Get the output of 4 cameras with SIPL
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hi. I’m using the SIPL API to get the output of 4 Sekonix cameras. I used the platform config hardcoded in the nvsipl sample since the platform config for SF3324_CPHY_x4 from the SIPL database doesn’t work.
The nvSCI buffers from the SIPL completion queue contain the image from one camera. I mapped the buffers to CUDA and viewed the image to make sure.
I want to get the output of all cameras. The ICP sample indicates that I should be getting a buffer with 4x the width of a single image. I think I need to set the number of virtual groups in ICP properly, however, the SIPL API doesn’t expose that.
I suspect I need to change the platform config I’m using to match the hardware setup. I tried the obvious way, i.e. change numCameraModules from 1 to 4 and add more entries in cameraModuleInfoList, but it didn’t work. I’m shooting in the dark here.
Does someone have a working configuration?
Hi @shayan.manoochehri ,
Which sample application are you using? Can you start with 2 Sekonix cameras? Can you share the log of the error and the steps to reproduce the issue? Thanks.
The sample I’m based on is /samples/nvmedia/nvsipl/test/sample/nvsipl_sample
This is the stock configuration.
static PlatformCfg platformCfg = {
    .platform = "SF3324_CPHY_x4",
    .platformConfig = "SF3324_CPHY_x4",
    .description = "SF3324 module in 4 lane CPHY mode",
    .numDeviceBlocks = 1U,
    .deviceBlockList = {
            .csiPort = NVMEDIA_IMAGE_CAPTURE_CSI_INTERFACE_TYPE_CSI_AB,
            .phyMode = NVMEDIA_ICP_CSI_CPHY_MODE,
            .i2cDevice = 0U,
            .deserInfo = {
                .name = "MAX96712",
#if !NV_IS_SAFETY
                .description = "Maxim 96712 Aggregator",
#endif // !NV_IS_SAFETY
                .i2cAddress = 0x29
            .numCameraModules = 1U,
            .cameraModuleInfoList = {
                    .name = "SF3324",
#if !NV_IS_SAFETY
                    .description = "Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705",
                    .linkIndex = 0U,
                    .serInfo = {
                        .name = "MAX96705",
#if !NV_IS_SAFETY
                        .description = "Maxim 96705 Serializer",
                        .i2cAddress = 0x40
                    .isEEPROMSupported = false,
                    .eepromInfo = {
                    .sensorInfo = {
                            .id = SIPL_PIPELINE_ID,
                            .name = "AR0231",
#if !NV_IS_SAFETY
                            .description = "OnSemi AR0231 Sensor",
                            .i2cAddress = 0x10,
                            .vcInfo = {
                                    .cfa = NVM_SURF_ATTR_COMPONENT_ORDER_CRBC,
                                    .embeddedTopLines = 24U,
                                    .embeddedBottomLines = 4U,
                                    .inputFormat = NVMEDIA_IMAGE_CAPTURE_INPUT_FORMAT_TYPE_RAW12,
                                    .resolution = {
                                        .width = 1920U,
                                        .height = 1208U
                                    .fps = 30.0,
                                    .isEmbeddedDataTypeEnabled = false
                            .isTriggerModeEnabled = true
I have no idea how to patch it to support two cameras. Here’s an example of what I tried.
            .i2cDevice = 0U,
            .deserInfo = {
                .name = "MAX96712",
#if !NV_IS_SAFETY
                .i2cAddress = 0x29
            .numCameraModules = 2U,
                    .name = "SF3324",
#if !NV_IS_SAFETY
                    .linkIndex = 0U,
                    .serInfo = {
                        .name = "MAX96705",
#if !NV_IS_SAFETY
                        .i2cAddress = 0x40
                    .eepromInfo = {
                    .sensorInfo = {
                            .name = "AR0231",
#if !NV_IS_SAFETY
                            .i2cAddress = 0x10,
                            .vcInfo = {
                                    .resolution = {
                                        .width = 1920U,
                                        .height = 1208U
                                    .fps = 30.0,
                    .name = "SF3324",
#if !NV_IS_SAFETY
                    .linkIndex = 1U,
                    .serInfo = {
                        .name = "MAX96705",
#if !NV_IS_SAFETY
                        .i2cAddress = 0x40
                    .eepromInfo = {
                    .sensorInfo = {
                            .id = 1,
                            .name = "AR0231",
#if !NV_IS_SAFETY
                            .i2cAddress = 0x10,
                            .vcInfo = {
                                    .resolution = {
                                        .width = 1920U,
                                        .height = 1208U
                                    .fps = 30.0,
Output.
MAX96712: Revision 2 detected
MAX96712: Enable periodic AEQ on Link 0
MAX96705: Pre-emphasis set to 0xaa
MAX96705: Revision 1 detected!
Sensor AR0231 RCCB Rev7 detected!
MAX96712: Enable periodic AEQ on Link 1
nvsipl_sample: CNvMCamera.cpp: 458: Init: Incorrect pipeline state:0 for pipeline:1
nvsipl_sample: ERROR: INvSIPLCamera::Init() failed, status: 6
nvsipl_sample: CNvMCamera.cpp: 1088: Deinit: Incorrect pipeline state:1 for pipeline:0
nvsipl_sample: CNvMCamera.cpp: 48: ~CNvMCamera: CNvMCamera object fails to deinit
nvsipl_sample: ERROR: Unexpected output type
Please refer to --link-enable-masks switch of nvsipl_camera sample application and its source code (under /nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera). Thanks.
Thanks. I tried specifying the mask in the platform config and it didn’t work. I give up. I switched to the DriveWorks API.
If you change your mind and need our help on NvMedia API again, let us know. Thanks.
