Just conclusively checking whether this GPU is compatible with Cuda 8.0? I couldn’t see it on a supported GPU page and am thinking now I might need to upgrade from this. Anyone who knows for sure?
Yes, it is supported by CUDA 8
What is the latest version of CUDA that can be used for a GeForce GTX 770?
All recent CUDA version up through CUDA 10.0 (the currently most recent version) will support GTX 770
CUDA 10 did not work on my GTX 770.
After installation and restart:
nvidia-smi:
> nvidia-smi
Mon Dec 10 22:11:26 2018
| NVIDIA-SMI 411.31 Driver Version: 411.31 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 GeForce GTX 770 WDDM | 00000000:02:00.0 N/A | N/A |
| 33% 32C P8 N/A / N/A | 55MiB / 4096MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
NVCC:
>nvcc -V
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:04_Central_Daylight_Time_2018
Cuda compilation tools, release 10.0, V10.0.130
“C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.0\1_Utilities\deviceQuery\deviceQuery_vs2017.sln”
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.0_Utilities\deviceQuery\../../bin/win64/Debug/deviceQuery.exe Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.0_Utilities\deviceQuery\../../bin/win64/Debug/deviceQuery.exe (process 5244) exited with code 1.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
sysinfo
System Information report written at: 12/10/18 22:18:37
System Name: P04295
[System Summary]
Item Value
OS Name Microsoft Windows 10 Pro
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name P04295
System Manufacturer Dell Inc.
System Model OptiPlex 980
System Type x64-based PC
System SKU
Processor Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz, 3193 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date Dell Inc. A02, 29-Apr-10
SMBIOS Version 2.6
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Dell Inc.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role SOHO Server
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.17134.285"
Time Zone W. Europe Standard Time
Installed Physical Memory (RAM) 6.00 GB
Total Physical Memory 5.93 GB
Available Physical Memory 3.00 GB
Total Virtual Memory 12.9 GB
Available Virtual Memory 9.85 GB
Page File Space 7.00 GB
Page File D:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
CUDA 9.1 works fine with an older driver!
