Flickering Issues with XWayland on RHEL9 with Hybrid RTX 4500
On RHEL9 Systems we currently experience issues with heavy flickering/graphical issues using RTX 4500 ADA in Combination with an integrated Intel Chip. We narrowed down the issue this far:
  • It only happens on Systems with the RTX4500 ADA in Combination with an integrated Intel Chip. On Systems where only the RTX4500 is available no flickering appears
    lspci | grep VGA
    00:02.0 VGAcompatible controller: Intel Corporation Arrow Lake-S [Intel Graphics] (rev 06)
    02:00.0 VGAcompatible controller: NVIDIA Corporation AD104GL [RTX 4500 Ada Generation] (rev a1)
    80:14.5 Non-VGA unclassified device: Intel Corporation Device 7f2f (rev 10)
  • So far we observed this issue only on Redhat Systems, Ubuntu Systems don’t seem to be affected
  • The issue only persists while using the proprietary nvidia-drivers, the nouveau-driver is not affected
  • The issue affects atleast following versions:
    nvidia-driver-580.105.08-1.el9.x86_64
    nvidia-driver-575.57.08-1.el9.x86_64
  • The issue can be fixed temporarily fixed by setting following Environment Setting: XWAYLAND_NO_GLAMOR=1However, this causes trouble with other graphical applications
  • The issue affects X-based applications like ICAClient in multiple Versions
  • Disabling the Intel-Chip in BIOS or blacklisting the i915-Driver does not fix the behaviour
  • The issue affects multiple systems
Hi @GOpenguin1
Please help to share nvidia bug report from repro state and reliable repro steps if any.
nvidia-bug-report-575.log.gz (531.6 KB)
nvidia-bug-report-580noglam.log.gz (604.5 KB)
I added twi bug-reports, one running nvidia-575 still affected by the same issues, one running nvidia-580 with the mentioned no_glamour option still active.
@amrits Are there any updates regarding this issue? Is this fixed in a later release?
Any information would be appreciated. Thank you.
