Hi Nvidia exports,
We have a requirement that an Image injection device would connect to the Xavier Replacing the camera sensor. Image injection device uses a serializer Max9295,we can’t Establish connection the Max96712.
So we would like require some helps from you, thanks a lot.
There is only serializer Max9295 connecting to Max96712, So can we skip the “NvMedia SIPL Framework” and get some image datas by Max96712 directly?
We try to debug the Max9295 to support the Image injection device, and there is a init error, Can you help me to locate the cause of the problem?
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "AR0X3C" to module driver "/usr/libnvidia/nvsipl_drv/libnvsipl_devblk_drv_ar0x3c.so"
Main: CNvMMAX96712CameraModule.cpp: 390: DoSetConfig: ZHC_TEST:DoSetConfig: cameraModuleConfig->eInterface 5
nvsipl_camera: Creating consumer for output:0 of sensor:4
nvsipl_camera: Profiler initialization for output:0 of sensor:4
nvsipl_camera: Consumer initialization for output:0 of sensor:4
nvsipl_camera: Initializing master interface
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMCamera.cpp: 574: Init: Initializing device blocks
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 216: Init: Initializing worker thread for block:0
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 34: ThreadCreate: Creating thread:DEVBLK_WORKER_0
Main: /dit/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 130: m_FuncStatic: Thread created
: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 117: ThreadSetName: Setting thread name:DEVBLK_WORKER_0Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 179: WorkersDoAction: All worker threads starting DEVBLK_WORKER_0: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 145: m_Func: Running thread:DEVBLK_WORKER_0
on:1
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 148: m_Func: Calling ThreadFunc for thread:DEVBLK_WORKER_0
nvsipl_camera: Queue timeout
DEVBLK_WORKER_0: CNvMMax96712.cpp: 184: DoInit: Check deserializer is present
MAX96712: Revision 5 detected
DEVBLK_WORKER_0: CNvMMax96712.cpp: 191: DoInit: Set deserializer defaults
MAX96712 Link 0: PHY optimization was enabled
DEVBLK_WORKER_0: CNvMMax96712.cpp: 199: DoInit: Get deserializer revision
DEVBLK_WORKER_0: CNvMMax96712.cpp: 211: DoInit: Set MIPI output mode
DEVBLK_WORKER_0: CNvMMAX96712CameraModule.cpp: 35: Init: ZHC_TEST:CNvMMAX96712CameraModule: m_pDeserializer->EnableLinks 0
DEVBLK_WORKER_0: CNvMMax96712.cpp: 271: EnableLinks: Enabling links
DEVBLK_WORKER_0: CNvMMAX96712CameraModule.cpp: 120: Init: ZHC_TEST: MAX96712: Init Done 0
Main: /dvs/git/dirty/git-master_qnx/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 205: WorkersDoAction: All worker threads finished action:1
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
Jan 01 02:50:42.815 nvsipl_camera.3166304..1 0 -----ONLINE-----
Jan 01 02:50:42.815 nvsipl_camera.3166304..1 slog* 0 MAX96712: Revision 5 detected
Jan 01 02:50:42.822 nvsipl_camera.3166304..1 slog 0 MAX96712 Link 0: PHY optimization was enabled
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera* 10031 src/devblk/common/core/CNvMDeviceBlock.cpp: 883
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 DevBlkCDIRootDeviceCheckAndClearIntr with NvMedia error: 7
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 501
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Device block init failed. Status:: 0x00000a
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 197
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Device block action failed for action: 1
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 198
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Device block action failed for block: 0
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMDeviceBlockMgr.cpp: 230
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 Failed to initialize device blocks
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 src/core/CNvMCamera.cpp: 596
Jan 01 02:50:42.974 nvsipl_camera.3166304..0 nvsipl_camera 10031 DeviceBlock manager init failed
Jan 01 02:50:42.974 devm_cdac.1052751 devm-cdac 10031 LOW-transitioning interrupt pin is not at the HIGH logic level: 16
Jan 01 02:50:42.974 devm_cdac.1052751 devm-cdac 10031 Failed to execute GPIO check and clear intr devctl: 16
Jan 01 02:50:42.974 nvsipl_camera.3166304..1 slog 0 cdiRootDevCheckAndClearIntr: failed to check and clear edge intr via devctl
- Is .“/nv-qnx-52120-standard/drive-t186ref-qnx/samples/nvmedia/nvsipl/devblk/devices/MAX96712DeserializerDriver” compiled in another location?
We try to modify MAX96712DeserializerDriver and replace the libnvsipl_devblk_drv_xxx.so, but there is no use.
Look forward to your reply.
