Hello all;
We have a possibity of make the overclock in Jetson AGX Xavier ? If yes what the procedure ?
Tks
Hello all;
Tks
Running “sudo nvpmodel -m 0” will set the max clock range availability. Then running “sudo jetson_clocks” (or “sudo ~ubuntu/jetson_clocks.sh” on older releases) will then force clocks to max within that range. There is no support for going out of that range.
