Hi all,
I hope this is the right forum. We are developing a camera-based operator efficiency monitoring application for a client. We would like to have a setup where we put
- two cameras in each room of a floor (8-10 rooms)
- connect the cameras to a local device for inference
- connect the local device to a remote server (for uploading inference results)
I am trying to figure out whether we can use Nvdia devices (Jetson TX2) for such a use case. And what other pieces equipment we do need to ‘ship’ to our clients to set it up.
(a service provide with expertise in installing CCTV/IP cameras will be involved but we still need to supply the hardware specifications).
One of the worries I have is that there is no casings (as far as I can tell) for the development board.
Can anyone provide some directions?
Best
Could you share more detail about your use case?
Since cable length is usually limited, it seems hard to connect all the camera in 8 rooms to the same board.
Is this something you are trying to find? Or the camera will connect to network and inference as a RTSP input?
Hi AastaLLL,
I somehow missed the notification for your reply. My apologies.
I know very little about electronic equipment or networks. But you are right about the cable length issue. So, we shall need IP cameras connected to a local network through a wifi.
As I mentioned in the question, our first priority is to understand the hardware specifications we need.
Thanks again
