my TX2? Thank you.
