I have a Jetson Nano running Jetpack 4.5 from USB with a picam2. I’m running a deepstream pipeline using nvargus that is based on the python demo deepstream-test1. Prior to running my application I always restart the nvargus-daemon service. However, my application runs into an End-of-Stream and shuts down unexpectedly. Sometimes it will only run for a couple of minutes, and sometimes it runs for about half an hour. I’m not sure if this a hardware problem, an nvargus issue, or something about how I’ve set up my queues. Here is an excerpt from my logs:
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
2021-04-06 11:20:10.270369: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully
opened dynamic library libcublas.so.10
2021-04-06 11:20:12.481668: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
04-06:11:20:53,445 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:20:57,732 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:20:58,816 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:00,867 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:01,889 INFO [mqtt_client.py:86] Occupany published to AWS
CONSUMER: Done Success
04-06:11:21:03,878 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:05,847 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:07,815 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:09,796 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:11,752 INFO [mqtt_client.py:86] Occupany published to AWS
04-06:11:21:13,660 INFO [mqtt_client.py:86] Occupany published to AWS
End-of-stream
04-06:11:21:13,692 INFO [main.py:716] Cleaning up
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
04-06:11:23:24,917 INFO [main.py:718] quiting loop
04-06:11:23:24,917 INFO [main.py:720] Done cleaning up.
04-06:11:23:24,918 INFO [main.py:721] exiting from cleanup
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
Any guidance on how to trouble shoot this is much appreciated. I can post relevant excerpts from my code if needed.
