Getting current TSC hardware timestamp in user space
we’re attempting to measure the latency between a stereo camera’s Start Of Frame and various other components down the pipeline.
We’re comparing against the getSensorSofTimestampTsc and getSensorSofTimestampTsc2 values provided by Jetson Linux API Reference: Argus::Ext::ISensorTimestampTsc Class Reference | NVIDIA Docs
We’ve seen How to get the clock source offset_ns on Jetpack 6 but don’t want to go via other clocks as we’ve noted they’re unstable similar to Clock source not stable - #5 by alexcekay-aut
Is the following code the best option for getting the current TSC timestamp on the latest JetPack 6 or is there an API for it?
uint64_t getTscNow()
  unsigned long cycles, frequency;
  asm volatile("mrs %0, cntfrq_el0" : "=r"(frequency));
  asm volatile("mrs %0, cntvct_el0" : "=r"(cycles));
  return (cycles * 100 / (frequency / 10000)) * 1000;
Thanks in advance!
hello janne.husberg1,
FYI, starting from JP-6.0, the Generic Timestamp Engine (GTE) driver has been marked as deprecated and replaced by the Hardware Timestamp Engine (HTE) from the upstream kernel.
you may see-also Topic 303499 for reference.
