For Jetpack 5.0.2, I want to know if the emmc can be started if it does not flush the system
对于jetpack5.0.2 我想知道如果emmc不刷系统,可以启动么
For Jetpack 5.0.2, I want to know if the emmc can be started if it does not flush the system,
像jetpack4.6一样,只刷一个qspi用于引导
Like Jetpack 4.6, only one QSPI is used for booting
目前我试过了很多次,直接刷到nvme上不能启动,还需要刷一次emmc,这在jetpack4.6版本上是不存在这个问题的,直接刷到nvme上就能启动了,我不知道这里有啥需要特别注意的地方
At present, I have tried many times. I can’t start by directly brushing to the nvme, and I still need to brush the emmc once. This problem does not exist in Jetpack 4.6. I can start by directly brushing to the nvme. I don’t know what I need to pay special attention to here
Since bootloader is changed to UEFI, mechanism is changed too.
Please refer to this post.
OK, thank you, because I didn’t see that the order of machine brushing must be nvme first and then emmc. I think I need to spend some time studying this
