• Hardware Platform (Jetson / GPU) - Jetson Nano • DeepStream Version - 6.0.1 • JetPack Version (valid for Jetson only) - 4.6.2 • TensorRT Version - 8.2 • NVIDIA GPU Driver Version (valid for GPU only) - 10.2 • Issue Type( questions, new requirements, bugs)
I am using the deeptream-test3.py code to store clips using smart record with a period of a 5-minute interval. Every 5 minutes, the clips will be stored. However, I encountered the following error while storing the clips:
'free(): invalid pointer.
Aborted (core dumped).
When running the deeptream-test3.py code with smart recording for two RTSP streams, the clips will be stored at 5-minute intervals. The code initiates the record event using the probe function upon startup and stops after 5 minutes. The process then repeats, starting the recording event again.
@yuweiw
Does nvurisrcbin 's smart-record use an encoder for storing video clips, and if so, which one does it use—hardware encoder or software encoder?
If you want to encode by yourself, like our demo deepstream_test_sr_app.c. We sugget you use the hardware encoder. But just for our smart record, it doesn’t need a encoder. You can refer to our guide: https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Smart_video.html.
The original raw data entering Smart Recording Module is originally the H264 stream in RTSP.
It’s the deepstream-test3 with the patch FAQ.
Just run that with python3 deepstream_test_3.py -i rtsp://127.0.0.1/video1 rtsp://127.0.0.1/video2 -s in the README file.
