Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] other DRIVE OS version
other
Target Operating System
Linux
[*] QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.8.0.10363
[*] other nv-qnx-52120-standard
Host Machine Version
[*] native Ubuntu 18.04
other
Hi Nvidia exports,
We have a requirement that an Image injection device would connect to the Xavier Replacing the camera sensor. Image injection device uses a serializer Max9295,we can’t Establish connection the Max96712.
So we would like require some helps from you, thanks a lot.
- There is only serializer Max9295 connecting to Max96712, So can we skip the “NvMedia SIPL Framework” and get some image datas by Max96712 directly?
- We try to debug the Max9295 to support the Image injection device, and there is a init error, Can you help me to locate the cause of the problem?
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "AR0X3C" to module driver "/usr/libnvidia/nvsipl_drv/libnvsipl_devblk_drv_ar0x3c.so"
Main: CNvMMAX96712CameraModule.cpp: 390: DoSetConfig: ZHC_TEST:DoSetConfig: cameraModuleConfig->eInterface 5
nvsipl_camera: Creating consumer for output:0 of sensor:4
nvsipl_camera: Profiler initialization for output:0 of sensor:4
nvsipl_camera: Consumer initialization for output:0 of sensor:4
nvsipl_camera: Initializing master interface
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMCamera.cpp: 574: Init: Initializing device blocks
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 216: Init: Initializing worker thread for block:0
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 34: ThreadCreate: Creating thread:DEVBLK_WORKER_0
Main: /dit/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 130: m_FuncStatic: Thread created
: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 117: ThreadSetName: Setting thread name:DEVBLK_WORKER_0Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 179: WorkersDoAction: All worker threads starting DEVBLK_WORKER_0: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 145: m_Func: Running thread:DEVBLK_WORKER_0
on:1
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 148: m_Func: Calling ThreadFunc for thread:DEVBLK_WORKER_0
nvsipl_camera: Queue timeout
DEVBLK_WORKER_0: CNvMMax96712.cpp: 184: DoInit: Check deserializer is present
MAX96712: Revision 5 detected
DEVBLK_WORKER_0: CNvMMax96712.cpp: 191: DoInit: Set deserializer defaults
MAX96712 Link 0: PHY optimization was enabled
DEVBLK_WORKER_0: CNvMMax96712.cpp: 199: DoInit: Get deserializer revision
DEVBLK_WORKER_0: CNvMMax96712.cpp: 211: DoInit: Set MIPI output mode
DEVBLK_WORKER_0: CNvMMAX96712CameraModule.cpp: 35: Init: ZHC_TEST:CNvMMAX96712CameraModule: m_pDeserializer->EnableLinks 0
DEVBLK_WORKER_0: CNvMMax96712.cpp: 271: EnableLinks: Enabling links
DEVBLK_WORKER_0: CNvMMAX96712CameraModule.cpp: 120: Init: ZHC_TEST: MAX96712: Init Done 0
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 205: WorkersDoAction: All worker threads finished action:1
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
Jan 01 02:50:42.815 nvsipl_camera.3166304..1 0 -----ONLINE-----
Jan 01 02:50:42.815 nvsipl_camera.3166304..1 slog* 0 MAX96712: Revision 5 detected
Jan 01 02:50:42.822 nvsipl_camera.3166304..1 slog 0 MAX96712 Link 0: PHY optimization was enabled
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera* 10031 src/devblk/common/core/CNvMDeviceBlock.cpp: 883
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 DevBlkCDIRootDeviceCheckAndClearIntr with NvMedia error: 7
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 501
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Device block init failed. Status:: 0x00000a
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 197
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Device block action failed for action: 1
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 198
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Device block action failed for block: 0
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 230
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Failed to initialize device blocks
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMCamera.cpp: 596
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 DeviceBlock manager init failed
Jan 01 02:50:42.974 devm_cdac.1052751 devm-cdac 10031 LOW-transitioning interrupt pin is not at the HIGH logic level: 16
Jan 01 02:50:42.974 devm_cdac.1052751 devm-cdac 10031 Failed to execute GPIO check and clear intr devctl: 16
Jan 01 02:50:42.974 nvsipl_camera.3166304..1 slog 0 cdiRootDevCheckAndClearIntr: failed to check and clear edge intr via devctl
- Is .“/nv-qnx-52120-standard/drive-t186ref-qnx/samples/nvmedia/nvsipl/devblk/devices/MAX96712DeserializerDriver” compiled in another location?
We try to modify MAX96712DeserializerDriver and replace the libnvsipl_devblk_drv_xxx.so, but there is no use.
Look forward to your reply.
