i have using 5 user pgi workstation in two machines it is running Ok but
another two machines it is generating error while compile the program
the error is
when i enter this command
pgf90 test.f i m using Linux9.0 O.S
the error is
The License key & Data for the feature donot match
flexlm error -8130
but i install the license file correctly from internet and moreover i have installed this s/w previously two machines there it run correctly
Then i check configuration I seen that in previous two machines the /usr/pgi license.dat file use 5.1 version but later license file is
uses 5.2 then i download new s/w and copy licencse file but problem is still occur
can u tell me the exact problem and what is the solution for this problem
sandeep gupta
