I installed 340.32 on a Acer Aspire TimelineX 5830TG
with Mandriva 2011 x86_64 installed. To install first
make sure the old graphics driver is not activated :
- cd /etc/systemd/system
ln -sf /lib/systemd/system/multi-user.target default.target - next reboot in `failsafe’ mode.
The installation of NVIDIA-Linux-x86_64-340.32.run went without
any errors or warnings … it created the following /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 340.32 (buildmeister@swio-display-x64-rhel04-01) Tue Aug 5 21:15:33 PDT 2014
# File generated by XFdrake (rev 262502)
# Refer to the xorg.conf man page for details about the format of
# this file.
Section "ServerLayout"
Identifier "layout1"
Screen "screen1" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Module"
Load "v4l" # Video for Linux
Load "glx"
EndSection
Section "ServerFlags"
# allows the server to start up even if the mouse does not work
#DontZoom # disable <Ctrl><Alt><KP_+>/<KP_-> (resolution switching)
Option "DontZap" "False" # disable <Ctrl><Alt><BS> (server abort)
Option "allowmouseopenfail"
EndSection
Section "InputDevice"
# generated from default
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
# TV fullscreen mode or DVD fullscreen output.
# 768x576 @ 79 Hz, 50 kHz hsync
Identifier "monitor1"
VendorName "Generic"
ModelName "Flat Panel 1024x768"
HorizSync 31.5 - 48.0
VertRefresh 56.0 - 65.0
ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630
ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616
EndSection
Section "Device"
Identifier "device1"
Driver "intel"
VendorName "Intel Corporation"
BoardName "Intel 810 and later"
EndSection
Section "Screen"
Identifier "screen1"
Device "device1"
Monitor "monitor1"
DefaultDepth 24
Option "DPMS"
SubSection "Display"
Depth 8
Modes "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240"
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
I tested the configuration above and a second time with Driver “intel” changed
into “nvidia” . Here’s the logging inside /var/log/Xorg.0.log :
[ 281.774] _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
[ 281.774] _XSERVTransOpen: transport open failed for inet6/acer30.stokkie.net:0
[ 281.774] _XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
[ 281.794]
X.Org X Server 1.10.3
Release Date: 2011-07-08
[ 281.795] X Protocol Version 11, Revision 0
[ 281.795] Build Operating System: Linux_2.6.33.7-server-2mnb Mandriva
[ 281.795] Current Operating System: Linux acer30.stokkie.net 2.6.39.4-4.2-desktop #1 SMP Fri Jan 13 15:29:31 CET 2017 x86_64
[ 281.795] Kernel command line: BOOT_IMAGE=/boot/vmlinuz BOOT_IMAGE=failsafe root=UUID=92e466c1-6a5c-4f0c-920c-ec96fd8c1902 failsafe
[ 281.795] Build Date: 26 July 2011 01:51:30AM
[ 281.796]
[ 281.796] Current version of pixman: 0.22.0
[ 281.796] Before reporting problems, check http://qa.mandriva.com
to make sure that you have the latest version.
[ 281.796] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 281.797] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 11 16:48:13 2017
[ 281.855] (==) Using config file: "/etc/X11/xorg.conf"
[ 281.855] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 281.871] (==) ServerLayout "layout1"
[ 281.871] (**) |-->Screen "screen1" (0)
[ 281.871] (**) | |-->Monitor "monitor1"
[ 281.871] (**) | |-->Device "device1"
[ 281.871] (**) |-->Input Device "Keyboard0"
[ 281.871] (**) |-->Input Device "Mouse0"
[ 281.871] (**) Option "DontZap" "False"
[ 281.871] (**) Option "AllowMouseOpenFail"
[ 281.871] (==) Automatically adding devices
[ 281.871] (==) Automatically enabling devices
[ 281.888] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d
[ 281.888] (==) ModulePath set to "/usr/lib64/xorg/extra-modules,/usr/lib64/xorg/modules"
[ 281.888] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 281.888] (WW) Disabling Keyboard0
[ 281.888] (WW) Disabling Mouse0
[ 281.888] (II) Loader magic: 0x7d61a0
[ 281.888] (II) Module ABI versions:
[ 281.888] X.Org ANSI C Emulation: 0.4
[ 281.888] X.Org Video Driver: 10.0
[ 281.888] X.Org XInput driver : 12.2
[ 281.888] X.Org Server Extension : 5.0
[ 281.888] (--) PCI:*(0:0:2:0) 8086:0116:1025:055b rev 9, Mem @ 0xd1400000/4194304, 0xc0000000/268435456, I/O @ 0x00004000/64
[ 281.888] (--) PCI: (0:1:0:0) 10de:0df4:1025:055c rev 161, Mem @ 0xd0000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 281.888] (II) Open ACPI successful (/var/run/acpid.socket)
[ 281.888] (II) "extmod" will be loaded by default.
[ 281.888] (II) "dbe" will be loaded by default.
[ 281.888] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 281.888] (II) "record" will be loaded by default.
[ 281.888] (II) "dri" will be loaded by default.
[ 281.888] (II) "dri2" will be loaded by default.
[ 281.888] (II) LoadModule: "v4l"
[ 281.950] (II) Loading /usr/lib64/xorg/modules/drivers/v4l_drv.so
[ 281.958] (II) Module v4l: vendor="X.Org Foundation"
[ 281.958] compiled for 1.10.2, module version = 0.1.1
[ 281.958] ABI class: X.Org Video Driver, version 10.0
[ 281.958] (II) LoadModule: "glx"
[ 282.018] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 282.828] (II) Module glx: vendor="NVIDIA Corporation"
[ 282.837] compiled for 4.0.2, module version = 1.0.0
[ 282.837] Module class: X.Org Server Extension
[ 282.846] (II) NVIDIA GLX Module 340.32 Tue Aug 5 20:32:43 PDT 2014
[ 282.860] (II) Loading extension GLX
[ 282.860] (II) LoadModule: "extmod"
[ 282.860] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[ 282.874] (II) Module extmod: vendor="X.Org Foundation"
[ 282.874] compiled for 1.10.3, module version = 1.0.0
[ 282.874] Module class: X.Org Server Extension
[ 282.874] ABI class: X.Org Server Extension, version 5.0
[ 282.874] (II) Loading extension MIT-SCREEN-SAVER
[ 282.874] (II) Loading extension XFree86-VidModeExtension
[ 282.874] (II) Loading extension XFree86-DGA
[ 282.874] (II) Loading extension DPMS
[ 282.874] (II) Loading extension XVideo
[ 282.874] (II) Loading extension XVideo-MotionCompensation
[ 282.874] (II) Loading extension X-Resource
[ 282.874] (II) LoadModule: "dbe"
[ 282.874] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[ 282.882] (II) Module dbe: vendor="X.Org Foundation"
[ 282.882] compiled for 1.10.3, module version = 1.0.0
[ 282.882] Module class: X.Org Server Extension
[ 282.882] ABI class: X.Org Server Extension, version 5.0
[ 282.882] (II) Loading extension DOUBLE-BUFFER
[ 282.882] (II) LoadModule: "record"
[ 282.883] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[ 282.891] (II) Module record: vendor="X.Org Foundation"
[ 282.891] compiled for 1.10.3, module version = 1.13.0
[ 282.891] Module class: X.Org Server Extension
[ 282.891] ABI class: X.Org Server Extension, version 5.0
[ 282.891] (II) Loading extension RECORD
[ 282.891] (II) LoadModule: "dri"
[ 282.891] (II) Loading /usr/lib64/xorg/modules/extensions/libdri.so
[ 282.902] (II) Module dri: vendor="X.Org Foundation"
[ 282.902] compiled for 1.10.3, module version = 1.0.0
[ 282.902] ABI class: X.Org Server Extension, version 5.0
[ 282.902] (II) Loading extension XFree86-DRI
[ 282.902] (II) LoadModule: "dri2"
[ 282.902] (II) Loading /usr/lib64/xorg/modules/extensions/libdri2.so
[ 282.902] (II) Module dri2: vendor="X.Org Foundation"
[ 282.902] compiled for 1.10.3, module version = 1.2.0
[ 282.902] (II) Loading extension DRI2
[ 282.903] (II) LoadModule: "nvidia"
[ 282.903] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 282.965] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 282.978] compiled for 4.0.2, module version = 1.0.0
[ 282.978] Module class: X.Org Video Driver
[ 282.990] (II) v4l driver for Video4Linux
[ 282.990] (II) NVIDIA dlloader X Driver 340.32 Tue Aug 5 20:13:04 PDT 2014
[ 282.990] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 282.991] (--) using VT number 8
[ 282.992] (WW) Falling back to old probe method for v4l
[ 282.992] (EE) No devices detected.
[ 282.992]
Fatal server error:
[ 282.992] no screens found
[ 282.992]
Please consult the The X.Org Foundation support
at http://qa.mandriva.com
for help.
[ 282.992] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 282.992]
I thought it was very strange that although the kernel driver module nvidia.ko
had loaded error free :
Module Size Used by
ipt_MASQUERADE 2384 1
ipt_LOG 8009 1
xt_state 1410 1
iptable_nat 5127 1
iptable_filter 1802 1
nf_nat_ftp 2274 0
nf_nat 21663 3 ipt_MASQUERADE,iptable_nat,nf_nat_ftp
nf_conntrack_ipv4 14734 4 iptable_nat,nf_nat
nf_defrag_ipv4 1657 1 nf_conntrack_ipv4
nf_conntrack_irc 5128 0
nf_conntrack_ftp 11326 1 nf_nat_ftp
nf_conntrack 83961 8 ipt_MASQUERADE,xt_state,iptable_nat,nf_nat_ftp,nf_nat,nf_conntrack_ipv4,nf_conntrack_irc,nf_conntrack_ftp
ip_tables 19124 2 iptable_nat,iptable_filter
x_tables 24804 6 ipt_MASQUERADE,ipt_LOG,xt_state,iptable_nat,iptable_filter,ip_tables
nfs 320983 0
lockd 79366 1 nfs
fscache 44887 1 nfs
auth_rpcgss 44731 1 nfs
nfs_acl 2725 1 nfs
sunrpc 225015 5 nfs,lockd,auth_rpcgss,nfs_acl
af_packet 21604 2
bnep 15827 2
bluetooth 213982 7 bnep
pci_stub 1646 1
vboxpci 15312 0
vboxnetadp 18678 0
vboxnetflt 18087 0
vboxdrv 330789 3 vboxpci,vboxnetadp,vboxnetflt
coretemp 6103 0
nvidia 10533918 0
uvcvideo 63774 0
videodev 90721 1 uvcvideo
media 13608 1 videodev
snd_hda_codec_hdmi 25618 1
v4l2_compat_ioctl32 9044 1 videodev
i2c_i801 9922 0
sparse_keymap 4322 0
snd_hda_codec_conexant 55236 1
i2c_core 30664 3 nvidia,videodev,i2c_i801
xhci_hcd 118038 0
rfkill 18699 2 bluetooth
battery 11618 0
iTCO_wdt 13412 0
iTCO_vendor_support 3070 1 iTCO_wdt
sg 30212 0
snd_hda_intel 26102 1
snd_hda_codec 100363 3 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel
wmi 10182 0
snd_hwdep 7020 1 snd_hda_codec
evdev 10209 11
snd_pcm_oss 46424 0
snd_pcm 95259 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_pcm_oss
snd_timer 23276 1 snd_pcm
snd_page_alloc 8612 2 snd_hda_intel,snd_pcm
snd_mixer_oss 16133 1 snd_pcm_oss
snd 74624 11 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm_oss,snd_pcm,snd_timer,snd_mixer_oss
soundcore 7751 1 snd
autofs4 24308 6
ext4 401007 1
jbd2 79652 1 ext4
crc16 1731 2 bluetooth,ext4
usbhid 43861 0
hid 84987 1 usbhid
sd_mod 35801 4
sr_mod 15423 0
crc_t10dif 1587 1 sd_mod
ahci 21638 3
libahci 23027 1 ahci
libata 210234 2 ahci,libahci
rts_pstor 409943 1
ehci_hcd 53153 0
usbcore 195459 5 uvcvideo,xhci_hcd,usbhid,ehci_hcd
scsi_mod 212079 5 sg,sd_mod,sr_mod,rts_pstor,libata
atl1c 35725 0
video 12689 0
loop 18830 0
dm_mod 74522 0
I still get the error : [ 282.992] (EE) No devices detected.
I started looking and the found the following :
[acer30:root]:(~)# cd /proc/driver/nvidia/
[acer30:root]:(/proc/driver/nvidia)# ll
total 0
dr-xr-xr-x 3 root root 0 Sep 11 20:24 gpus/
-r--r--r-- 1 root root 0 Sep 11 21:14 params
dr-xr-xr-x 2 root root 0 Sep 11 21:14 patches/
-rw-r--r-- 1 root root 0 Sep 11 21:14 registry
-r--r--r-- 1 root root 0 Sep 11 21:14 version
dr-xr-xr-x 2 root root 0 Sep 11 21:14 warnings/
[acer30:root]:(/proc/driver/nvidia)# cd gpus
[acer30:root]:(/proc/driver/nvidia/gpus)# ll
total 0
dr-xr-xr-x 2 root root 0 Sep 11 20:24 0000:01:00.0/
[acer30:root]:(/proc/driver/nvidia/gpus)# cd 0000\:01\:00.0/
[acer30:root]:(/proc/driver/nvidia/gpus/0000:01:00.0)# ll
total 0
-r--r--r-- 1 root root 0 Sep 11 21:14 information
[acer30:root]:(/proc/driver/nvidia/gpus/0000:01:00.0)# cat information
Model: GeForce GT 540M
IRQ: 16
GPU UUID: GPU-????????-????-????-????-????????????
Video BIOS: ??.??.??.??.??
Bus Type: PCIe
DMA Size: 32 bits
DMA Mask: 0xffffffff
Bus Location: 0000:01:00.0
[acer30:root]:(/proc/driver/nvidia/gpus/0000:01:00.0)# cat registry
Binary: ""
So on my laptop both the GPU UUID and Video BIOS have been wiped out ?
Hence any NVidia driver will of course fail to detect the onboard GeForce GT 540M …
Any advise what to do next ?
