Hey
I need to get the bboxIds and I have tried to get them by using the annotor example for them and then trying to save it. Here is the code I tried it with
with rep.trigger.on_frame(num_frames=30000) as trigger:
while trigger:
ssd.SyntheticData.Get().set_instance_mapping_semantic_filter("class:bolt")
bbox_2d_loose = rep.AnnotatorRegistry.annotate("bounding_box_2d_loose")
bbox_2d_loose.attach(render_product)
bbox_2d_tight = rep.AnnotatorRegistry.get_annotator("bounding_box_2d_tight")
bbox_2d_tight.attach(render_product)
bbox_3d = rep.AnnotatorRegistry.get_annotator("bounding_box_3d")
bbox_3d.attach(render_product)
data_folder_path = "/home/sdtc-develop/francesco/dataset_6d_pose_estimation/isaac_source_data/writing_sem_test"
data = bbox_2d_loose.get_data()
data1 = bbox_2d_tight.get_data()
data2 = bbox_3d.get_data()
data = data1[data1]
data_name = f"semantic_segmentation_single_{i}.txt"
data_save_path = os.path.join(data_folder_path, data_name)
np.savetxt(data_save_path, data)
I am using isaac sim and replicator to greate a data set with the basic writer
and now I have troubles saving the bboxIds. It says that the data generated by this script is empty, 0 dimensional array, while the images are generated and saved correctly.
