According to the blog outlets, the new mobile GPUs are getting the latest architecture at last and some GDDR5 memory! :) Let’s hope there is something radically new on desktop side soon as well!
Wow, interesting news for two reasons. First, these are 40nm parts! So there’s progress with getting that new process working.
Second, the memory size for 4 out of 5 these mobile parts is 1GB! Wow… that’s really nice for mobile!
There’s also a vague reference to “half the power use” which sounds promising but is way too vague to make any conclusions.
However, the article does say that the new parts use GDDR3, not GDDR5.
Probably still a typo. But maybe not. GDDR5 gives you double bandwidth so you’d expect to see narrower memory width and slower clocks, but the values in the slide are consistent with GDDR3.
And the next question is: Are these compute capability 1.1 or 1.2? We haven’t seen a 1.2 device yet, but a new mobile chip is the logical place for one to appear.
But look at the GTS260Mversus the GTX260M. Suddenly it looks like there may indeed be GDDR5!
GTX 260M :
memory clock “Up to 950 Mhz”
Memory Config up to 1GB GDDR3
Memory width 256 bit
Memory Bandwidth 61 GB/sec
DX 10
GTS 260M:
Memory clock “up to 2000 MHz”
Memory Interface Width 128 bit
DX 10, Compute
The spec page for the GTS does not specifically state the type of RAM nor the bandwidth, but look at what has changed. The bus width is halved, and the clock rate is doubled.
If they are counting the “effective” clock rate of the RAM and not the real clock rate, then that is very consistent with the GDDR5 doubling of bandwidth per pin.
So I would actually have to guess that yes, this is GDDR5! And the fact that the low end parts use GDDR3 means that the memory controller can handle both types. And the DX spec change shows that this is indeed not a trivial shrink, but some re-engineering and redesign.
If these are using GDDR5, that also means that desktop parts would also be very useful… GDDR5 has fewer board traces and makes things much simpler (and cheaper).
seibert’s question of whether this is compute 1.1 or 1.2 is now also a very good one.
Compute 1.1 does not form part of the question, I think:
We also got questions about which architecture these GPUs came from and if we were simply renaming old GPUs. The answer to that is definitive–these are new GPUs based on a new design and 40nm process. At a high-level these chips are based on the same architecture used in the high-end NVIDIA desktop GPUs, so they share the same compute benefits.
Rene Haas, General Manager, notebook business at NVIDIA
Hmm, wow, look at the power use of the GTS 250M. It’s only 28 watts. That means you’re getting 12.9 GFlops/watt.
That’s better than anything we’ve ever seen. The last generation of mobile parts (from only about 4 months ago) is about 7 GFlops/watt.
The best ratio for desktop parts is the GTX295, with 6.2 GFlops/watt.
So, half the power use. GDDR5 means half the memory traces needed. Half the pincount on the chip. Smaller chip. Put this together and you get the possibility of making dual GPU single-width cards.
Or quad GPU double width cards??? Hmmmmm, tasty!!
And this isn’t even talking G300, this is just with chips that NV just showed it has.
That statement is too vague to be definitive. Mobile and desktop GPUs could be thought of as sharing the “CUDA architecture”, despite having different compute capabilities. (A technical detail I would not expect a manager to discuss in a generic Q&A session.)
Great, and then the next qustion becomes “when?”, which I believe might be answered by some projections of the near future for TSMC’s 40nm process:
TSMC Promises to Improve 40nm Yields in Two Months
… Nvidia plans to ramp up production its recently announced graphics processing units (GPUs) using 40nm process tech at TSMC in August. Meanwhile, ATI is trying hard to supply any amount … According to the report, Nvidia has said that its 40nm GPU production at TSMC will be limited to OEM parts initially. 40nm GPUs destined for the channel market will be introduced when the process is more mature, likely around the end of the year.
So no back-to-school-brand-spanking-new-MacBook - but when did that ever happen? - and those hoping to upgrade an existing system will have to wait untill Christmas … Which suits me just fine - the weather here is absolutely gorgeous these days :-)
