Can I flash my Xavier NX with OpenCV with cuda installed? Like by cloning opencv_build directory in /Linux_for_Tegra/rootfs/home/ directory then using cmake and make commands, can I flash this kind of image directly as I have seen it takes a lot of time in make command, when I install it manually.
Shine.d
1
you can refer to Backup and Restore section for this:
Related topics
| Best way to install openCV with Cuda on Jetpack 5 (Xavier NX) : openCV for Tegra? | 1 | 10960 | August 3, 2022 | |
| Do people use Xavier without flashing Jetpack? | 2 | 961 | December 27, 2018 | |
| Install Opencv Jetson Xavier NX Developer kit | 2 | 1017 | November 27, 2023 | |
| Installing only Cuda and OpenCV from Jetpack 5 Using SDK Manager | 2 | 927 | June 29, 2023 | |
| FLASHING FAILED - Xavier - JetsPack 4.4 DP - SDKManager | 10 | 3214 | July 7, 2020 | |
| OpenCV CUDA support? | 17 | 5782 | August 17, 2020 | |
| OpenCV CUDA on AGX XAVIER | 3 | 1081 | March 23, 2021 | |
| Failure to get opencv with cuda working | 3 | 939 | March 30, 2023 | |
| Jetson Xavier NX Cuda-enabled OpenCV Python | 7 | 3148 | October 16, 2021 | |
| Opencv cuda version compile error | 1 | 599 | December 1, 2020 |
