Hey,
Getting this error and then stops encoding:
0:00:03.404924665 20620 0x72102a30 WARN v4l2allocator gstv4l2allocator.c:1372:gst_v4l2_allocator_dqbuf:x264enc:pool:src:allocator V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.078745802 e[335m13858e[00m 0x71905c30 e[33;01mLOG e[00m e[00m v4l2allocator gstv4l2allocator.c:1333:gst_v4l2_allocator_dqbuf:<x264enc:pool:src:allocator>e[00m dequeued buffer 1 (flags 0x4001)
0:00:01.078766427 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;01;31;44m GST_PADS gstpad.c:4077:gst_pad_query:<srtsink0:sink>e[00m sent query 0x72b08090 (caps), result 1
0:00:01.078780437 e[335m13858e[00m 0x71905c30 e[33;01mLOG e[00m e[00m v4l2allocator gstv4l2allocator.c:1362:gst_v4l2_allocator_dqbuf:<x264enc:pool:src:allocator>e[00m Dequeued capture buffer, length: 524288 bytesused: 0 data_offset: 0
0:00:01.078816114 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;04m default gstutils.c:2769:query_caps_func:<queue3:src>e[00m intersect with result application/x-rtp, media=(string)video, payload=(int)[ 96, 127 ], clock-rate=(int)90000, encoding-name=(string)H264
0:00:01.078839499 e[335m13858e[00m 0x71905c30 e[33;01mWARN e[00m e[00m v4l2allocator gstv4l2allocator.c:1372:gst_v4l2_allocator_dqbuf:<x264enc:pool:src:allocator>e[00m V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.078877364 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;04m default gstutils.c:2771:query_caps_func:<queue3:src>e[00m intersected application/x-rtp, media=(string)video, payload=(int)[ 96, 127 ], clock-rate=(int)90000, encoding-name=(string)H264
0:00:01.078934707 e[335m13858e[00m 0x71905c30 e[33;01mLOG e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:1260:gst_v4l2_buffer_pool_dqbuf:<x264enc:pool:src>e[00m dequeued buffer 0x71817e90 seq:0 (ix=1), mem 0x71902058 used 0, plane=0, flags 00004001, ts 0:00:00.185658000, pool-queued=3, buffer=0x71817e90
0:00:01.078951374 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;01;31;44m GST_PADS gstpad.c:3438:gst_pad_query_default:<queue3:sink>e[00m not forwarding 0x72b08090 (caps) query
0:00:01.078965801 e[335m13858e[00m 0x71905c30 e[37mDEBUG e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:1464:gst_v4l2_buffer_pool_release_buffer:<x264enc:pool:src>e[00m release buffer 0x71817e90
0:00:01.078991946 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;01;31;44m GST_PADS gstpad.c:4077:gst_pad_query:<queue3:sink>e[00m sent query 0x72b08090 (caps), result 1
0:00:01.079043404 e[335m13858e[00m 0x71905c30 e[33;01mLOG e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:1147:gst_v4l2_buffer_pool_qbuf:<x264enc:pool:src>e[00m queuing buffer 1
0:00:01.079044863 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;01;34m GST_CAPS gstutils.c:3111:gst_pad_peer_query_caps:<rtp:src>e[00m peer query returned application/x-rtp, media=(string)video, payload=(int)[ 96, 127 ], clock-rate=(int)90000, encoding-name=(string)H264
0:00:01.079116841 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;01;37;41m GST_PERFORMANCE gstcaps.c:178:_gst_caps_copy:e[00m doing copy 0x9b2e50 -> 0x72b09a50
0:00:01.079148143 e[335m13858e[00m 0x71905c30 e[33;01mLOG e[00m e[00m v4l2allocator gstv4l2allocator.c:1286:gst_v4l2_allocator_qbuf:<x264enc:pool:src:allocator>e[00m queued buffer 1 (flags 0x4003)
0:00:01.079158872 e[335m13858e[00m 0x9bd2f0 e[37mDEBUG e[00m e[00;01;37;41m GST_PERFORMANCE gstminiobject.c:428:gst_mini_object_make_writable:e[00m copy GstCaps miniobject 0x9b2e50 -> 0x72b09a50
0:00:01.079179393 e[335m13858e[00m 0x71905c30 e[37mDEBUG e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:2073:gst_v4l2_buffer_pool_process:<x264enc:pool:src>e[00m end of stream reached
