I’m trying to render through my GPU in blender but in Edit>Preferences>System under CUDA I get a message saying “No compatible GPUs found for Cycles Requires NVIDIA GPU with compute capability 3.0.”
My GPU is a GeForce GTX 670 which according to NVIDIA’s website is compute 3.0 compatible. My driver is nvidia-driver-470 version 470.161.03-0ubuntu0.22.04.1and I’m running a fairly fresh install of Linux Mint 21.1. and blender 3.0.1 and im quite new to both.
I have tried the 3 GPU drivers available in driver manager (NVIDIA 390.157 and xserver-xord-video-nouveau 1:1.0.17-2build1) someone recommend I activate openGL and openCL I think I have done this but am not sure how to check.
I have posted on the Blender Stack Exchange and they told me to try here. So hoping someone can point me in the right direction.
System:
Kernel: 5.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.6.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Machine:
Type: Desktop System: Dell product: Precision WorkStation T5400 v: N/A
serial: <superuser required>
Mobo: Dell model: 0RW203 serial: <superuser required> BIOS: Dell v: A11
date: 04/30/2012
Memory:
RAM: total: 7.76 GiB used: 3.4 GiB (43.8%)
RAM Report:
permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: 2x 4-core model: Intel Xeon E5450 bits: 64 type: MCP SMP
arch: Core Yorkfield rev: 6 cache: L1: 2x 256 KiB (512 KiB)
L2: 2x 12 MiB (24 MiB)
Speed (MHz): avg: 2881 high: 2993 min/max: N/A cores: 1: 2993 2: 2993
3: 2993 4: 2993 5: 2104 6: 2993 7: 2993 8: 2993 bogomips: 47883
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3
Graphics:
Device-1: NVIDIA GK104 [GeForce GTX 670] vendor: ASUSTeK driver: nvidia
v: 470.161.03 bus-ID: 02:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 670/PCIe/SSE2
v: 4.6.0 NVIDIA 470.161.03 direct render: Yes
Audio:
Device-1: Intel 631xESB/632xESB High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK104 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 02:00.1
Sound Server-1: ALSA v: k5.15.0-58-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Broadcom NetXtreme BCM5754 Gigabit Ethernet PCI Express
vendor: Dell Precision T5400 driver: tg3 v: kernel port: N/A
bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 1.35 TiB used: 52.13 GiB (3.8%)
ID-1: /dev/sda vendor: Hitachi model: HUA721010KLA330 size: 931.51 GiB
ID-2: /dev/sdb vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB
Partition:
ID-1: / size: 438.55 GiB used: 52.13 GiB (11.9%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 512 MiB used: 5.2 MiB (1.0%) fs: vfat
dev: /dev/sdb2
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): cpu: 809 mobo: 1422 gpu: nvidia fan: 10%
Repos:
Packages: 2757
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/graphics-drivers-ppa-jammy.list
1: deb [arch=amd64 signed-by=/etc/apt/keyrings/graphics-drivers-ppa-jammy.gpg] https://ppa.launchpadcontent.net/graphics-drivers/ppa/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb https://mirror.init7.net/linuxmint vera main upstream import backport
2: deb http://mirror.ox.ac.uk/sites/archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http://mirror.ox.ac.uk/sites/archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http://mirror.ox.ac.uk/sites/archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Info:
Processes: 275 Uptime: 2h 15m Init: systemd runlevel: 5 Compilers:
gcc: 11.3.0 Shell: Bash v: 5.1.16 inxi: 3.3.13
mike@mike-Precision-WorkStation-T5400:~$ nvidia-smi
Tue Jan 17 15:31:37 2023
| NVIDIA-SMI 470.161.03 Driver Version: 470.161.03 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:02:00.0 N/A | N/A |
| 10% 37C P8 N/A / N/A | 338MiB / 1998MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
mike@mike-Precision-WorkStation-T5400:~$ glxinfo | grep OpenGL
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 670/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.161.03
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 470.161.03
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.161.03
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:```
