In another post about Xavier performance, someone (carolyuu) had suggested flashing Xavier with the following command to achieve maximum performance:
sudo ./flash.sh -r -k kernel-dtb jetson-xavier-maxn mmcblk0p1
I would just like to understand if this is really/still necessary to achieve maximum performance, or if running:
nvpmodel -m 0
/usr/bin/jetson_clocks
Is sufficient…?
Thank you!
Hi logidelic,
Yes, please set the clocks for maximum performance:
$ sudo nvpmodel -m 0
$ sudo ./jetson_clocks.sh
Please reference: https://www.jetsonhacks.com/2018/10/07/nvpmodel-nvidia-jetson-agx-xavier-developer-kit/
Hi Carlyuu. Truly appreciate the response, but I still don’t think it’s answering my question (or at least you’re not writing it explicitly). I know that we need to execute nvpmodel and jetson_clocks.
My question is, are we always required to flash using the “jetson-xavier-maxn” configuration as well to achieve maximum performance?
Hi logidelic,
Yes, if you want to achieve maximum performance, you need flash with jetson-xavier-maxn.conf and set nvpmodel to 0, you can refer L4T documentation → “Power Management for Jetson AGX Xavier Devices” section to see detail.
Documentation download link: [url]https://developer.nvidia.com/embedded/dlc/l4t-documentation-32-1[/url]
