Fuse burning failure after a successful KEK0
Yet another question about a fuse burning. This looks like the post, but whose link marked as a solution does not exist or I can not access.
TX2 carrier board, L4T 32.2.3
This has happened as follows.
  1. KEK0 was burned with PKC
$ echo "0x000000000000000000000000abcd0001" > abcd0008_kek0.txt
$ sudo ./odmfuse.sh -j -i 0x18 -c PKC -k ../abcd0008.pem --KEK0 ../abcd0008_kek0.txt jetson-tx2
[sudo] password for tsato:
Sorry, try again.
./tegraflash.py --chip 0x18 --applet "/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin"  --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0061 ] Generating RCM messages
[   0.0077 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[   0.0095 ] RCM 0 is saved as rcm_0.rcm
[   0.0103 ] RCM 1 is saved as rcm_1.rcm
[   0.0103 ] List of rcm files are saved in rcm_list.xml
[   0.0103 ]
[   0.0103 ] Signing RCM messages
[   0.0119 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0136 ] Assuming zero filled SBK key
[   0.0223 ]
[   0.0223 ] Copying signature to RCM mesages
[   0.0241 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0257 ]
[   0.0257 ] Boot Rom communication
[   0.0274 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[   0.0288 ] RCM version 0X180001
[   0.1894 ] Boot Rom communication completed
[   1.1959 ]
[   2.1992 ] tegrarcm_v2 --isapplet
[   2.2011 ] Applet version 01.00.0000
[   2.5384 ]
[   2.5404 ] Retrieving EEPROM data
[   2.5406 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/cvm.bin
[   2.5425 ] Applet version 01.00.0000
[   2.8946 ] Saved platform info in /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/cvm.bin
[   2.9675 ]
Board ID(3310) version(B02) sku(1000) revision(C.0)
copying sdram_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying pmc_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying br_cmd_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing mb2_bootloader(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mts_preboot(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts_bootpack(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
copying bootloader_dtb(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Existing bpmp_fw(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpmp_fw_dtb(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing tlk(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eks(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/eks.img) reused.
Existing mb1file(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing spefile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/spe.bin) reused.
copying tegraboot(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing tbcfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/cboot.bin) reused.
Existing scefile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
copying wb0boot(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
done.
Existing cfg(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing bl(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing applet(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
*** Calculating HASH from keyfile /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem ... done
PKC HASH: 0xd4401fb379c7d1efcb412054198885f49cf6486312614b32c044f49e44a44b74
*** Generating fuse configuration ... done.
done.
*** Start fusing  ...
./tegraflash.py --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --dev_params emmc.cfg  --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img" --cfg flash.xml --bl nvtboot_recovery_cpu.bin --odmdata 0x90000 --chip 0x18 --applet mb1_recovery_prod.bin  --cmd "burnfuses odmfuse_pkc.xml"
version 1.0.0
[   0.0137 ] Burning fuses
[   0.0137 ] Generating RCM messages
[   0.0152 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[   0.0168 ] RCM 0 is saved as rcm_0.rcm
[   0.0176 ] RCM 1 is saved as rcm_1.rcm
[   0.0176 ] List of rcm files are saved in rcm_list.xml
[   0.0176 ]
[   0.0176 ] Signing RCM messages
[   0.0192 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0208 ] Assuming zero filled SBK key
[   0.0293 ]
[   0.0293 ] Copying signature to RCM mesages
[   0.0307 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0332 ]
[   0.0332 ] Boot Rom communication
[   0.0344 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[   0.0355 ] BootRom is not running
[   5.2689 ]
[   6.2721 ] tegrarcm_v2 --isapplet
[   6.2740 ] Applet version 01.00.0000
[   6.6108 ]
[   6.6144 ] Parsing fuse info as per xml file
[   6.6164 ] tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[   6.6183 ] MagicId=0x45535546 version=0x1
[   6.6187 ] node: name=Kek0 size=16
[   6.6187 ]   value=0x000000000000000000000000abcd0001
[   6.6187 ] node: name=PublicKeyHash size=32
[   6.6187 ]   value=0x744ba4449ef444c0324b61126348f69cf4858819542041cbefd1c779b31f40d4
[   6.6187 ] node: name=BootSecurityInfo size=4
[   6.6187 ]   value=0x2
[   6.6188 ]
[   6.6207 ] tegrarcm_v2 --oem burnfuses blow_fuse_data.bin
[   6.6225 ] Applet version 01.00.0000
[   6.7237 ] 0000000000000001: Oem commands are not supported
[   6.7247 ] Fuse burning failed
[   6.7248 ]
[   6.7248 ] trying fusing with CPU binary
[   6.7285 ] tegrasign_v2 --key None --getmode mode.txt
[   6.7304 ] Assuming zero filled SBK key
[   6.7307 ]
[   6.7308 ] Parsing partition layout
[   6.7327 ] tegraparser_v2 --pt flash.xml.tmp
[   6.7357 ]
[   6.7357 ] Creating list of images to be signed
[   6.7376 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   6.7658 ]
[   6.7659 ] Generating signatures
[   6.7679 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[   6.7696 ] Assuming zero filled SBK key
[   7.0737 ]
[   7.0738 ] Generating br-bct
[   7.1107 ] Updating dev and MSS params in BR BCT
[   7.1109 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[   7.1460 ]
[   7.1461 ] Updating bl info
[   7.1479 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   7.1521 ]
[   7.1522 ] Updating smd info
[   7.1539 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[   7.1555 ]
[   7.1555 ] Updating Odmdata
[   7.1573 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x90000
[   7.1592 ]
[   7.1593 ] Get Signed section of bct
[   7.1611 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[   7.1627 ]
[   7.1643 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[   7.1659 ] Assuming zero filled SBK key
[   7.1664 ]
[   7.1664 ] Updating BCT with signature
[   7.1679 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[   7.1697 ]
[   7.1697 ] Generating coldboot mb1-bct
[   7.1714 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   7.1727 ] MB1-BCT version: 0xf
[   7.1730 ] Copying Sdram info from 2 to 3 set
[   7.1988 ] Packing sdram param for instance[0]
[   7.1993 ] Packing sdram param for instance[1]
[   7.1998 ] Packing sdram param for instance[2]
[   7.2003 ] Packing sdram param for instance[3]
[   7.2008 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[   7.2015 ] Appending platform config data of size :- 3048
[   7.2016 ]
[   7.2016 ] Parsing config file :mobile_scr.cfg
[   7.2016 ] Appending platform config data of size :- 12240
[   7.2016 ]
[   7.2016 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[   7.2016 ] Appending platform config data of size :- 24
[   7.2016 ]
[   7.2016 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[   7.2016 ] Appending platform config data of size :- 648
[   7.2017 ]
[   7.2017 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[   7.2017 ] Appending platform config data of size :- 64
[   7.2017 ]
[   7.2017 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   7.2017 ] Appending platform config data of size :- 1628
[   7.2017 ]
[   7.2018 ] Updating mb1-bct with firmware information
[   7.2035 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   7.2047 ] MB1-BCT version: 0xf
[   7.2054 ]
[   7.2054 ] Updating mb1-bct with storage information
[   7.2071 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   7.2083 ] MB1-BCT version: 0xf
[   7.2090 ]
[   7.2106 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[   7.2123 ]
[   7.2140 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   7.2153 ]
[   7.2173 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[   7.2188 ] Assuming zero filled SBK key
[   7.2220 ]
[   7.2239 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   7.2254 ]
[   7.2255 ] Generating recovery mb1-bct
[   7.2271 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   7.2286 ] MB1-BCT version: 0xf
[   7.2289 ] Copying Sdram info from 2 to 3 set
[   7.2557 ] Packing sdram param for instance[0]
[   7.2562 ] Packing sdram param for instance[1]
[   7.2567 ] Packing sdram param for instance[2]
[   7.2572 ] Packing sdram param for instance[3]
[   7.2577 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[   7.2584 ] Appending platform config data of size :- 3048
[   7.2584 ]
[   7.2584 ] Parsing config file :minimal_scr.cfg
[   7.2584 ] Appending platform config data of size :- 12240
[   7.2584 ]
[   7.2584 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[   7.2584 ] Appending platform config data of size :- 24
[   7.2585 ]
[   7.2585 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[   7.2585 ] Appending platform config data of size :- 648
[   7.2585 ]
[   7.2585 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[   7.2585 ]
[   7.2585 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   7.2585 ] Appending platform config data of size :- 1628
[   7.2586 ]
[   7.2586 ] Updating mb1-bct with firmware information
[   7.2605 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   7.2619 ] MB1-BCT version: 0xf
[   7.2626 ]
[   7.2626 ] Updating mb1-bct with storage information
[   7.2645 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   7.2658 ] MB1-BCT version: 0xf
[   7.2663 ]
[   7.2681 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[   7.2697 ]
[   7.2713 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[   7.2728 ]
[   7.2747 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[   7.2759 ] Assuming zero filled SBK key
[   7.2788 ]
[   7.2806 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   7.2821 ]
[   7.2823 ] Copying signatures
[   7.2837 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   7.4039 ]
[   7.4040 ] Sending BCTs
[   7.4059 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   7.4077 ] Applet version 01.00.0000
[   7.7430 ] Sending bct_bootrom
[   7.7433 ] [................................................] 100%
[   7.7448 ] Sending bct_mb1
[   7.7455 ] [................................................] 100%
[   7.7617 ]
[   7.7618 ] Generating blob
[   7.7640 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[   7.7660 ]
[   7.7680 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[   7.7708 ]
[   7.7734 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[   7.7753 ] Assuming zero filled SBK key
[   7.7897 ]
[   7.7919 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[   7.7942 ]
[   7.7958 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[   7.7972 ]
[   7.7987 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[   7.8007 ]
[   7.8028 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[   7.8043 ] Assuming zero filled SBK key
[   7.8086 ]
[   7.8106 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[   7.8127 ]
[   7.8142 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[   7.8155 ]
[   7.8169 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[   7.8184 ]
[   7.8205 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[   7.8220 ] Assuming zero filled SBK key
[   7.8270 ]
[   7.8291 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[   7.8310 ]
[   7.8328 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[   7.8345 ]
[   7.8364 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[   7.8461 ]
[   7.8486 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[   7.8504 ] Assuming zero filled SBK key
[   7.9266 ]
[   7.9289 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[   7.9333 ]
[   7.9350 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[   7.9364 ]
[   7.9380 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[   7.9401 ]
[   7.9419 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[   7.9431 ] Assuming zero filled SBK key
[   7.9575 ]
[   7.9596 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[   7.9617 ]
[   7.9636 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[   7.9651 ]
[   7.9667 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[   7.9694 ]
[   7.9715 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[   7.9726 ] Assuming zero filled SBK key
[   7.9933 ]
[   7.9951 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[   7.9977 ]
[   7.9999 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[   8.0018 ]
[   8.0038 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[   8.0076 ]
[   8.0100 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[   8.0116 ] Assuming zero filled SBK key
[   8.0345 ]
[   8.0370 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[   8.0391 ]
[   8.0410 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[   8.0426 ]
[   8.0446 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img zerosbk
[   8.0466 ]
[   8.0489 ] tegrasign_v2 --key None --list blob_tos-trusty_sigheader.img_list.xml
[   8.0500 ] Assuming zero filled SBK key
[   8.0636 ]
[   8.0652 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[   8.0670 ]
[   8.0686 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[   8.0698 ]
[   8.0713 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[   8.0726 ]
[   8.0746 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[   8.0759 ] Assuming zero filled SBK key
[   8.0761 ]
[   8.0779 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   8.0792 ]
[   8.0809 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[   8.0820 ] number of images in blob are 9
[   8.0823 ] blobsize is 4097816
[   8.0825 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 203856
[   8.0852 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89360
[   8.0858 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[   8.0864 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[   8.0872 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 344464
[   8.0880 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533904
[   8.0885 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466240
[   8.0895 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 313152
[   8.0900 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[   8.0919 ]
[   8.0920 ] Sending bootloader and pre-requisite binaries
[   8.0934 ] tegrarcm_v2 --download blob blob.bin
[   8.0945 ] Applet version 01.00.0000
[   8.4354 ] Sending blob
[   8.4356 ] [................................................] 100%
[   8.8852 ]
[   8.8870 ] tegrarcm_v2 --boot recovery
[   8.8888 ] Applet version 01.00.0000
[   9.2281 ]
[  10.2312 ] tegrarcm_v2 --isapplet
[  10.5694 ]
[  10.5715 ] tegradevflash_v2 --iscpubl
[  10.5734 ] Cannot Open USB
[  11.3504 ]
[  12.3537 ] tegrarcm_v2 --isapplet
[  12.4512 ]
[  12.4533 ] tegradevflash_v2 --iscpubl
[  12.4552 ] Bootloader version 01.00.0000
[  12.6748 ] Bootloader version 01.00.0000
[  12.6759 ]
[  12.6760 ] tegradevflash_v2 --oem burnfuses blow_fuse_data.bin
[  12.6779 ] Bootloader version 01.00.0000
[  12.7953 ] Fusing burning successful
[  12.9105 ]
[  12.9125 ] tegradevflash_v2 --reboot recovery
[  12.9144 ] Bootloader version 01.00.0000
[  13.0157 ]
*** The fuse configuration is saved in bootloader/odmfuse_pkc.xml
*** The ODM fuse has been secured with PKC keys.
*** Flash "signed BCT and bootloader(s)".
*** done.
  1. Flash an image
$ sudo BOARDID=3310 FAB=C04 ./flash.sh -u ../abcd0008.pem -r jetson-tx2 mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 2.3
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: PKC,
Board ID(3310) version(C04) sku() revision()
copying bctfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying bootrom_config(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
Existing bootloader(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
Existing cpu_bootloader(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing bpffile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing drameccfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing tosfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
copying tbcdtbfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x90000 --applet mb1_recovery_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg  --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb" --skipuid   --key "/home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem"
saving flash command in /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0224 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --getmode mode.txt
[   0.0243 ] PKC key in Open SSL format
[   0.0248 ] Key size is 256 bytes
[   0.0251 ] Valid PKC key
[   0.0290 ]
[   0.0291 ] Generating RCM messages
[   0.0311 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[   0.0330 ] RCM 0 is saved as rcm_0.rcm
[   0.0338 ] RCM 1 is saved as rcm_1.rcm
[   0.0338 ] List of rcm files are saved in rcm_list.xml
[   0.0338 ]
[   0.0339 ] Signing RCM messages
[   0.0358 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0377 ] PKC key in Open SSL format
[   0.0381 ] Key size is 256 bytes
[   0.0384 ] Valid PKC key
[   0.0405 ] Saving pkc public key  in pub_key.key
[   0.2255 ]
[   0.2255 ] Copying signature to RCM mesages
[   0.2275 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key
[   0.2300 ]
[   0.2301 ] Parsing partition layout
[   0.2509 ] tegraparser_v2 --pt flash.xml.tmp
[   0.2530 ]
[   0.2531 ] Creating list of images to be signed
[   0.2638 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml oem-rsa
[   0.2972 ]
[   0.2972 ] Generating signatures
[   0.2988 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list images_list.xml --pubkeyhash pub_key.key
[   0.2999 ] PKC key in Open SSL format
[   0.3004 ] Key size is 256 bytes
[   0.3007 ] Valid PKC key
[   0.3019 ] Saving pkc public key  in pub_key.key
[   3.1161 ]
[   3.1162 ] Generating br-bct
[   3.1180 ] Updating dev and MSS params in BR BCT
[   3.1182 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[   3.1491 ]
[   3.1492 ] Updating bl info
[   3.1506 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   3.1535 ]
[   3.1535 ] Updating smd info
[   3.1551 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[   3.1571 ]
[   3.1571 ] Updating Odmdata
[   3.1587 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x90000
[   3.1609 ]
[   3.1609 ] Get Signed section of bct
[   3.1625 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[   3.1644 ]
[   3.1660 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list bct_list.xml --pubkeyhash pub_key.key
[   3.1674 ] PKC key in Open SSL format
[   3.1677 ] Key size is 256 bytes
[   3.1678 ] Valid PKC key
[   3.1714 ] Saving pkc public key  in pub_key.key
[   3.2540 ]
[   3.2541 ] Updating BCT with signature
[   3.2554 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key
[   3.2568 ]
[   3.2569 ] Generating coldboot mb1-bct
[   3.2582 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   3.2594 ] MB1-BCT version: 0xf
[   3.2597 ] Copying Sdram info from 2 to 3 set
[   3.2768 ] Packing sdram param for instance[0]
[   3.2772 ] Packing sdram param for instance[1]
[   3.2777 ] Packing sdram param for instance[2]
[   3.2782 ] Packing sdram param for instance[3]
[   3.2787 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[   3.2791 ] Appending platform config data of size :- 3048
[   3.2791 ]
[   3.2791 ] Parsing config file :mobile_scr.cfg
[   3.2791 ] Appending platform config data of size :- 12240
[   3.2791 ]
[   3.2791 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[   3.2791 ] Appending platform config data of size :- 24
[   3.2792 ]
[   3.2792 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[   3.2792 ] Appending platform config data of size :- 648
[   3.2792 ]
[   3.2792 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[   3.2792 ]
[   3.2792 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   3.2792 ] Appending platform config data of size :- 1628
[   3.2792 ]
[   3.2793 ] Updating mb1-bct with firmware information
[   3.2806 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.2819 ] MB1-BCT version: 0xf
[   3.2826 ]
[   3.2826 ] Updating mb1-bct with storage information
[   3.2839 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.2850 ] MB1-BCT version: 0xf
[   3.2855 ]
[   3.2864 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[   3.2873 ]
[   3.2884 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct oem-rsa
[   3.2899 ]
[   3.2910 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.2920 ] PKC key in Open SSL format
[   3.2923 ] Key size is 256 bytes
[   3.2924 ] Valid PKC key
[   3.2948 ] Saving pkc public key  in pub_key.key
[   3.3800 ]
[   3.3821 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.signed mb1_cold_boot_bct_MB1_sigheader.bct.sig oem-rsa
[   3.3834 ]
[   3.3835 ] Generating recovery mb1-bct
[   3.3849 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   3.3862 ] MB1-BCT version: 0xf
[   3.3866 ] Copying Sdram info from 2 to 3 set
[   3.4050 ] Packing sdram param for instance[0]
[   3.4055 ] Packing sdram param for instance[1]
[   3.4059 ] Packing sdram param for instance[2]
[   3.4064 ] Packing sdram param for instance[3]
[   3.4069 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[   3.4073 ] Appending platform config data of size :- 3048
[   3.4073 ]
[   3.4073 ] Parsing config file :minimal_scr.cfg
[   3.4073 ] Appending platform config data of size :- 12240
[   3.4073 ]
[   3.4074 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[   3.4074 ] Appending platform config data of size :- 24
[   3.4074 ]
[   3.4074 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[   3.4074 ] Appending platform config data of size :- 648
[   3.4074 ]
[   3.4074 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[   3.4074 ]
[   3.4074 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   3.4075 ] Appending platform config data of size :- 1628
[   3.4075 ]
[   3.4075 ] Updating mb1-bct with firmware information
[   3.4090 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.4108 ] MB1-BCT version: 0xf
[   3.4118 ]
[   3.4118 ] Updating mb1-bct with storage information
[   3.4130 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.4145 ] MB1-BCT version: 0xf
[   3.4576 ]
[   3.4593 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[   3.4611 ]
[   3.4630 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct oem-rsa
[   3.4651 ]
[   3.4676 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.4690 ] PKC key in Open SSL format
[   3.4694 ] Key size is 256 bytes
[   3.4696 ] Valid PKC key
[   3.4734 ] Saving pkc public key  in pub_key.key
[   3.5580 ]
[   3.5601 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.signed mb1_bct_MB1_sigheader.bct.sig oem-rsa
[   3.5614 ]
[   3.5616 ] Copying signatures
[   3.5628 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml --pubkeyhash pub_key.key
[   3.6030 ]
[   3.6031 ] Boot Rom communication
[   3.6044 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[   3.6057 ] RCM version 0X180001
[   3.7653 ] Boot Rom communication completed
[   4.7736 ]
[   5.7770 ] tegrarcm_v2 --isapplet
[   5.7789 ] Applet version 01.00.0000
[   6.1167 ]
[   6.1167 ] Sending BCTs
[   6.1188 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.signed
[   6.1207 ] Applet version 01.00.0000
[   6.4729 ] Sending bct_bootrom
[   6.4733 ] [................................................] 100%
[   6.4747 ] Sending bct_mb1
[   6.4760 ] [................................................] 100%
[   6.4927 ]
[   6.4928 ] Generating blob
[   6.4951 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[   6.4972 ]
[   6.4993 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin oem-rsa
[   6.5022 ]
[   6.5049 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.5066 ] PKC key in Open SSL format
[   6.5070 ] Key size is 256 bytes
[   6.5072 ] Valid PKC key
[   6.5102 ] Saving pkc public key  in pub_key.key
[   6.6185 ]
[   6.6211 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.signed blob_nvtboot_recovery_cpu_sigheader.bin.sig oem-rsa
[   6.6239 ]
[   6.6260 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[   6.6279 ]
[   6.6298 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin oem-rsa
[   6.6321 ]
[   6.6345 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_nvtboot_recovery_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.6358 ] PKC key in Open SSL format
[   6.6361 ] Key size is 256 bytes
[   6.6363 ] Valid PKC key
[   6.6395 ] Saving pkc public key  in pub_key.key
[   6.7469 ]
[   6.7490 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.signed blob_nvtboot_recovery_sigheader.bin.sig oem-rsa
[   6.7507 ]
[   6.7523 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[   6.7536 ]
[   6.7550 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin oem-rsa
[   6.7569 ]
[   6.7588 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.7603 ] PKC key in Open SSL format
[   6.7605 ] Key size is 256 bytes
[   6.7607 ] Valid PKC key
[   6.7636 ] Saving pkc public key  in pub_key.key
[   6.8706 ]
[   6.8728 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.signed blob_preboot_d15_prod_cr_sigheader.bin.sig oem-rsa
[   6.8746 ]
[   6.8762 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[   6.8776 ]
[   6.8790 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin oem-rsa
[   6.8860 ]
[   6.8877 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.8888 ] PKC key in Open SSL format
[   6.8891 ] Key size is 256 bytes
[   6.8893 ] Valid PKC key
[   6.8911 ] Saving pkc public key  in pub_key.key
[   7.0281 ]
[   7.0301 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.signed blob_mce_mts_d15_prod_cr_sigheader.bin.sig oem-rsa
[   7.0338 ]
[   7.0353 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[   7.0366 ]
[   7.0381 ] tegrahost_v2 --appendsigheader blob_bpmp.bin oem-rsa
[   7.0403 ]
[   7.0421 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_bpmp_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   7.0432 ] PKC key in Open SSL format
[   7.0434 ] Key size is 256 bytes
[   7.0436 ] Valid PKC key
[   7.0456 ] Saving pkc public key  in pub_key.key
[   7.1372 ]
[   7.1391 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.signed blob_bpmp_sigheader.bin.sig oem-rsa
[   7.1409 ]
[   7.1425 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[   7.1437 ]
[   7.1450 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb oem-rsa
[   7.1470 ]
[   7.1489 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   7.1501 ] PKC key in Open SSL format
[   7.1504 ] Key size is 256 bytes
[   7.1505 ] Valid PKC key
[   7.1525 ] Saving pkc public key  in pub_key.key
[   7.2422 ]
[   7.2441 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.signed blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.sig oem-rsa
[   7.2463 ]
[   7.2478 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[   7.2492 ]
[   7.2505 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img oem-rsa
[   7.2525 ]
[   7.2544 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_tos-trusty_sigheader.img_list.xml --pubkeyhash pub_key.key
[   7.2554 ] PKC key in Open SSL format
[   7.2556 ] Key size is 256 bytes
[   7.2558 ] Valid PKC key
[   7.2585 ] Saving pkc public key  in pub_key.key
[   7.3465 ]
[   7.3484 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.signed blob_tos-trusty_sigheader.img.sig oem-rsa
[   7.3502 ]
[   7.3517 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[   7.3530 ]
[   7.3543 ] tegrahost_v2 --appendsigheader blob_eks.img oem-rsa
[   7.3557 ]
[   7.3576 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   7.3588 ] PKC key in Open SSL format
[   7.3592 ] Key size is 256 bytes
[   7.3595 ] Valid PKC key
[   7.3608 ] Saving pkc public key  in pub_key.key
[   7.4442 ]
[   7.4467 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.signed blob_eks_sigheader.img.sig oem-rsa
[   7.4487 ]
[   7.4509 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[   7.4528 ]
[   7.4547 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb oem-rsa
[   7.4577 ]
[   7.4598 ] tegrasign_v2 --key /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/abcd0008.pem --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   7.4614 ] PKC key in Open SSL format
[   7.4617 ] Key size is 256 bytes
[   7.4619 ] Valid PKC key
[   7.4650 ] Saving pkc public key  in pub_key.key
[   7.5776 ]
[   7.5798 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.signed blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.sig oem-rsa
[   7.5824 ]
[   7.5845 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[   7.5858 ] number of images in blob are 9
[   7.5864 ] blobsize is 4097848
[   7.5867 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.signed of size 203856
[   7.5897 ] Added binary blob_nvtboot_recovery_sigheader.bin.signed of size 89360
[   7.5906 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.signed of size 63104
[   7.5911 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.signed of size 2082144
[   7.5917 ] Added binary blob_bpmp_sigheader.bin.signed of size 533904
[   7.5922 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.signed of size 466240
[   7.5930 ] Added binary blob_tos-trusty_sigheader.img.signed of size 313152
[   7.5935 ] Added binary blob_eks_sigheader.img.signed of size 1440
[   7.5939 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.signed of size 344496
[   7.5947 ]
[   7.5947 ] Sending bootloader and pre-requisite binaries
[   7.5962 ] tegrarcm_v2 --download blob blob.bin
[   7.5974 ] Applet version 01.00.0000
[   7.9334 ] Sending blob
[   7.9336 ] [................................................] 100%
[   8.3837 ]
[   8.3857 ] tegrarcm_v2 --boot recovery
[   8.3876 ] Applet version 01.00.0000
[   8.7260 ]
[   9.7291 ] tegrarcm_v2 --isapplet
[  10.8403 ]
[  10.8605 ] tegradevflash_v2 --iscpubl
[  10.8624 ] Bootloader version 01.00.0000
[  11.0248 ] Bootloader version 01.00.0000
[  11.0259 ]
[  11.0259 ] Retrieving storage infomation
[  11.0279 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[  11.0298 ] Applet is not running on device. Continue with Bootloader
[  11.3819 ]
[  11.3839 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[  11.3859 ] Bootloader version 01.00.0000
[  11.5607 ] Saved platform info in storage_info.bin
[  11.5652 ]
[  11.5652 ] Flashing the device
[  11.5673 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[  11.5732 ]
[  11.5752 ] tegradevflash_v2 --pt flash.xml.bin --create
[  11.5772 ] Bootloader version 01.00.0000
[  11.7407 ] Erasing sdmmc_boot: 3 ......... [Done]
[  11.7760 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[  11.7769 ] [................................................] 100%
[  11.8249 ] Erasing sdmmc_user: 3 ......... [Done]
[  16.1975 ] Writing partition master_boot_record with mbr_1_3.bin
[  16.1984 ] [................................................] 100%
[  16.2023 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[  16.2097 ] [................................................] 100%
[  16.2141 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[  16.2219 ] [................................................] 100%
[  16.2331 ] Writing partition mb1 with mb1_prod.bin.signed
[  16.2339 ] [................................................] 100%
[  16.2410 ] Writing partition mb1_b with mb1_prod.bin.signed
[  16.2626 ] [................................................] 100%
[  16.2698 ] Writing partition dram-ecc-fw with dram-ecc_sigheader.bin.signed
[  16.2932 ] [................................................] 100%
[  16.2993 ] Writing partition badpage-fw with badpage_sigheader.bin.signed
[  16.3325 ] [................................................] 100%
[  16.3373 ] Writing partition badpage-fw_b with badpage_sigheader.bin.signed
[  16.3944 ] [................................................] 100%
[  16.3993 ] Writing partition spe-fw with spe_sigheader.bin.signed
[  16.4528 ] [................................................] 100%
[  16.4598 ] Writing partition spe-fw_b with spe_sigheader.bin.signed
[  16.5159 ] [................................................] 100%
[  16.5230 ] Writing partition mb2 with nvtboot_sigheader.bin.signed
[  16.5544 ] [................................................] 100%
[  16.5617 ] Writing partition mb2_b with nvtboot_sigheader.bin.signed
[  16.6019 ] [................................................] 100%
[  16.6090 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.signed
[  16.6544 ] [................................................] 100%
[  16.6606 ] Writing partition mts-preboot_b with preboot_d15_prod_cr_sigheader.bin.signed
[  16.7133 ] [................................................] 100%
[  16.7197 ] Writing partition SMD with slot_metadata.bin
[  16.7800 ] [................................................] 100%
[  16.8084 ] Writing partition SMD_b with slot_metadata.bin
[  16.8145 ] [................................................] 100%
[  16.8189 ] Writing partition master_boot_record with mbr_1_3.bin
[  16.8213 ] [................................................] 100%
[  16.8253 ] Writing partition APP with system.img
[  16.8267 ] [................................................] 100%
[ 952.6641 ] Writing partition mts-bootpack with mce_mts_d15_prod_cr_sigheader.bin.signed
[ 952.6831 ] [................................................] 100%
[ 952.7615 ] Writing partition mts-bootpack_b with mce_mts_d15_prod_cr_sigheader.bin.signed
[ 952.7779 ] [................................................] 100%
[ 952.8545 ] Writing partition cpu-bootloader with cboot_sigheader.bin.signed
[ 952.8707 ] [................................................] 100%
[ 952.8832 ] Writing partition cpu-bootloader_b with cboot_sigheader.bin.signed
[ 952.8909 ] [................................................] 100%
[ 952.9034 ] Writing partition bootloader-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.signed
[ 952.9105 ] [................................................] 100%
[ 952.9238 ] Writing partition bootloader-dtb_b with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.signed
[ 952.9375 ] [................................................] 100%
[ 952.9509 ] Writing partition secure-os with tos-trusty_sigheader.img.signed
[ 952.9618 ] [................................................] 100%
[ 952.9745 ] Writing partition secure-os_b with tos-trusty_sigheader.img.signed
[ 952.9905 ] [................................................] 100%
[ 953.0034 ] Writing partition eks with eks_sigheader.img.signed
[ 953.0278 ] [................................................] 100%
[ 953.0320 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.signed
[ 953.0357 ] [................................................] 100%
[ 953.0428 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.signed
[ 953.0571 ] [................................................] 100%
[ 953.0645 ] Writing partition bpmp-fw with bpmp_sigheader.bin.signed
[ 953.0809 ] [................................................] 100%
[ 953.0997 ] Writing partition bpmp-fw_b with bpmp_sigheader.bin.signed
[ 953.1212 ] [................................................] 100%
[ 953.1401 ] Writing partition bpmp-fw-dtb with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.signed
[ 953.1590 ] [................................................] 100%
[ 953.1752 ] Writing partition bpmp-fw-dtb_b with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.signed
[ 953.1980 ] [................................................] 100%
[ 953.2140 ] Writing partition sce-fw with camera-rtcpu-sce_sigheader.img.signed
[ 953.2321 ] [................................................] 100%
[ 953.2396 ] Writing partition sce-fw_b with camera-rtcpu-sce_sigheader.img.signed
[ 953.2585 ] [................................................] 100%
[ 953.2662 ] Writing partition sc7 with warmboot_wbheader.bin.signed
[ 953.2813 ] [................................................] 100%
[ 953.2860 ] Writing partition sc7_b with warmboot_wbheader.bin.signed
[ 953.2940 ] [................................................] 100%
[ 953.2989 ] Writing partition BMP with bmp.blob
[ 953.3060 ] [................................................] 100%
[ 953.3358 ] Writing partition BMP_b with bmp.blob
[ 953.3577 ] [................................................] 100%
[ 953.3642 ] Writing partition kernel with boot_sigheader.img.signed
[ 953.3798 ] [................................................] 100%
[ 953.3965 ] Writing partition kernel_b with boot_sigheader.img.signed
[ 953.4155 ] [................................................] 100%
[ 953.4324 ] Writing partition kernel-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.signed
[ 953.4561 ] [................................................] 100%
[ 953.4689 ] Writing partition kernel-dtb_b with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.signed
[ 953.4884 ] [................................................] 100%
[ 953.5247 ]
[ 953.5272 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 953.5292 ] Bootloader version 01.00.0000
[ 953.6252 ] Writing partition BCT with br_bct_BR.bct
[ 953.6258 ] [................................................] 100%
[ 953.6839 ]
[ 953.6948 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.signed
[ 953.6967 ] Bootloader version 01.00.0000
[ 953.7933 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.signed
[ 953.7943 ] [................................................] 100%
[ 953.8611 ]
[ 953.8631 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.signed
[ 953.8650 ] Bootloader version 01.00.0000
[ 953.9613 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.signed
[ 953.9623 ] [................................................] 100%
[ 954.0185 ]
[ 954.0186 ] Flashing completed
[ 954.0187 ] Coldbooting the device
[ 954.0207 ] tegradevflash_v2 --reboot coldboot
[ 954.0226 ] Bootloader version 01.00.0000
[ 954.1890 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
  1. Burning fuses won’t succeed anymore. The following example tried to burn with -p, but any command like with -o won’t work anymore with the same error.
$ sudo ./odmfuse.sh -j -i 0x18 -c PKC -k ../abcd0008.pem --KEK0 ../abcd0008_kek0.txt -p jetson-tx2
version 1.0.0
[   0.0062 ] Generating RCM messages
[   0.0078 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/tsato/Desktop/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[   0.0103 ]
[   0.0104 ] Signing RCM messages
[   0.0120 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0137 ] Assuming zero filled SBK key
[   0.0225 ]
[   0.0226 ] Copying signature to RCM mesages
[   0.0244 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0270 ]
[   0.0271 ] Boot Rom communication
[   0.0289 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[   0.0307 ] RCM version 0X13
[   0.1890 ] Boot Rom communication failed
[   5.2766 ]
Error: Return value 3
Command tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
Reading board information failed.
Here’re fuse values on the box.
$ ll /sys/devices/3820000.efuse/3820000.efuse\:efuse-burn/
total 0
drwxr-xr-x 3 root root    0 Mar 19 23:13 ./
drwxr-xr-x 4 root root    0 Mar 19 23:07 ../
-rw-rw---- 1 root root 4096 Mar 19 23:12 arm_jtag_disable
-rw-rw---- 1 root root 4096 Mar 19 23:12 boot_security_info
-rw-rw---- 1 root root 4096 Mar 19 23:12 calc_h2
-rw-rw---- 1 root root 4096 Mar 19 23:12 debug_authentication
lrwxrwxrwx 1 root root    0 Mar 19 23:12 driver -> ../../../bus/platform/drivers/tegra-fuse-burn/
-rw-r--r-- 1 root root 4096 Mar 19 23:12 driver_override
-rw-rw---- 1 root root 4096 Mar 19 23:12 kek0
-rw-rw---- 1 root root 4096 Mar 19 23:12 kek1
-rw-rw---- 1 root root 4096 Mar 19 23:12 kek2
-r--r--r-- 1 root root 4096 Mar 19 23:12 modalias
-rw-rw---- 1 root root 4096 Mar 19 23:12 odm_h2
-rw-rw---- 1 root root 4096 Mar 19 23:12 odm_info
-rw-rw---- 1 root root 4096 Mar 19 23:12 odm_lock
-rw-rw---- 1 root root 4096 Mar 19 23:12 odm_production_mode
lrwxrwxrwx 1 root root    0 Mar 19 23:12 of_node -> '../../../firmware/devicetree/base/efuse@3820000/efuse-burn'/
drwxr-xr-x 2 root root    0 Mar 19 23:12 power/
-rw-rw---- 1 root root 4096 Mar 19 23:12 public_key
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm0
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm1
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm2
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm3
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm4
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm5
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm6
-rw-rw---- 1 root root 4096 Mar 19 23:12 reserved_odm7
-rw-rw---- 1 root root 4096 Mar 19 23:12 secure_boot_key
lrwxrwxrwx 1 root root    0 Mar 19 23:07 subsystem -> ../../../bus/platform/
-rw-r--r-- 1 root root 4096 Mar 19 23:07 uevent
$ sudo cat /sys/devices/3820000.efuse/3820000.efuse\:efuse-burn/*
[sudo] password for nvidia:
0x00000000
0x00000002
0x000012dd
0x00000000
cat: '/sys/devices/3820000.efuse/3820000.efuse:efuse-burn/driver': Is a directory
(null)
0x00000000000000000000000000000000
of:Nefuse-burnT<NULL>Cnvidia,tegra186-efuse-burn0x00000000
0x00000000
0x00000000
0x00000000
cat: '/sys/devices/3820000.efuse/3820000.efuse:efuse-burn/of_node': Is a directory
cat: '/sys/devices/3820000.efuse/3820000.efuse:efuse-burn/power': Is a directory
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
cat: '/sys/devices/3820000.efuse/3820000.efuse:efuse-burn/subsystem': Is a directory
DRIVER=tegra-fuse-burn
OF_NAME=efuse-burn
OF_FULLNAME=/efuse@3820000/efuse-burn
OF_COMPATIBLE_0=nvidia,tegra186-efuse-burn
OF_COMPATIBLE_N=1
MODALIAS=of:Nefuse-burnT<NULL>Cnvidia,tegra186-efuse-burn
If having burned the KEK0 prevents no more values from being burned, I will give up on using this box, and continue to test a new one. But I would appreciate if I can burn again. I just want to burn ODM reserved fuses.
Please share the information of executing tegrafuse.sh
After runing with -p, the key should be invisible.
Also please try to set BOARDID=3310 FAB=C04 in executing odmfuse.sh
Hi, here’s the result.
It’s still visible.
$ sudo ./tegrafuse.sh
Unsupported fuse: device_key
Unsupported fuse: jtag_disable
odm_lock : 0x00000000
odm_production_mode : 0x00000000
Unsupported fuse: odm_reserved
Unsupported fuse: pkc_disable
public_key : 0x744ba4449ef444c0324b61126348f69cf4858819542041cbefd1c779b31f40d4
Unsupported fuse: sec_boot_dev_cfg
secure_boot_key : 0x00000000000000000000000000000000
Unsupported fuse: sw_reserved
OK, will try later.
I didn’t make a difference.
$ sudo BOARDID=3310 FAB=C04 ./odmfuse.sh -j -i 0x18 -c PKC -k ../abcd0008.pem --KEK0 ../abcd0008_kek0.txt -p jetson-tx2
./tegraflash.py --chip 0x18 --applet "/l4tpool/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin"  --skipuid --cmd "dump eeprom boardinfo cvm.bin"
version 1.0.0
[   0.0416 ] Generating RCM messages
[   0.0434 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /l4tpool/l4timages/TX2G1.0/L4T32.2.3/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[   0.0452 ] RCM 0 is saved as rcm_0.rcm
[   0.0559 ] RCM 1 is saved as rcm_1.rcm
[   0.0559 ] List of rcm files are saved in rcm_list.xml
[   0.0559 ]
[   0.0560 ] Signing RCM messages
[   0.0579 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0598 ] Assuming zero filled SBK key
[   0.0684 ]
[   0.0684 ] Copying signature to RCM mesages
[   0.0705 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0734 ]
[   0.0735 ] Boot Rom communication
[   0.0749 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[   0.0770 ] RCM version 0X13
[   0.2360 ] Boot Rom communication failed
[   5.4756 ]
We have checked status of tegrafuse. It looks like the TX2 is in a condition not being considered. We will see if we can handle it in odmfuse.sh. Will update.
I see, thanks for checking.
I have the same issue.
I have managed to burn necessary keys without odm_production (details in this post).
Now I try to burn only odm_production fuse:
sudo ./odmfuse.sh -j -i 0x18 -c PKC -p jetson-tx2
but get this error:
[   0.0052 ] RCM 0 is saved as rcm_0.rcm
[   0.0058 ] RCM 1 is saved as rcm_1.rcm
[   0.0058 ] List of rcm files are saved in rcm_list.xml
[   0.0058 ]
[   0.0058 ] Signing RCM messages
[   0.0067 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0074 ] Assuming zero filled SBK key
[   0.0102 ]
[   0.0103 ] Copying signature to RCM mesages
[   0.0112 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0123 ]
[   0.0123 ] Boot Rom communication
[   0.0131 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[   0.0140 ] RCM version 0X13
[   0.0145 ] Boot Rom communication failed
[   5.2105 ]
And one more question regarding L4T version:
Could anybody confirm the success of burning fuses with R32.3.1 ?
I succeed only with R32.2.1.
I have confirmed it won’t succeed with 32.3.1 as described in my another post.
Hi @TakenoriSato
For more information, do you touch odmfuse.sh? Or use default one in r32.2.3?
As described here, the patch was applied when executing odmfuse.sh. Without it, the odmfuse.sh process always gets stuck and nothing happens on TX2.
