`$ cat Xorg.0.log
[ 6.984] (–) Log file renamed from “/var/log/Xorg.pid-5548.log” to “/var/log/Xorg.0.log”
[ 6.986]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 6.986] X Protocol Version 11, Revision 0
[ 6.986] Build Operating System: Linux 4.4.0-168-generic aarch64 Ubuntu
[ 6.986] Current Operating System: Linux bms971svrp01 4.9.140-tegra #1 SMP PREEMPT Wed Apr 8 18:10:49 PDT 2020 aarch64
[ 6.986] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 6.987] Build Date: 14 November 2019 06:20:13PM
[ 6.987] xorg-server 2:1.19.6-1ubuntu4.4 (For technical support please see Enterprise open source support | Ubuntu)
[ 6.987] Current version of pixman: 0.34.0
[ 6.987] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 6.987] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 6.987] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed May 6 10:42:59 2020
[ 6.988] (==) Using config file: “/etc/X11/xorg.conf”
[ 6.988] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 6.992] (==) No Layout section. Using the first Screen section.
[ 6.992] (==) No screen section available. Using defaults.
[ 6.992] () |–>Screen “Default Screen Section” (0)
[ 6.992] () | |–>Monitor “”
[ 6.993] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 6.993] () | |–>Device “Tegra0”
[ 6.993] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 6.993] (==) Automatically adding devices
[ 6.993] (==) Automatically enabling devices
[ 6.993] (==) Automatically adding GPU devices
[ 6.993] (==) Automatically binding GPU devices
[ 6.993] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7.000] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 7.000] Entry deleted from font path.
[ 7.000] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 7.000] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 7.004] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 7.004] Entry deleted from font path.
[ 7.004] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 7.004] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 7.004] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 7.004] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 7.004] (II) Loader magic: 0x5588609010
[ 7.004] (II) Module ABI versions:
[ 7.004] X.Org ANSI C Emulation: 0.4
[ 7.004] X.Org Video Driver: 23.0
[ 7.004] X.Org XInput driver : 24.1
[ 7.004] X.Org Server Extension : 10.0
[ 7.006] (++) using VT number 1
[ 7.010] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 7.012] (II) no primary bus or device found
[ 7.012] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 7.012] (II) “glx” will be loaded by default.
[ 7.012] (II) LoadModule: “extmod”
[ 7.012] (II) Module “extmod” already built-in
[ 7.012] (II) LoadModule: “glx”
[ 7.013] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.047] (II) Module glx: vendor=“X.Org Foundation”
[ 7.047] compiled for 1.19.6, module version = 1.0.0
[ 7.047] ABI class: X.Org Server Extension, version 10.0
[ 7.047] (II) LoadModule: “nvidia”
[ 7.049] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.076] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 7.076] compiled for 4.0.2, module version = 1.0.0
[ 7.076] Module class: X.Org Video Driver
[ 7.094] (II) NVIDIA dlloader X Driver 32.4.2 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4164) Wed Apr 8 18:12:28 PDT 2020
[ 7.094] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.094] (WW) Falling back to old probe method for NVIDIA
[ 7.095] (II) Loading sub module “fb”
[ 7.095] (II) LoadModule: “fb”
[ 7.099] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.102] (II) Module fb: vendor=“X.Org Foundation”
[ 7.102] compiled for 1.19.6, module version = 1.0.0
[ 7.102] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.102] (II) Loading sub module “wfb”
[ 7.102] (II) LoadModule: “wfb”
[ 7.103] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.105] (II) Module wfb: vendor=“X.Org Foundation”
[ 7.105] compiled for 1.19.6, module version = 1.0.0
[ 7.105] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.105] (II) Loading sub module “ramdac”
[ 7.105] (II) LoadModule: “ramdac”
[ 7.106] (II) Module “ramdac” already built-in
[ 7.107] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 7.107] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 7.107] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 7.107] (==) NVIDIA(0): RGB weight 888
[ 7.107] (==) NVIDIA(0): Default visual is TrueColor
[ 7.107] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.107] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 7.107] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 7.107] () NVIDIA(0): Enabling 2D acceleration
[ 7.107] (II) Loading sub module “glxserver_nvidia”
[ 7.107] (II) LoadModule: “glxserver_nvidia”
[ 7.108] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 7.370] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 7.370] compiled for 4.0.2, module version = 1.0.0
[ 7.370] Module class: X.Org Server Extension
[ 7.370] (II) NVIDIA GLX Module 32.4.2 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4164) Wed Apr 8 18:10:45 PDT 2020
[ 7.471] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 7.471] (–) NVIDIA(0): DFP-0
[ 7.471] (–) NVIDIA(0): DFP-1
[ 7.472] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (GM20B) at SoC (GPU-0)
[ 7.472] (–) NVIDIA(0): Memory: 4059412 kBytes
[ 7.472] (–) NVIDIA(0): VideoBIOS:
[ 7.472] (==) NVIDIA(0):
[ 7.472] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 7.472] (==) NVIDIA(0): will be used as the requested mode.
[ 7.472] (–) NVIDIA(0): No enabled display devices found; starting anyway because
[ 7.472] (–) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 7.472] (II) NVIDIA(0): Validated MetaModes:
[ 7.472] (II) NVIDIA(0): “NULL”
[ 7.472] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 7.472] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 7.472] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 7.472] (–) Depth 24 pixmap format is 32 bpp
[ 7.472] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 7.473] (II) NVIDIA: access.
[ 7.476] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 7.476] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 7.476] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 7.476] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 7.476] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 7.476] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 7.476] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 7.476] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 7.476] (II) NVIDIA(0): Config Options in the README.
[ 7.531] (II) NVIDIA(0): Setting mode “NULL”
[ 7.534] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 7.534] (==) NVIDIA(0): Backing store enabled
[ 7.534] (==) NVIDIA(0): Silken mouse enabled
[ 7.535] (==) NVIDIA(0): DPMS enabled
[ 7.535] (II) Loading sub module “dri2”
[ 7.535] (II) LoadModule: “dri2”
[ 7.535] (II) Module “dri2” already built-in
[ 7.535] (II) NVIDIA(0): [DRI2] Setup complete
[ 7.535] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 7.535] (–) RandR disabled
[ 7.543] (II) SELinux: Disabled on system
[ 7.544] (II) Initializing extension GLX
[ 7.544] (II) Indirect GLX disabled.
[ 7.705] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 7.705] (II) No input driver specified, ignoring this device.
[ 7.705] (II) This device may have been added with another device file.
[ 7.707] (II) config/udev: Adding input device Lite-On Tech IBM USB Keyboard with UltraNav (/dev/input/event2)
[ 7.707] () Lite-On Tech IBM USB Keyboard with UltraNav: Applying InputClass “libinput keyboard catchall”
[ 7.707] (II) LoadModule: “libinput”
[ 7.708] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.720] (II) Module libinput: vendor=“X.Org Foundation”
[ 7.720] compiled for 1.19.6, module version = 0.27.1
[ 7.720] Module class: X.Org XInput Driver
[ 7.720] ABI class: X.Org XInput driver, version 24.1
[ 7.720] (II) Using input driver ‘libinput’ for ‘Lite-On Tech IBM USB Keyboard with UltraNav’
[ 7.722] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 33 paused 0
[ 7.722] () Lite-On Tech IBM USB Keyboard with UltraNav: always reports core events
[ 7.722] () Option “Device” “/dev/input/event2”
[ 7.722] () Option “_source” “server/udev”
[ 7.724] (II) event2 - Lite-On Tech IBM USB Keyboard with UltraNav: is tagged by udev as: Keyboard
[ 7.724] (II) event2 - Lite-On Tech IBM USB Keyboard with UltraNav: device is a keyboard
[ 7.724] (II) event2 - Lite-On Tech IBM USB Keyboard with UltraNav: device removed
[ 7.724] () Option “config_info” “udev:/sys/devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.0/0003:04B3:3018.0001/input/input2/event2”
[ 7.724] (II) XINPUT: Adding extended input device “Lite-On Tech IBM USB Keyboard with UltraNav” (type: KEYBOARD, id 6)
[ 7.725] () Option “xkb_model” “pc105”
[ 7.725] () Option “xkb_layout” “de”
[ 7.768] (II) event2 - Lite-On Tech IBM USB Keyboard with UltraNav: is tagged by udev as: Keyboard
[ 7.768] (II) event2 - Lite-On Tech IBM USB Keyboard with UltraNav: device is a keyboard
[ 7.770] (II) config/udev: Adding input device Lite-On Tech IBM USB Keyboard with UltraNav (/dev/input/event3)
[ 7.770] () Lite-On Tech IBM USB Keyboard with UltraNav: Applying InputClass “libinput keyboard catchall”
[ 7.770] (II) Using input driver ‘libinput’ for ‘Lite-On Tech IBM USB Keyboard with UltraNav’
[ 7.772] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 36 paused 0
[ 7.772] () Lite-On Tech IBM USB Keyboard with UltraNav: always reports core events
[ 7.772] () Option “Device” “/dev/input/event3”
[ 7.772] () Option “_source” “server/udev”
[ 7.774] (II) event3 - Lite-On Tech IBM USB Keyboard with UltraNav: is tagged by udev as: Keyboard
[ 7.774] (II) event3 - Lite-On Tech IBM USB Keyboard with UltraNav: device is a keyboard
[ 7.774] (II) event3 - Lite-On Tech IBM USB Keyboard with UltraNav: device removed
[ 7.774] () Option “config_info” “udev:/sys/devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.1/0003:04B3:3018.0002/input/input3/event3”
[ 7.774] (II) XINPUT: Adding extended input device “Lite-On Tech IBM USB Keyboard with UltraNav” (type: KEYBOARD, id 7)
[ 7.774] () Option “xkb_model” “pc105”
[ 7.774] () Option “xkb_layout” “de”
[ 7.776] (II) event3 - Lite-On Tech IBM USB Keyboard with UltraNav: is tagged by udev as: Keyboard
[ 7.776] (II) event3 - Lite-On Tech IBM USB Keyboard with UltraNav: device is a keyboard
[ 7.777] (II) config/udev: Adding input device Synaptics Inc. Composite TouchPad / TrackPoint (/dev/input/event4)
[ 7.778] () Synaptics Inc. Composite TouchPad / TrackPoint: Applying InputClass “libinput touchpad catchall”
[ 7.778] (II) Using input driver ‘libinput’ for ‘Synaptics Inc. Composite TouchPad / TrackPoint’
[ 7.779] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 37 paused 0
[ 7.779] () Synaptics Inc. Composite TouchPad / TrackPoint: always reports core events
[ 7.779] () Option “Device” “/dev/input/event4”
[ 7.779] () Option “_source” “server/udev”
[ 7.781] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: is tagged by udev as: Touchpad
[ 7.781] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: no resolution or size hints, assuming a size of 69x50mm
[ 7.781] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: device is a touchpad
[ 7.781] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: device removed
[ 7.782] () Option “config_info” “udev:/sys/devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.0/input/input4/event4”
[ 7.782] (II) XINPUT: Adding extended input device “Synaptics Inc. Composite TouchPad / TrackPoint” (type: TOUCHPAD, id 8)
[ 7.782] () Option “AccelerationScheme” “none”
[ 7.782] () Synaptics Inc. Composite TouchPad / TrackPoint: (accel) selected scheme none/0
[ 7.782] () Synaptics Inc. Composite TouchPad / TrackPoint: (accel) acceleration factor: 2.000
[ 7.782] () Synaptics Inc. Composite TouchPad / TrackPoint: (accel) acceleration threshold: 4
[ 7.783] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: is tagged by udev as: Touchpad
[ 7.783] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: no resolution or size hints, assuming a size of 69x50mm
[ 7.783] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: device is a touchpad
[ 7.785] (II) config/udev: Adding input device Synaptics Inc. Composite TouchPad / TrackPoint (/dev/input/mouse0)
[ 7.785] (II) No input driver specified, ignoring this device.
[ 7.785] (II) This device may have been added with another device file.
[ 7.786] (II) config/udev: Adding input device Synaptics Inc. Composite TouchPad / TrackPoint (Stick) (/dev/input/event5)
[ 7.786] () Synaptics Inc. Composite TouchPad / TrackPoint (Stick): Applying InputClass “libinput pointer catchall”
[ 7.787] (II) Using input driver ‘libinput’ for ‘Synaptics Inc. Composite TouchPad / TrackPoint (Stick)’
[ 7.788] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 38 paused 0
[ 7.788] () Synaptics Inc. Composite TouchPad / TrackPoint (Stick): always reports core events
[ 7.788] () Option “Device” “/dev/input/event5”
[ 7.788] () Option “_source” “server/udev”
[ 7.790] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): is tagged by udev as: Mouse Pointingstick
[ 7.790] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): trackpoint device set to range 31
[ 7.790] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): device is a pointer
[ 7.790] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): device removed
[ 7.790] () Option “config_info” “udev:/sys/devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.1/input/input5/event5”
[ 7.790] (II) XINPUT: Adding extended input device “Synaptics Inc. Composite TouchPad / TrackPoint (Stick)” (type: MOUSE, id 9)
[ 7.791] () Option “AccelerationScheme” “none”
[ 7.791] () Synaptics Inc. Composite TouchPad / TrackPoint (Stick): (accel) selected scheme none/0
[ 7.791] () Synaptics Inc. Composite TouchPad / TrackPoint (Stick): (accel) acceleration factor: 2.000
[ 7.791] () Synaptics Inc. Composite TouchPad / TrackPoint (Stick): (accel) acceleration threshold: 4
[ 7.792] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): is tagged by udev as: Mouse Pointingstick
[ 7.792] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): trackpoint device set to range 31
[ 7.792] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): device is a pointer
[ 7.793] (II) config/udev: Adding input device Synaptics Inc. Composite TouchPad / TrackPoint (Stick) (/dev/input/mouse1)
[ 7.794] (II) No input driver specified, ignoring this device.
[ 7.794] (II) This device may have been added with another device file.
[ 7.794] (II) config/udev: Adding input device gpio-keys (/dev/input/event1)
[ 7.794] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 7.794] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 7.796] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 39 paused 0
[ 7.796] () gpio-keys: always reports core events
[ 7.796] () Option “Device” “/dev/input/event1”
[ 7.796] () Option “_source” “server/udev”
[ 7.797] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 7.797] (II) event1 - gpio-keys: device is a keyboard
[ 7.797] (II) event1 - gpio-keys: device removed
[ 7.797] () Option “config_info” “udev:/sys/devices/gpio-keys/input/input1/event1”
[ 7.797] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 10)
[ 7.797] () Option “xkb_model” “pc105”
[ 7.797] () Option “xkb_layout” “de”
[ 7.799] (II) event1 - gpio-keys: is tagged by udev as: Keyboard
[ 7.799] (II) event1 - gpio-keys: device is a keyboard
[ 72.544] (–) NVIDIA(GPU-0): Lenovo Group Limited LEN LT2452pwC (DFP-0): connected
[ 72.544] (–) NVIDIA(GPU-0): Lenovo Group Limited LEN LT2452pwC (DFP-0): External TMDS
[ 72.553] (II) NVIDIA(0): Setting mode “NULL”
[ 72.603] (–) NVIDIA(GPU-0): Lenovo Group Limited LEN LT2452pwC (DFP-0): connected
[ 72.603] (–) NVIDIA(GPU-0): Lenovo Group Limited LEN LT2452pwC (DFP-0): External TMDS
[ 72.638] (II) NVIDIA(0): Setting mode “HDMI-0: nvidia-auto-select @1920x1200 +0+0 {AllowGSYNC=Off, ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}”
[ 72.787] (–) NVIDIA(GPU-0): Lenovo Group Limited LEN LT2452pwC (DFP-0): connected
[ 72.787] (–) NVIDIA(GPU-0): Lenovo Group Limited LEN LT2452pwC (DFP-0): External TMDS
[ 85.426] () Option “fd” “33”
[ 85.426] (II) event2 - Lite-On Tech IBM USB Keyboard with UltraNav: device removed
[ 85.427] () Option “fd” “36”
[ 85.427] (II) event3 - Lite-On Tech IBM USB Keyboard with UltraNav: device removed
[ 85.428] () Option “fd” “37”
[ 85.428] (II) event4 - Synaptics Inc. Composite TouchPad / TrackPoint: device removed
[ 85.429] () Option “fd” “38”
[ 85.429] (II) event5 - Synaptics Inc. Composite TouchPad / TrackPoint (Stick): device removed
[ 85.429] () Option “fd” “39”
[ 85.429] (II) event1 - gpio-keys: device removed
[ 85.516] (II) systemd-logind: got pause for 13:68
[ 85.516] (II) systemd-logind: got pause for 13:69
[ 85.516] (II) systemd-logind: got pause for 13:65
[ 85.516] (II) systemd-logind: got pause for 13:66
[ 85.516] (II) systemd-logind: got pause for 13:67
[ 85.517] (II) libinput: Synaptics Inc. Composite TouchPad / TrackPoint (Stick): SetProperty on 304 called but device is disabled.
This driver cannot change properties on a disabled device
[ 85.517] (II) libinput: Synaptics Inc. Composite TouchPad / TrackPoint (Stick): SetProperty on 297 called but device is disabled.
[ 85.520] (II) libinput: Synaptics Inc. Composite TouchPad / TrackPoint (Stick): SetProperty on 306 called but device is disabled.
[ 85.521] (II) libinput: Synaptics Inc. Composite TouchPad / TrackPoint (Stick): SetProperty on 306 called but device is disabled.
[ 85.521] (II) libinput: Synaptics Inc. Composite TouchPad / TrackPoint (Stick): SetProperty on 275 called but device is disabled.
[160702.686] (II) UnloadModule: “libinput”
[160702.713] (II) systemd-logind: releasing fd for 13:65
[160705.733] (II) UnloadModule: “libinput”
[160705.733] (II) systemd-logind: releasing fd for 13:69
[160705.773] (II) UnloadModule: “libinput”
[160705.774] (II) systemd-logind: releasing fd for 13:68
[160705.788] (II) UnloadModule: “libinput”
[160705.789] (II) systemd-logind: releasing fd for 13:67
[160705.813] (II) UnloadModule: “libinput”
[160705.813] (II) systemd-logind: releasing fd for 13:66
[160705.841] (II) NVIDIA(GPU-0): Deleting GPU-0
[160705.843] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[160705.843] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[160705.843] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[160705.849] (II) Server terminated successfully (0). Closing log file.`
