I have run Azure Custom vision model on Jetson Nano with Deep stream and I need to Get an Out put signal from GPIO when it detect “Rejected” labeled object detected by the camera. I was trying to fix this but i couldn’t able to find a way to do that and I really confused.
please provide me steps that i want to follow to setup this and if there is any sample codes/projects please provide me.
I am using Jetson nano Dev kit(4GB)]
Can you explain each steps that i want to follow create a service to monitor the “Rejected” and control GPIO through sysfs. including example codes.
Sorry that it seems the custom requirement specific to your use case. There should be many resources online about how to create custom system service and also the commands to control GPIO. You have to study that and implement by yourself.
I can just give you a simple example to control GPIO through sysfs, you can try it on your board first.
$ cd /sys/class/gpio
# echo 194 > export
# cd gpio194
# echo out > direction && echo 1 > value
