Gen3_lite rigid bodies error
My console window generate some errors.
[Error] [omni.physx.tensors.plugin] Pattern ‘/gen3_lite/world/base_joint’ did not match any rigid bodies
[Error] [omni.physx.tensors.plugin] Provided pattern list did not match any articulations
I use ubuntu 22.04, and ros2 humble.
I used ros2_kortex pkg’s urdf, and it worked well in gazebo.
But in isaac sim, it generate some errors.
How can I fix it?
URDF’s hierarchy is here.
Thank you for read my post.
Please check if the following topics are helpful:
I looked up other reference.
After looking for other links, I understood the process, and I was able to solve the problem thanks to you.
Thank you!
