Hello,everyone. I am using kernel version 28.2 now. I have collected 500M10 frames (Gigabit Ethernet) of GIGE camera of dalasa, but there will be streaks on the image. I saved the image frame by frame and found that the acquisition driver has problems. But the same time I am on a PC, UBUNTU acquisition has no stripes. I adjusted the resolution to 640X480, and there is no stripe on the card side. Does the network driver of the board need to be adjusted? Still need to change to TX2?
Please check
There is an issue in R28.1 and we have fixed it in R28.2. You may run iperf and check if the result meets expectation.
