While running the deepstream 6.2 on h265 camera, I am getting my output display in green colour
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hardware Platform -: GPU
DeepStream Version -: 6.2
TensorRT Version -: 8.5.2.2
NVIDIA GPU Driver Version -: NVIDIA RTX A4000
Issue Type -: when we run our deepstream test app on h264 camera, its running but when we run on h265 it shows green screen. We can run both h264 and h265 on ffplay. If we run the gstreamer command (gst-launch-1.0 rtspsrc location=rtsp:// latency=0 drop-on-latency=true rtsp-keep-alive=true protocols=tcp ! rtph265depay ! h265parse ! nvv4l2decoder ! nvvideoconvert ! nveglglessink sync=false ) then also it is working.
How to reproduce the issue -: run h265 camera on deepstream test 3 app.
could you share more logs? please do “export GST_DEBUG=6” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
0:00:02.273019086 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4180:gst_pad_peer_query:udpsrc1:src peer query 0x7f31cc006140 (caps)
0:00:02.273027531 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.273028814 40126 0x7f31d8007760 DEBUG baseparse gstbaseparse.c:1587:gst_base_parse_sink_query: accept-caps query
0:00:02.273034084 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001202
0:00:02.273041959 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3815:do_probe_callbacks:udpsrc1:src data is passed
0:00:02.273047138 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.273042039 40126 0x7f31d8007760 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31bc0765a0, idx 0, length -1, flags 0001
0:00:02.273052459 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001200
0:00:02.273057989 40126 0x7f31d8007760 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31bc0765a0, idx 0, length 1
0:00:02.273063189 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:manager:recv_rtp_sink_0 doing query 0x7f31cc006140 (caps)
0:00:02.273080572 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:3182:gst_pad_query_caps_default:manager:recv_rtp_sink_0 query caps caps query: 0x7f31cc006140, GstQueryCaps, filter=(GstCaps)“application/x-rtp,\ media=(string)video,\ payload=(int)96,\ clock-rate=(int)90000,\ encoding-name=(string)H265,\ a-tool=(string)"LIVE555\\ Streaming\\ Media\\ v2022.04.26",\ a-type=(string)broadcast,\ x-qt-text-nam=(string)"Session\\ streamed\\ by\\ \"rtspd\"",\ x-qt-text-inf=(string)standard,\ clock-base=(uint)2735626719,\ seqnum-base=(uint)4864,\ npt-start=(guint64)53632000000,\ play-speed=(double)1,\ play-scale=(double)1”, caps=(GstCaps)“NULL”;
0:00:02.273082074 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:3129:gst_pad_query_accept_caps_default:h265parse0:sink query accept-caps accept-caps query: 0x7f31bc05f2d0, GstQueryAcceptCaps, caps=(GstCaps)“video/x-h265,\ stream-format=(string)hvc1,\ alignment=(string)au,\ codec_data=(buffer)01420101016000000300800000f000fcfdfffa00000f03200001001740010c01ffff016000000300800000030000030078ac09210001003e420101016000000300800000030000030078a0020080241fe36bbb5377725d602dc040404100000303e800005dc0721dee510049200149900249000a4c88220001000a4401c172b09c2c5f19c9”, result=(boolean)false;
0:00:02.273087204 40126 0x7f31e801d300 DEBUG GST_PADS gstutils.c:2806:gst_pad_proxy_query_caps:manager:recv_rtp_sink_0 proxying caps query for manager:recv_rtp_sink_0
0:00:02.273095450 40126 0x7f31d8007760 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31bc0765a0, idx 0, length -1, flags 0001
0:00:02.273098425 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3006:gst_pad_forward:manager:recv_rtp_sink_0 calling forward function on pad recv_rtp_sink_0:proxypad1
0:00:02.273100339 40126 0x7f31d8007760 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31bc0765a0, idx 0, length 1
0:00:02.273104487 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4180:gst_pad_peer_query:<recv_rtp_sink_0:proxypad1> peer query 0x7f31cc006140 (caps)
0:00:02.273113223 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:rtpsession0:recv_rtp_sink doing query 0x7f31cc006140 (caps)
0:00:02.273120066 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:3154:gst_pad_query_accept_caps_default:h265parse0:sink allowed caps intersect video/x-h265, caps video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101016000000300800000f000fcfdfffa00000f03200001001740010c01ffff016000000300800000030000030078ac09210001003e420101016000000300800000030000030078a0020080241fe36bbb5377725d602dc040404100000303e800005dc0721dee510049200149900249000a4c88220001000a4401c172b09c2c5f19c9
0:00:02.273123012 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:3182:gst_pad_query_caps_default:rtpsession0:recv_rtp_sink query caps caps query: 0x7f31cc006140, GstQueryCaps, filter=(GstCaps)“application/x-rtp,\ media=(string)video,\ payload=(int)96,\ clock-rate=(int)90000,\ encoding-name=(string)H265,\ a-tool=(string)"LIVE555\\ Streaming\\ Media\\ v2022.04.26",\ a-type=(string)broadcast,\ x-qt-text-nam=(string)"Session\\ streamed\\ by\\ \"rtspd\"",\ x-qt-text-inf=(string)standard,\ clock-base=(uint)2735626719,\ seqnum-base=(uint)4864,\ npt-start=(guint64)53632000000,\ play-speed=(double)1,\ play-scale=(double)1”, caps=(GstCaps)“NULL”;
0:00:02.273128432 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:h265parse0:sink not forwarding 0x7f31bc05f2d0 (accept-caps) query
0:00:02.273132229 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:3206:gst_pad_query_caps_default:rtpsession0:recv_rtp_sink trying pad template caps
0:00:02.273139032 40126 0x7f31d8007760 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31bc0765a0, idx 0, length -1, flags 0001
0:00:02.273145714 40126 0x7f31d8007760 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31bc0765a0, idx 0, length 1
0:00:02.273151866 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:3228:gst_pad_query_caps_default:rtpsession0:recv_rtp_sink using caps 0x7f31e800c400 application/x-rtp with filter 0x7f31e8041630 application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273162636 40126 0x7f31d8007760 LOG baseparse gstbaseparse.c:1594:gst_base_parse_sink_query: accept-caps query result: 1 accept-caps query: 0x7f31bc05f2d0, GstQueryAcceptCaps, caps=(GstCaps)“video/x-h265,\ stream-format=(string)hvc1,\ alignment=(string)au,\ codec_data=(buffer)01420101016000000300800000f000fcfdfffa00000f03200001001740010c01ffff016000000300800000030000030078ac09210001003e420101016000000300800000030000030078a0020080241fe36bbb5377725d602dc040404100000303e800005dc0721dee510049200149900249000a4c88220001000a4401c172b09c2c5f19c9”, result=(boolean)true;
0:00:02.273162746 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:3232:gst_pad_query_caps_default:rtpsession0:recv_rtp_sink result 0x7f31cc0061e0 application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273169369 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:h265parse0:sink sent query 0x7f31bc05f2d0 (accept-caps), result 1
0:00:02.273174619 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:rtpsession0:recv_rtp_sink not forwarding 0x7f31cc006140 (caps) query
0:00:02.273179448 40126 0x7f31d8007760 DEBUG default gstutils.c:3146:gst_pad_query_accept_caps:h265parse0:sink query returned 1
0:00:02.273184908 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:rtpsession0:recv_rtp_sink sent query 0x7f31cc006140 (caps), result 1
0:00:02.273190609 40126 0x7f31d8007760 LOG decodebin gstdecodebin2.c:2372:connect_pad: linked on pad rtph265depay0:src
0:00:02.273198344 40126 0x7f31e801d300 DEBUG default gstutils.c:2769:query_caps_func:<recv_rtp_sink_0:proxypad1> intersect with result application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273200187 40126 0x7f31d8007760 LOG decodebin gstdecodebin2.c:2374:connect_pad: locking chain 0x7f31bc012d50 from thread 0x7f31d8007760
0:00:02.273209625 40126 0x7f31d8007760 LOG decodebin gstdecodebin2.c:2374:connect_pad: locked chain 0x7f31bc012d50 from thread 0x7f31d8007760
0:00:02.273210697 40126 0x7f31e801d300 DEBUG default gstutils.c:2771:query_caps_func:<recv_rtp_sink_0:proxypad1> intersected application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273217951 40126 0x7f31d8007760 LOG decodebin gstdecodebin2.c:2419:connect_pad: unlocking chain 0x7f31bc012d50 from thread 0x7f31d8007760
0:00:02.273226256 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:manager:recv_rtp_sink_0 not forwarding 0x7f31cc006140 (caps) query
0:00:02.273228881 40126 0x7f31d8007760 DEBUG decodebin gstdecodebin2.c:2681:connect_element: Attempting to connect element h265parse0 [chain:0x7f31bc012d50] further
0:00:02.273234141 40126 0x7f31d8007760 DEBUG decodebin gstdecodebin2.c:2695:connect_element: got a source pad template src
0:00:02.273239932 40126 0x7f31d8007760 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad h265parse0:src
0:00:02.273241385 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:manager:recv_rtp_sink_0 sent query 0x7f31cc006140 (caps), result 1
0:00:02.273246775 40126 0x7f31d8007760 DEBUG decodebin gstdecodebin2.c:2705:connect_element: got the pad for always template src
0:00:02.273254169 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.273260341 40126 0x7f31d8007760 DEBUG GST_CAPS gstpad.c:2732:gst_pad_get_current_caps:h265parse0:src get current pad caps (NULL)
0:00:02.273265761 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00002200
0:00:02.273270680 40126 0x7f31d8007760 DEBUG GST_CAPS gstutils.c:3057:gst_pad_query_caps:h265parse0:src get pad caps with filter (NULL)
0:00:02.273278855 40126 0x7f31e801d300 DEBUG GST_CAPS gstutils.c:3110:gst_pad_peer_query_caps:udpsrc1:src peer query returned application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273281841 40126 0x7f31d8007760 DEBUG query gstquery.c:679:gst_query_new_custom: creating new query 0x7f31bc05f1e0 caps
0:00:02.273288974 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3324:gst_base_src_default_negotiate: caps of peer: application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273291619 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:h265parse0:src doing query 0x7f31bc05f1e0 (caps)
0:00:02.273298412 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3335:gst_base_src_default_negotiate: have caps: application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273301859 40126 0x7f31d8007760 DEBUG baseparse gstbaseparse.c:1610:gst_base_parse_src_query: caps query: caps query: 0x7f31bc05f1e0, GstQueryCaps, filter=(GstCaps)“NULL”, caps=(GstCaps)“NULL”;
0:00:02.273302911 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:993:gst_base_src_default_fixate: using default caps fixate function
0:00:02.273308391 40126 0x7f31d8007760 DEBUG GST_CAPS gstpad.c:3182:gst_pad_query_caps_default:h265parse0:src query caps caps query: 0x7f31bc05f1e0, GstQueryCaps, filter=(GstCaps)“NULL”, caps=(GstCaps)“NULL”;
0:00:02.273314743 40126 0x7f31d8007760 DEBUG GST_CAPS gstpad.c:3200:gst_pad_query_caps_default:h265parse0:src fixed pad caps: trying pad caps
0:00:02.273319181 40126 0x7f31d8007760 DEBUG GST_CAPS gstpad.c:3206:gst_pad_query_caps_default:h265parse0:src trying pad template caps
0:00:02.273319973 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3343:gst_base_src_default_negotiate: fixated to: application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273326385 40126 0x7f31d8007760 DEBUG GST_CAPS gstpad.c:3235:gst_pad_query_caps_default:h265parse0:src using caps 0x7f31bc05f400 video/x-h265, parsed=(boolean)true, stream-format=(string){ hvc1, hev1, byte-stream }, alignment=(string){ au, nal }
0:00:02.273333709 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:2732:gst_pad_get_current_caps:udpsrc1:src get current pad caps application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273336133 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:h265parse0:src not forwarding 0x7f31bc05f1e0 (caps) query
0:00:02.273343728 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:946:gst_base_src_set_caps: New caps equal to old ones: application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273347835 40126 0x7f31d8007760 LOG baseparse gstbaseparse.c:1618:gst_base_parse_src_query: caps query result: 1 caps query: 0x7f31bc05f1e0, GstQueryCaps, filter=(GstCaps)“NULL”, caps=(GstCaps)“video/x-h265,\ parsed=(boolean)true,\ stream-format=(string){\ hvc1,\ hev1,\ byte-stream\ },\ alignment=(string){\ au,\ nal\ }”;
0:00:02.273352685 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:h265parse0:src sent query 0x7f31bc05f1e0 (caps), result 1
0:00:02.273353115 40126 0x7f31e801d300 DEBUG GST_CAPS gstpad.c:2732:gst_pad_get_current_caps:udpsrc1:src get current pad caps application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, a-tool=(string)“LIVE555\ Streaming\ Media\ v2022.04.26”, a-type=(string)broadcast, x-qt-text-nam=(string)“Session\ streamed\ by\ "rtspd"”, x-qt-text-inf=(string)standard, clock-base=(uint)2735626719, seqnum-base=(uint)4864, npt-start=(guint64)53632000000, play-speed=(double)1, play-scale=(double)1
0:00:02.273359027 40126 0x7f31d8007760 DEBUG GST_CAPS gstutils.c:3064:gst_pad_query_caps:h265parse0:src query returned video/x-h265, parsed=(boolean)true, stream-format=(string){ hvc1, hev1, byte-stream }, alignment=(string){ au, nal }
0:00:02.273364046 40126 0x7f31e801d300 DEBUG query gstquery.c:679:gst_query_new_custom: creating new query 0x7f31c4005850 allocation
0:00:02.273370508 40126 0x7f31d8007760 DEBUG decodebin gstdecodebin2.c:1523:analyze_new_pad: Pad h265parse0:src caps:video/x-h265, parsed=(boolean)true, stream-format=(string){ hvc1, hev1, byte-stream }, alignment=(string){ au, nal }
0:00:02.273377602 40126 0x7f31d8007760 DEBUG GST_PADS gstpad.c:1104:gst_pad_set_active:<‘’:decodepad0> pad was active in push mode
0:00:02.273378614 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4180:gst_pad_peer_query:udpsrc1:src peer query 0x7f31c4005850 (allocation)
0:00:02.273384004 40126 0x7f31d8007760 DEBUG GST_PADS gstghostpad.c:848:gst_ghost_pad_set_target:<‘’:decodepad0> set target h265parse0:src
0:00:02.273390676 40126 0x7f31d8007760 DEBUG GST_PADS gstghostpad.c:869:gst_ghost_pad_set_target:<‘’:decodepad0> connecting internal pad to target h265parse0:src
0:00:02.273391668 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.273397990 40126 0x7f31d8007760 LOG GST_MESSAGE gstmessage.c:303:gst_message_new_custom: source proxypad7: creating new message 0x55ee300f1eb0 structure-change
0:00:02.273406907 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001202
0:00:02.273408059 40126 0x7f31d8007760 DEBUG GST_BUS gstbus.c:340:gst_bus_post: [msg 0x55ee300f1eb0] posting on bus structure-change message: 0x55ee300f1eb0, time 99:99:99.999999999, seq-num 328, element ‘proxypad7’, GstMessageStructureChange, type=(GstStructureChangeType)GST_STRUCTURE_CHANGE_TYPE_PAD_LINK, owner=(GstElement)“(GstH265Parse)\ h265parse0”, busy=(boolean)true;
0:00:02.273412417 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3815:do_probe_callbacks:udpsrc1:src data is passed
0:00:02.273421084 40126 0x7f31d8007760 DEBUG decodebin gstdecodebin2.c:5627:gst_decode_bin_handle_message: Forwarding msg structure-change message: 0x55ee300f1eb0, time 99:99:99.999999999, seq-num 328, element ‘proxypad7’, GstMessageStructureChange, type=(GstStructureChangeType)GST_STRUCTURE_CHANGE_TYPE_PAD_LINK, owner=(GstElement)“(GstH265Parse)\ h265parse0”, busy=(boolean)true;
0:00:02.273422055 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.273428427 40126 0x7f31d8007760 DEBUG bin gstbin.c:3718:gst_bin_handle_message_func: [msg 0x55ee300f1eb0] handling child proxypad7 message of type structure-change
0:00:02.273434178 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001200
0:00:02.273438587 40126 0x7f31d8007760 LOG bin gstbin.c:860:message_check: looking at message 0x7f31c0025e20: 0
0:00:02.273443947 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:manager:recv_rtp_sink_0 doing query 0x7f31c4005850 (allocation)
0:00:02.273448405 40126 0x7f31d8007760 DEBUG bin gstbin.c:882:find_message: no message found matching types 00001000
0:00:02.273453855 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:manager:recv_rtp_sink_0 forwarding 0x7f31c4005850 (allocation) query
0:00:02.273457933 40126 0x7f31d8007760 DEBUG bin gstbin.c:889:find_message: structure-change
0:00:02.273463484 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3006:gst_pad_forward:manager:recv_rtp_sink_0 calling forward function on pad recv_rtp_sink_0:proxypad1
0:00:02.273468182 40126 0x7f31d8007760 DEBUG bin gstbin.c:928:bin_replace_message: got new message 0x55ee300f1eb0, structure-change from proxypad7
0:00:02.273472811 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3373:query_forward_func:<recv_rtp_sink_0:proxypad1> query peer 0x7f31c4005850 (allocation) of recv_rtp_sink_0:proxypad1
0:00:02.273477189 40126 0x7f31d8007760 DEBUG GST_BUS gstbus.c:379:gst_bus_post: [msg 0x55ee300f1eb0] dropped
0:00:02.273482459 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4180:gst_pad_peer_query:<recv_rtp_sink_0:proxypad1> peer query 0x7f31c4005850 (allocation)
0:00:02.273487539 40126 0x7f31d8007760 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link h265parse0:src and decodepad0:proxypad7
0:00:02.273491927 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:rtpsession0:recv_rtp_sink doing query 0x7f31c4005850 (allocation)
0:00:02.273499752 40126 0x7f31d8007760 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked h265parse0:src and decodepad0:proxypad7, successful
0:00:02.273508629 40126 0x7f31d8007760 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:02.273504220 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:rtpsession0:recv_rtp_sink forwarding 0x7f31c4005850 (allocation) query
0:00:02.273514390 40126 0x7f31d8007760 DEBUG GST_EVENT gstevent.c:308:gst_event_new_custom: creating new event 0x7f31bc0104e0 reconfigure 61441
0:00:02.273519419 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3006:gst_pad_forward:rtpsession0:recv_rtp_sink calling forward function on pad rtpsession0:recv_rtp_src
0:00:02.273524889 40126 0x7f31d8007760 DEBUG GST_EVENT gstpad.c:5697:gst_pad_send_event_unchecked:h265parse0:src have event type reconfigure event: 0x7f31bc0104e0, time 99:99:99.999999999, seq-num 329, (NULL)
0:00:02.273531161 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3373:query_forward_func:rtpsession0:recv_rtp_src query peer 0x7f31c4005850 (allocation) of rtpsession0:recv_rtp_src
0:00:02.273535299 40126 0x7f31d8007760 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:h265parse0:src Received event on flushing pad. Discarding
0:00:02.273541561 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4180:gst_pad_peer_query:rtpsession0:recv_rtp_src peer query 0x7f31c4005850 (allocation)
0:00:02.273545859 40126 0x7f31d8007760 LOG GST_EVENT gstevent.c:222:_gst_event_free: freeing event 0x7f31bc0104e0 type reconfigure
0:00:02.273550858 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:rtpstorage0:sink doing query 0x7f31c4005850 (allocation)
0:00:02.273556759 40126 0x7f31d8007760 LOG GST_MESSAGE gstmessage.c:303:gst_message_new_custom: source proxypad7: creating new message 0x7f31e8052490 structure-change
0:00:02.273561238 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:rtpstorage0:sink forwarding 0x7f31c4005850 (allocation) query
0:00:02.273568472 40126 0x7f31d8007760 DEBUG GST_BUS gstbus.c:340:gst_bus_post: [msg 0x7f31e8052490] posting on bus structure-change message: 0x7f31e8052490, time 99:99:99.999999999, seq-num 330, element ‘proxypad7’, GstMessageStructureChange, type=(GstStructureChangeType)GST_STRUCTURE_CHANGE_TYPE_PAD_LINK, owner=(GstElement)“(GstH265Parse)\ h265parse0”, busy=(boolean)false;
0:00:02.273568952 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:2897:gst_pad_iterate_internal_links_default:rtpstorage0:sink Making iterator
0:00:02.273576617 40126 0x7f31d8007760 DEBUG decodebin gstdecodebin2.c:5627:gst_decode_bin_handle_message: Forwarding msg structure-change message: 0x7f31e8052490, time 99:99:99.999999999, seq-num 330, element ‘proxypad7’, GstMessageStructureChange, type=(GstStructureChangeType)GST_STRUCTURE_CHANGE_TYPE_PAD_LINK, owner=(GstElement)“(GstH265Parse)\ h265parse0”, busy=(boolean)false;
0:00:02.273578350 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3006:gst_pad_forward:rtpstorage0:sink calling forward function on pad rtpstorage0:src
0:00:02.273587628 40126 0x7f31e801d300 LOG GST_PADS gstpad.c:3373:query_forward_func:rtpstorage0:src query peer 0x7f31c4005850 (allocation) of rtpstorage0:src
0:00:02.273583470 40126 0x7f31d8007760 DEBUG bin gstbin.c:3718:gst_bin_handle_message_func: [msg 0x7f31e8052490] handling child proxypad7 message of type structure-change
0:00:02.273592276 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4180:gst_pad_peer_query:rtpstorage0:src peer query 0x7f31c4005850 (allocation)
0:00:02.273596905 40126 0x7f31d8007760 LOG bin gstbin.c:860:message_check: looking at message 0x55ee300f1eb0: 1
0:00:02.273601113 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4053:gst_pad_query:rtpssrcdemux0:sink doing query 0x7f31c4005850 (allocation)
0:00:02.273606113 40126 0x7f31d8007760 DEBUG bin gstbin.c:956:bin_remove_messages:decodepad0:proxypad7 deleting message 0x55ee300f1eb0 of type structure-change (types 0x00001000)
0:00:02.273612575 40126 0x7f31d8007760 LOG GST_MESSAGE gstmessage.c:208:_gst_message_free: finalize message 0x55ee300f1eb0, structure-change from proxypad7
0:00:02.273614238 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3437:gst_pad_query_default:rtpssrcdemux0:sink not forwarding 0x7f31c4005850 (allocation) query
0:00:02.273618366 40126 0x7f31d8007760 LOG bin gstbin.c:860:message_check: looking at message 0x7f31c0025e20: 0
0:00:02.273623315 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:rtpssrcdemux0:sink sent query 0x7f31c4005850 (allocation), result 0
0:00:02.273628234 40126 0x7f31d8007760 DEBUG bin gstbin.c:962:bin_remove_messages: not deleting message 0x7f31c0025e20 of type 0x00100000
0:00:02.273632703 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4122:gst_pad_query:rtpssrcdemux0:sink query failed
0:00:02.273647961 40126 0x7f31d8007760 LOG GST_MESSAGE gstmessage.c:208:_gst_message_free: finalize message 0x7f31e8052490, structure-change from proxypad7
0:00:02.273654905 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4243:gst_pad_peer_query:rtpstorage0:src query failed
0:00:02.273659994 40126 0x7f31d8007760 DEBUG GST_BUS gstbus.c:379:gst_bus_post: [msg 0x7f31e8052490] dropped
0:00:02.273665945 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:rtpstorage0:sink sent query 0x7f31c4005850 (allocation), result 0
0:00:02.273672267 40126 0x7f31d8007760 LOG decodebin gstdecodebin2.c:3222:are_final_caps: Checking with caps video/x-h265, parsed=(boolean)true, stream-format=(string){ hvc1, hev1, byte-stream }, alignment=(string){ au, nal }
0:00:02.273675724 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4122:gst_pad_query:rtpstorage0:sink query failed
0:00:02.273681465 40126 0x7f31d8007760 LOG decodebin gstdecodebin2.c:3229:are_final_caps: Caps are not final caps
0:00:02.273685232 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4243:gst_pad_peer_query:rtpsession0:recv_rtp_src query failed
0:00:02.273695331 40126 0x7f31d8007760 DEBUG uridecodebin gsturidecodebin.c:336:gst_uri_decode_bin_autoplug_factories: finding factories
0:00:02.273696273 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:rtpsession0:recv_rtp_sink sent query 0x7f31c4005850 (allocation), result 0
0:00:02.273701222 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:840:gst_element_factory_list_filter: finding factories
0:00:02.273705370 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4122:gst_pad_query:rtpsession0:recv_rtp_sink query failed
0:00:02.273712373 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mpegaudioparse
0:00:02.273717052 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4243:gst_pad_peer_query:<recv_rtp_sink_0:proxypad1> query failed
0:00:02.273722903 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying aacparse
0:00:02.273726760 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4076:gst_pad_query:manager:recv_rtp_sink_0 sent query 0x7f31c4005850 (allocation), result 0
0:00:02.273738642 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying ac3parse
0:00:02.273740306 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4122:gst_pad_query:manager:recv_rtp_sink_0 query failed
0:00:02.273745966 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying amrparse
0:00:02.273750124 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:4243:gst_pad_peer_query:udpsrc1:src query failed
0:00:02.273758510 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying dcaparse
0:00:02.273759181 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3254:gst_base_src_prepare_allocation: peer ALLOCATION query failed
0:00:02.273764842 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying flacparse
0:00:02.273771625 40126 0x7f31e801d300 DEBUG GST_POLL gstpoll.c:681:gst_poll_new: 0x7f31c40058a0: new controllable : 1
0:00:02.273773568 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying h263parse
0:00:02.273784078 40126 0x7f31e801d300 DEBUG GST_POLL gstpoll.c:848:gst_poll_add_fd_unlocked: 0x7f31c40058a0: fd (fd:76, idx:0)
0:00:02.273784980 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying h264parse
0:00:02.273789709 40126 0x7f31e801d300 DEBUG GST_POLL gstpoll.c:1014:gst_poll_fd_ctl_read_unlocked: 0x7f31c40058a0: fd (fd:76, idx:0), active : 1
0:00:02.273797183 40126 0x7f31e801d300 LOG GST_POLL gstpoll.c:290:raise_wakeup: 0x7f31c40058a0: raise
0:00:02.273797924 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mpeg4videoparse
0:00:02.273804567 40126 0x7f31e801d300 DEBUG bufferpool gstbufferpool.c:180:gst_buffer_pool_init:GstBufferPool@0x7f31c4038ab0 created
0:00:02.273806540 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mpegvideoparse
0:00:02.273812672 40126 0x7f31e801d300 DEBUG bufferpool gstbufferpool.c:218:gst_buffer_pool_new: created new buffer pool
0:00:02.273821929 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying sbcparse
0:00:02.273826668 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying wavpackparse
0:00:02.273828782 40126 0x7f31e801d300 WARN structure gststructure.c:1861:priv_gst_structure_append_to_gstring: No value transform to serialize field ‘params’ of type ‘GstAllocationParams’
0:00:02.273835144 40126 0x7f31e801d300 DEBUG bufferpool gstbufferpool.c:609:default_set_config: config GstBufferPoolConfig, caps=(GstCaps)“application/x-rtp,\ media=(string)video,\ payload=(int)96,\ clock-rate=(int)90000,\ encoding-name=(string)H265,\ a-tool=(string)"LIVE555\\ Streaming\\ Media\\ v2022.04.26",\ a-type=(string)broadcast,\ x-qt-text-nam=(string)"Session\\ streamed\\ by\\ \"rtspd\"",\ x-qt-text-inf=(string)standard,\ clock-base=(uint)2735626719,\ seqnum-base=(uint)4864,\ npt-start=(guint64)53632000000,\ play-speed=(double)1,\ play-scale=(double)1”, size=(uint)1492, min-buffers=(uint)0, max-buffers=(uint)0, allocator=(GstAllocator)“NULL”, params=(GstAllocationParams)NULL;
0:00:02.273831077 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avisubtitle
0:00:02.273845464 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying jpeg2000parse
0:00:02.273847177 40126 0x7f31e801d300 WARN structure gststructure.c:1861:priv_gst_structure_append_to_gstring: No value transform to serialize field ‘pool’ of type ‘GArray’
0:00:02.273854421 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3260:gst_base_src_prepare_allocation: ALLOCATION (1) params: allocation query: 0x7f31c4005850, GstQueryAllocation, caps=(GstCaps)“application/x-rtp,\ media=(string)video,\ payload=(int)96,\ clock-rate=(int)90000,\ encoding-name=(string)H265,\ a-tool=(string)"LIVE555\\ Streaming\\ Media\\ v2022.04.26",\ a-type=(string)broadcast,\ x-qt-text-nam=(string)"Session\\ streamed\\ by\\ \"rtspd\"",\ x-qt-text-inf=(string)standard,\ clock-base=(uint)2735626719,\ seqnum-base=(uint)4864,\ npt-start=(guint64)53632000000,\ play-speed=(double)1,\ play-scale=(double)1”, need-pool=(boolean)true, pool=(GArray)NULL;
0:00:02.273860703 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3088:gst_base_src_set_allocation: activate pool
0:00:02.273856014 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying oggaviparse
0:00:02.273864610 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:501:gst_buffer_pool_set_active: active 1
0:00:02.273876222 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:354:do_start: starting
0:00:02.273871643 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying ogmaudioparse
0:00:02.273881041 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:3114:gst_base_src_set_allocation: deactivate old pool
0:00:02.273887643 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying ogmvideoparse
0:00:02.273892543 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:501:gst_buffer_pool_set_active: active 0
0:00:02.273897562 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying pngparse
0:00:02.273902832 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:533:gst_buffer_pool_set_active: outstanding buffers 4
0:00:02.273907882 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying ssaparse
0:00:02.273914324 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2842:gst_base_src_loop: next_ts 99:99:99.999999999 size 4096
0:00:02.273918752 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying subparse
0:00:02.273923952 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2519:gst_base_src_get_range: calling create offset 18446744073709551615 length 4096, time 0
0:00:02.273928621 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying h265parse
0:00:02.273932899 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:1128:default_acquire_buffer: no buffer, trying to allocate
0:00:02.273943338 40126 0x7f31e801d300 DEBUG GST_MEMORY gstmemory.c:138:gst_memory_init: new memory 0x7f31c403bd80, maxsize:1499 offset:0 size:1492
0:00:02.273947025 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:844:gst_buffer_new: new 0x7f31c4038b40
0:00:02.273938349 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying unalignedaudioparse
0:00:02.273952656 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:450:_memory_add: buffer 0x7f31c4038b40, idx -1, mem 0x7f31c403bd80
0:00:02.273957766 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying unalignedvideoparse
0:00:02.273961062 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:898:gst_buffer_new_allocate: new buffer 0x7f31c4038b40 of size 1492 from allocator (nil)
0:00:02.273966622 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying nvjpegdec
0:00:02.273971391 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:286:do_alloc_buffer: allocated buffer 0/0, 0x7f31c4038b40
0:00:02.273975910 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying nvv4l2decoder
0:00:02.273980999 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038b40, idx 0, length -1, flags 0003
0:00:02.273987371 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038b40, idx 0, length 1
0:00:02.273991349 40126 0x7f31e801d300 LOG udpsrc gstudpsrc.c:875:gst_udpsrc_fill: doing select, timeout -1
0:00:02.273993503 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying openmptdec
0:00:02.273998372 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1656:gst_buffer_resize_range: trim 0x7f31c4038b40 0-1452 size:1492 offs:0 max:1499
0:00:02.273998803 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying adpcmdec
0:00:02.274004133 40126 0x7f31e801d300 DEBUG GST_BUFFER gstbuffer.c:2282:gst_buffer_add_meta: alloc metadata 0x7f31c4036cd0 (GstNetAddressMeta) of size 24
0:00:02.274019001 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying aiffparse
0:00:02.274023229 40126 0x7f31e801d300 LOG udpsrc gstudpsrc.c:993:gst_udpsrc_fill: read packet of 1452 bytes
0:00:02.274027667 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying alawdec
0:00:02.274033458 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1091:gst_clock_get_internal_time: internal time 182:52:59.537928364
0:00:02.274048797 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying amrnbdec
0:00:02.274054939 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1136:gst_clock_get_time: adjusted time 182:52:59.537928364
0:00:02.274059277 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying amrwbdec
0:00:02.274064517 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2326:gst_base_src_do_sync: created DTS 0:00:00.335916836
0:00:02.274069045 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying apedemux
0:00:02.274074205 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2336:gst_base_src_do_sync: created PTS 0:00:00.335916836
0:00:02.274079235 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying av1dec
0:00:02.274083252 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2375:gst_base_src_do_sync: no sync needed
0:00:02.274088322 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_aac
0:00:02.274092470 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2612:gst_base_src_get_range: buffer ok
0:00:02.274097689 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_aac_fixed
0:00:02.274102108 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.274107578 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_cook
0:00:02.274113249 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001012
0:00:02.274117918 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_h264
0:00:02.274122627 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3815:do_probe_callbacks:udpsrc1:src data is passed
0:00:02.274131453 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.274127576 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_h265
0:00:02.274135371 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001010
0:00:02.274138496 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_mpeg2video
0:00:02.274142073 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:manager:recv_rtp_sink_0 calling chainfunction &gst_proxy_pad_chain_default with buffer buffer: 0x7f31c4038b40, pts 0:00:00.335916836, dts 0:00:00.335916836, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274143486 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_mpeg4
0:00:02.274150369 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpsession0:recv_rtp_sink calling chainfunction &gst_rtp_session_chain_recv_rtp with buffer buffer: 0x7f31c4038b40, pts 0:00:00.335916836, dts 0:00:00.335916836, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274156290 40126 0x7f31e801d300 LOG rtpsession gstrtpsession.c:1945:gst_rtp_session_chain_recv_rtp: received RTP packet
0:00:02.274158414 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_mpegvideo
0:00:02.274161229 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1091:gst_clock_get_internal_time: internal time 182:52:59.538056516
0:00:02.274162852 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_msmpeg4
0:00:02.274167000 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1136:gst_clock_get_time: adjusted time 182:52:59.538056516
0:00:02.274172140 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_real_144
0:00:02.274177951 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038b40, idx 0, length 1, flags 0001
0:00:02.274189322 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_real_288
0:00:02.274193600 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038b40, idx 0, length 1
0:00:02.274198470 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_rv10
0:00:02.274204721 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:1194:update_receiver_stats: seq 4921, PC: 58, OC: 68919
0:00:02.274215652 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:968:calculate_jitter: SSRC 634dd09f got payload 96
0:00:02.274218648 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_rv20
0:00:02.274221994 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:1000:calculate_jitter: rtparrival 30232, rtptime 2735651471, clock-rate 90000, diff 151, jitter: 66.000000
0:00:02.274224218 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_rv30
0:00:02.274225400 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:909:push_packet: pushing new packet
0:00:02.274235219 40126 0x7f31e801d300 LOG rtpsession rtpsession.c:1506:source_push_rtp: source 634dd09f pushed receiver RTP packet
0:00:02.274238365 40126 0x7f31e801d300 LOG rtpsession gstrtpsession.c:1345:gst_rtp_session_process_rtp: pushing received RTP packet
0:00:02.274230600 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_rv40
0:00:02.274244296 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpstorage0:sink calling chainfunction &gst_rtp_storage_chain with buffer buffer: 0x7f31c4038b40, pts 0:00:00.335916836, dts 0:00:00.335916836, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274252000 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpssrcdemux0:sink calling chainfunction &gst_rtp_ssrc_demux_chain with buffer buffer: 0x7f31c4038b40, pts 0:00:00.335916836, dts 0:00:00.335916836, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274245318 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avidemux
0:00:02.274257250 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038b40, idx 0, length 1, flags 0001
0:00:02.274263262 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying dashdemux
0:00:02.274267991 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038b40, idx 0, length 1
0:00:02.274274022 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying dtsdec
0:00:02.274278380 40126 0x7f31e801d300 DEBUG rtpssrcdemux gstrtpssrcdemux.c:611:gst_rtp_ssrc_demux_chain: received buffer of SSRC 634dd09f
0:00:02.274283269 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying dvdemux
0:00:02.274289852 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpjitterbuffer0:sink calling chainfunction &gst_rtp_jitter_buffer_chain with buffer buffer: 0x7f31c4038b40, pts 0:00:00.335916836, dts 0:00:00.335916836, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274303377 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying dvdlpcmdec
0:00:02.274309389 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038b40, idx 0, length 1, flags 0001
0:00:02.274313767 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying flacdec
0:00:02.274318736 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038b40, idx 0, length 1
0:00:02.274324647 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying flvdemux
0:00:02.274330809 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:2983:gst_rtp_jitter_buffer_chain: Received packet #4921 at time 0:00:00.335916836, discont 0, rtx 0
0:00:02.274339546 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying flxdec
0:00:02.274339916 40126 0x7f31e801d300 LOG rtpjitterbuffer gstrtpjitterbuffer.c:2687:calculate_jitter: dtsdiff 0:00:00.001675840 rtptime 0:00:00.000000000, clock-rate 90000, diff 0:00:00.001675840, jitter: 0:00:00.000732763
0:00:02.274345106 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying gmedec
0:00:02.274350807 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:3083:gst_rtp_jitter_buffer_chain: expected #4921, got #4921, gap of 0
0:00:02.274361236 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:3113:gst_rtp_jitter_buffer_chain: Clearing gap packets
0:00:02.274356888 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying gsmdec
0:00:02.274367578 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:3268:gst_rtp_jitter_buffer_chain: Pushed packet #4921, now 21 packets, head: 0, percent -1
0:00:02.274372077 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying hlsdemux
0:00:02.274377146 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpjitterbuffer0:sink called chainfunction &gst_rtp_jitter_buffer_chain with buffer 0x7f31c4038b40, returned ok
0:00:02.274383128 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying icydemux
0:00:02.274389139 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpssrcdemux0:sink called chainfunction &gst_rtp_ssrc_demux_chain with buffer 0x7f31c4038b40, returned ok
0:00:02.274393938 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying id3demux
0:00:02.274399489 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpstorage0:sink called chainfunction &gst_rtp_storage_chain with buffer 0x7f31c4038b40, returned ok
0:00:02.274404969 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying ivfparse
0:00:02.274410680 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpsession0:recv_rtp_sink called chainfunction &gst_rtp_session_chain_recv_rtp with buffer 0x7f31c4038b40, returned ok
0:00:02.274414948 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying jpegdec
0:00:02.274420408 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:manager:recv_rtp_sink_0 called chainfunction &gst_proxy_pad_chain_default with buffer 0x7f31c4038b40, returned ok
0:00:02.274424686 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying katedec
0:00:02.274428503 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.274433823 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying matroskademux
0:00:02.274439013 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001001
0:00:02.274444103 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying midiparse
0:00:02.274449413 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2842:gst_base_src_loop: next_ts 99:99:99.999999999 size 4096
0:00:02.274455775 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2519:gst_base_src_get_range: calling create offset 18446744073709551615 length 4096, time 0
0:00:02.274457268 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying modplug
0:00:02.274460804 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:1128:default_acquire_buffer: no buffer, trying to allocate
0:00:02.274467306 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mpegpsdemux
0:00:02.274471795 40126 0x7f31e801d300 DEBUG GST_MEMORY gstmemory.c:138:gst_memory_init: new memory 0x7f31c403c400, maxsize:1499 offset:0 size:1492
0:00:02.274476303 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mssdemux
0:00:02.274481804 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:844:gst_buffer_new: new 0x7f31c4038c60
0:00:02.274486883 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mulawdec
0:00:02.274491572 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:450:_memory_add: buffer 0x7f31c4038c60, idx -1, mem 0x7f31c403c400
0:00:02.274495940 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying multipartdemux
0:00:02.274499898 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:898:gst_buffer_new_allocate: new buffer 0x7f31c4038c60 of size 1492 from allocator (nil)
0:00:02.274505008 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying musepackdec
0:00:02.274509746 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:286:do_alloc_buffer: allocated buffer 1/0, 0x7f31c4038c60
0:00:02.274514926 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mxfdemux
0:00:02.274521118 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038c60, idx 0, length -1, flags 0003
0:00:02.274525306 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying oggdemux
0:00:02.274529654 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038c60, idx 0, length 1
0:00:02.274534433 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying ogmtextparse
0:00:02.274538781 40126 0x7f31e801d300 LOG udpsrc gstudpsrc.c:875:gst_udpsrc_fill: doing select, timeout -1
0:00:02.274543751 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying openexrdec
0:00:02.274551355 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1656:gst_buffer_resize_range: trim 0x7f31c4038c60 0-1452 size:1492 offs:0 max:1499
0:00:02.274551976 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying openjpegdec
0:00:02.274557446 40126 0x7f31e801d300 DEBUG GST_BUFFER gstbuffer.c:2282:gst_buffer_add_meta: alloc metadata 0x7f31c40367a0 (GstNetAddressMeta) of size 24
0:00:02.274562296 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying opusdec
0:00:02.274566163 40126 0x7f31e801d300 LOG udpsrc gstudpsrc.c:993:gst_udpsrc_fill: read packet of 1452 bytes
0:00:02.274571102 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying pngdec
0:00:02.274575901 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1091:gst_clock_get_internal_time: internal time 182:52:59.538471048
0:00:02.274580300 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying pnmdec
0:00:02.274584838 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1136:gst_clock_get_time: adjusted time 182:52:59.538471048
0:00:02.274589697 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying qtdemux
0:00:02.274594376 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2326:gst_base_src_do_sync: created DTS 0:00:00.336459520
0:00:02.274598804 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rmdemux
0:00:02.274603624 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2336:gst_base_src_do_sync: created PTS 0:00:00.336459520
0:00:02.274613372 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2375:gst_base_src_do_sync: no sync needed
0:00:02.274618371 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2612:gst_base_src_get_range: buffer ok
0:00:02.274609495 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rsvgdec
0:00:02.274623070 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.274628480 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpopusdepay
0:00:02.274632778 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001012
0:00:02.274637778 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying sbcdec
0:00:02.274641385 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3815:do_probe_callbacks:udpsrc1:src data is passed
0:00:02.274647216 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying siddec
0:00:02.274650953 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.274657084 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying speexdec
0:00:02.274662605 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001010
0:00:02.274667354 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying theoradec
0:00:02.274673014 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:manager:recv_rtp_sink_0 calling chainfunction &gst_proxy_pad_chain_default with buffer buffer: 0x7f31c4038c60, pts 0:00:00.336459520, dts 0:00:00.336459520, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274675429 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying tsdemux
0:00:02.274679196 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpsession0:recv_rtp_sink calling chainfunction &gst_rtp_session_chain_recv_rtp with buffer buffer: 0x7f31c4038c60, pts 0:00:00.336459520, dts 0:00:00.336459520, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274681540 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying vmncdec
0:00:02.274685037 40126 0x7f31e801d300 LOG rtpsession gstrtpsession.c:1945:gst_rtp_session_chain_recv_rtp: received RTP packet
0:00:02.274690547 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying vorbisdec
0:00:02.274695377 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1091:gst_clock_get_internal_time: internal time 182:52:59.538590643
0:00:02.274699825 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying vp8dec
0:00:02.274704734 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1136:gst_clock_get_time: adjusted time 182:52:59.538590643
0:00:02.274709694 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying vp9dec
0:00:02.274714483 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038c60, idx 0, length 1, flags 0001
0:00:02.274718480 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying wavpackdec
0:00:02.274723520 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038c60, idx 0, length 1
0:00:02.274728629 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying wavparse
0:00:02.274734220 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:1194:update_receiver_stats: seq 4922, PC: 59, OC: 70359
0:00:02.274739430 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying webpdec
0:00:02.274743808 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:968:calculate_jitter: SSRC 634dd09f got payload 96
0:00:02.274748757 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying a52dec
0:00:02.274755209 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:1000:calculate_jitter: rtparrival 30281, rtptime 2735651471, clock-rate 90000, diff 49, jitter: 64.937500
0:00:02.274759898 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:909:push_packet: pushing new packet
0:00:02.274762864 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying asfdemux
0:00:02.274764026 40126 0x7f31e801d300 LOG rtpsession rtpsession.c:1506:source_push_rtp: source 634dd09f pushed receiver RTP packet
0:00:02.274769687 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying auparse
0:00:02.274774265 40126 0x7f31e801d300 LOG rtpsession gstrtpsession.c:1345:gst_rtp_session_process_rtp: pushing received RTP packet
0:00:02.274780427 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_dvvideo
0:00:02.274785997 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpstorage0:sink calling chainfunction &gst_rtp_storage_chain with buffer buffer: 0x7f31c4038c60, pts 0:00:00.336459520, dts 0:00:00.336459520, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274788592 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_sipr
0:00:02.274794714 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpssrcdemux0:sink calling chainfunction &gst_rtp_ssrc_demux_chain with buffer buffer: 0x7f31c4038c60, pts 0:00:00.336459520, dts 0:00:00.336459520, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274797199 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying faad
0:00:02.274801447 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038c60, idx 0, length 1, flags 0001
0:00:02.274805745 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying fluiddec
0:00:02.274810223 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038c60, idx 0, length 1
0:00:02.274815233 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying gdkpixbufdec
0:00:02.274819711 40126 0x7f31e801d300 DEBUG rtpssrcdemux gstrtpssrcdemux.c:611:gst_rtp_ssrc_demux_chain: received buffer of SSRC 634dd09f
0:00:02.274824640 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying libde265dec
0:00:02.274830832 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpjitterbuffer0:sink calling chainfunction &gst_rtp_jitter_buffer_chain with buffer buffer: 0x7f31c4038c60, pts 0:00:00.336459520, dts 0:00:00.336459520, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.274833838 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying mpeg2dec
0:00:02.274838136 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038c60, idx 0, length 1, flags 0001
0:00:02.274842905 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rademux
0:00:02.274847814 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038c60, idx 0, length 1
0:00:02.274852803 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpL16depay
0:00:02.274858795 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:2983:gst_rtp_jitter_buffer_chain: Received packet #4922 at time 0:00:00.336459520, discont 0, rtx 0
0:00:02.274862902 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpL24depay
0:00:02.274870657 40126 0x7f31e801d300 LOG rtpjitterbuffer gstrtpjitterbuffer.c:2687:calculate_jitter: dtsdiff 0:00:00.000542684 rtptime 0:00:00.000000000, clock-rate 90000, diff 0:00:00.000542684, jitter: 0:00:00.000720883
0:00:02.274872681 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpL8depay
0:00:02.274878452 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:3083:gst_rtp_jitter_buffer_chain: expected #4922, got #4922, gap of 0
0:00:02.274882560 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpac3depay
0:00:02.274887118 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:3113:gst_rtp_jitter_buffer_chain: Clearing gap packets
0:00:02.274892368 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpamrdepay
0:00:02.274897598 40126 0x7f31e801d300 DEBUG rtpjitterbuffer gstrtpjitterbuffer.c:3268:gst_rtp_jitter_buffer_chain: Pushed packet #4922, now 22 packets, head: 0, percent -1
0:00:02.274901776 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpbvdepay
0:00:02.274906625 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpjitterbuffer0:sink called chainfunction &gst_rtp_jitter_buffer_chain with buffer 0x7f31c4038c60, returned ok
0:00:02.274911234 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpceltdepay
0:00:02.274916453 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpssrcdemux0:sink called chainfunction &gst_rtp_ssrc_demux_chain with buffer 0x7f31c4038c60, returned ok
0:00:02.274920942 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpdvdepay
0:00:02.274925611 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpstorage0:sink called chainfunction &gst_rtp_storage_chain with buffer 0x7f31c4038c60, returned ok
0:00:02.274930029 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpg722depay
0:00:02.274935239 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:rtpsession0:recv_rtp_sink called chainfunction &gst_rtp_session_chain_recv_rtp with buffer 0x7f31c4038c60, returned ok
0:00:02.274939357 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpg723depay
0:00:02.274945017 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4329:gst_pad_chain_data_unchecked:manager:recv_rtp_sink_0 called chainfunction &gst_proxy_pad_chain_default with buffer 0x7f31c4038c60, returned ok
0:00:02.274949105 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpg726depay
0:00:02.274953533 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.274958653 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpg729depay
0:00:02.274963382 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001001
0:00:02.274967981 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpgsmdepay
0:00:02.274973000 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2842:gst_base_src_loop: next_ts 99:99:99.999999999 size 4096
0:00:02.274976897 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtph261depay
0:00:02.274981727 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2519:gst_base_src_get_range: calling create offset 18446744073709551615 length 4096, time 0
0:00:02.274986465 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtph263depay
0:00:02.274990643 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:1128:default_acquire_buffer: no buffer, trying to allocate
0:00:02.274995763 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtph263pdepay
0:00:02.275000702 40126 0x7f31e801d300 DEBUG GST_MEMORY gstmemory.c:138:gst_memory_init: new memory 0x7f31c403ca80, maxsize:1499 offset:0 size:1492
0:00:02.275004690 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtph264depay
0:00:02.275008968 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:844:gst_buffer_new: new 0x7f31c4038d80
0:00:02.275014108 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtph265depay
0:00:02.275018576 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:450:_memory_add: buffer 0x7f31c4038d80, idx -1, mem 0x7f31c403ca80
0:00:02.275023726 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpilbcdepay
0:00:02.275028124 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:898:gst_buffer_new_allocate: new buffer 0x7f31c4038d80 of size 1492 from allocator (nil)
0:00:02.275032482 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpj2kdepay
0:00:02.275037091 40126 0x7f31e801d300 LOG bufferpool gstbufferpool.c:286:do_alloc_buffer: allocated buffer 2/0, 0x7f31c4038d80
0:00:02.275041569 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpjpegdepay
0:00:02.275046228 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038d80, idx 0, length -1, flags 0003
0:00:02.275050496 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpklvdepay
0:00:02.275054955 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038d80, idx 0, length 1
0:00:02.275059533 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmp1sdepay
0:00:02.275063641 40126 0x7f31e801d300 LOG udpsrc gstudpsrc.c:875:gst_udpsrc_fill: doing select, timeout -1
0:00:02.275068180 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmp2tdepay
0:00:02.275075063 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1656:gst_buffer_resize_range: trim 0x7f31c4038d80 0-1452 size:1492 offs:0 max:1499
0:00:02.275076866 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmp4adepay
0:00:02.275081214 40126 0x7f31e801d300 DEBUG GST_BUFFER gstbuffer.c:2282:gst_buffer_add_meta: alloc metadata 0x7f31c4036530 (GstNetAddressMeta) of size 24
0:00:02.275085632 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmp4gdepay
0:00:02.275090241 40126 0x7f31e801d300 LOG udpsrc gstudpsrc.c:993:gst_udpsrc_fill: read packet of 1452 bytes
0:00:02.275095130 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmp4vdepay
0:00:02.275100040 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1091:gst_clock_get_internal_time: internal time 182:52:59.538995236
0:00:02.275104348 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmpadepay
0:00:02.275110129 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1136:gst_clock_get_time: adjusted time 182:52:59.538995236
0:00:02.275114938 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmparobustdepay
0:00:02.275119737 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2326:gst_base_src_do_sync: created DTS 0:00:00.336983708
0:00:02.275124586 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpmpvdepay
0:00:02.275129796 40126 0x7f31e801d300 LOG basesrc gstbasesrc.c:2336:gst_base_src_do_sync: created PTS 0:00:00.336983708
0:00:02.275134364 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtppcmadepay
0:00:02.275138061 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2375:gst_base_src_do_sync: no sync needed
0:00:02.275143662 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtppcmudepay
0:00:02.275147509 40126 0x7f31e801d300 DEBUG basesrc gstbasesrc.c:2612:gst_base_src_get_range: buffer ok
0:00:02.275152989 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpqcelpdepay
0:00:02.275156737 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.275162828 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpqdm2depay
0:00:02.275167226 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001012
0:00:02.275171364 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpsbcdepay
0:00:02.275175843 40126 0x7f31e801d300 DEBUG GST_PADS gstpad.c:3815:do_probe_callbacks:udpsrc1:src data is passed
0:00:02.275180692 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpsirendepay
0:00:02.275184799 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3725:do_probe_callbacks:udpsrc1:src do probes
0:00:02.275189939 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpspeexdepay
0:00:02.275194528 40126 0x7f31e801d300 LOG GST_SCHEDULING gstpad.c:3612:probe_hook_marshal:udpsrc1:src hook 2 with flags 0x00003040 does not match 00001010
0:00:02.275199096 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpsv3vdepay
0:00:02.275205508 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:manager:recv_rtp_sink_0 calling chainfunction &gst_proxy_pad_chain_default with buffer buffer: 0x7f31c4038d80, pts 0:00:00.336983708, dts 0:00:00.336983708, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.275208103 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtptheoradepay
0:00:02.275213363 40126 0x7f31e801d300 DEBUG GST_SCHEDULING gstpad.c:4323:gst_pad_chain_data_unchecked:rtpsession0:recv_rtp_sink calling chainfunction &gst_rtp_session_chain_recv_rtp with buffer buffer: 0x7f31c4038d80, pts 0:00:00.336983708, dts 0:00:00.336983708, dur 99:99:99.999999999, size 1452, offset none, offset_end none, flags 0x0
0:00:02.275220246 40126 0x7f31e801d300 LOG rtpsession gstrtpsession.c:1945:gst_rtp_session_chain_recv_rtp: received RTP packet
0:00:02.275223212 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpvorbisdepay
0:00:02.275225316 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1091:gst_clock_get_internal_time: internal time 182:52:59.539120623
0:00:02.275231878 40126 0x7f31e801d300 DEBUG GST_CLOCK gstclock.c:1136:gst_clock_get_time: adjusted time 182:52:59.539120623
0:00:02.275233722 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying rtpvrawdepay
0:00:02.275237990 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:1800:gst_buffer_map_range: buffer 0x7f31c4038d80, idx 0, length 1, flags 0001
0:00:02.275242348 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying y4mdec
0:00:02.275246866 40126 0x7f31e801d300 LOG GST_BUFFER gstbuffer.c:244:_get_merged_memory: buffer 0x7f31c4038d80, idx 0, length 1
0:00:02.275252748 40126 0x7f31d8007760 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:850:gst_element_factory_list_filter: Trying avdec_4xm
0:00:02.275257677 40126 0x7f31e801d300 LOG rtpsource rtpsource.c:1194:update_receiver_stats: seq 4923, PC: 60, OC: 71799
this is the log i am getting thhrough gst_debug=6
debug6deepstreamlogs.txt (208.5 KB)
the log is not enough because the time length is less that one second.
- noticing you are testing deeptream-test3, did you modify the code?
- test3 will use uridecodebin to decode if you did not modify the code. can you see the video if using this command?
gst-launch-1.0 -v uridecodebin uri=rtsp://xx ! nveglglessink.
Text file of logs i also shared , in that more logs are there.
1-: Yes , I am using deepstream test 3, No, I didnt do any chnages
2-: yes using gst urid
I am sharing the logs i am getting with gst-launch-1.0 -v uridecodebin uri=rtsp://xx ! nveglglessink. this command
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)699696669,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.165:6970,\ rtcp-from=(string)192.168.1.165:6971,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)3352731,\ packets-received=(guint64)3936,\ bitrate=(guint64)583320,\ packets-lost=(int)0,\ jitter=(uint)7,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)true,\ sr-ntptime=(guint64)16775422522956614006,\ sr-rtptime=(uint)3597119630,\ sr-octet-count=(uint)2946068,\ sr-packet-count=(uint)3457,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)28805,\ sent-rb-jitter=(uint)16,\ sent-rb-lsr=(uint)1172805098,\ sent-rb-dlsr=(uint)194547,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)748348260,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;” >, rtx-count=(uint)0, recv-rtx-req-count=(uint)0, sent-rtx-req-count=(uint)0;
using that command i am getting this log with each frame
One more thing, We create our own pipeline also, in that for decoding we used “decodebin”
plugin then it is giving green screen but when we use “nvv4l2decoder” instead of that then it is working fine.
- what is your start commandline?
- is the output video green if testing “gst-launch-1.0 -v uridecodebin uri=rtsp://xx ! nveglglessink” ?
- if the output video is green, we need more logs, please share the 1.log after testing this command, you can compress the 1.log by zip.
export GST_DEBUG=6 && gst-launch-1.0 -v uridecodebin uri=rtsp://xx ! nveglglessink >1.log 2>1.log
1-: _NV_PRIME_RENDER_OFFLOAD=1 ./deepstream-test-app3 rtsp;//xx
2-: No, it doesnot showing anything, its shows black screen
1.log (6.9 MB)
0:00:00.092534317 e[331m 144e[00m 0x556994dc7800 e[31;01mERROR e[00m e[00m nveglglessink ext/eglgles/gsteglglessink.c:563:egl_init:e[00m Failed to perform EGL init
from the log, the app did not decode because the nveglglessink failed to initialize.
were all tests in host or from ssh shell?
All test from host.
This egl sink is working for h264 camera and also in gstreamer its working
this command is working
is there any problem of decoder becuase if we replace uridecodebin with nvv4l2decoder its working?
- can you try this command? if this command works, it should not be decoder issue.
gst-launch-1.0 uridecodebin uri=rtsp://xx ! nvvideoconvert ! autovideosink - can you this command? noticing you added nvvidoeconvert and sync=false.
gst-launch-1.0 rtspsrc location=rtsp:// latency=0 drop-on-latency=true rtsp-keep-alive=true protocols=tcp ! rtph265depay ! h265parse ! nvv4l2decoder ! nveglglessink
