Hello again,
I’m sorry for late answer, I had solve other problems.
I am currently working on this mode.
If I using v4l:
v4l2-ctl -w --verbose --set-fmt-video=width=1944,height=1097,pixelformat=RG12 --set-ctrl=bypass_mode=0 --stream-mmap -d /dev/video0 --stream-count=10 --set-ctrl=sensor_modes=0
I receive a right data and have a good trace:
kworker/0:2-3191 [000] .... 146.751484: rtos_queue_peek_from_isr_failed: tstamp:4963279293 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 146.919472: rtos_queue_peek_from_isr_failed: tstamp:4968279343 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 147.087443: rtos_queue_peek_from_isr_failed: tstamp:4973279308 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 147.255470: rtos_queue_peek_from_isr_failed: tstamp:4978279316 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 147.423455: rtos_queue_peek_from_isr_failed: tstamp:4983279322 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 147.423466: rtos_queue_peek_from_isr_failed: tstamp:4984270901 queue:0x0b4b4500
v4l2-ctl-8379 [005] .... 161.167397: tegra_channel_open: vi-output, imx415 2-001a
v4l2-ctl-8379 [000] .... 161.168818: tegra_channel_set_power: imx415 2-001a : 0x1
v4l2-ctl-8379 [000] .... 161.169185: camera_common_s_power: status : 0x1
v4l2-ctl-8379 [000] .... 161.169321: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
v4l2-ctl-8379 [000] .... 161.169324: csi_s_power: enable : 0x1
v4l2-ctl-8379 [005] .... 161.227155: tegra_channel_capture_setup: vnc_id 0 W 1944 H 1097 fmt 20
vi-output, imx4-8384 [004] .... 161.227251: tegra_channel_set_stream: enable : 0x1
vi-output, imx4-8384 [004] .... 161.228486: tegra_channel_set_stream: 150c0000.nvcsi--2 : 0x1
vi-output, imx4-8384 [004] .... 161.228488: csi_s_stream: enable : 0x1
vi-output, imx4-8384 [004] .... 161.228524: tegra_channel_set_stream: imx415 2-001a : 0x1
kworker/0:2-3191 [000] .... 161.254573: rtos_queue_peek_from_isr_failed: tstamp:5416120152 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 161.254578: rtcpu_start: tstamp:5416121106
kworker/0:2-3191 [000] .... 161.254581: rtos_queue_send_from_isr_failed: tstamp:5416129361 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.254582: rtos_queue_send_from_isr_failed: tstamp:5416129467 queue:0x0b4aad68
kworker/0:2-3191 [000] .... 161.254583: rtos_queue_send_from_isr_failed: tstamp:5416129575 queue:0x0b4ac998
kworker/0:2-3191 [000] .... 161.254584: rtos_queue_send_from_isr_failed: tstamp:5416129681 queue:0x0b4ae518
kworker/0:2-3191 [000] .... 161.254585: rtos_queue_send_from_isr_failed: tstamp:5416129786 queue:0x0b4af2d8
kworker/0:2-3191 [000] .... 161.254586: rtos_queue_send_from_isr_failed: tstamp:5416129891 queue:0x0b4b0098
kworker/0:2-3191 [000] .... 161.254587: rtos_queue_send_from_isr_failed: tstamp:5416129999 queue:0x0b4b0e58
kworker/0:2-3191 [000] .... 161.254588: rtos_queue_send_from_isr_failed: tstamp:5416130103 queue:0x0b4b1c18
kworker/0:2-3191 [000] .... 161.254591: rtos_queue_send_failed: tstamp:5416130551 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.254593: rtos_queue_send_from_isr_failed: tstamp:5416132203 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.254594: rtos_queue_send_from_isr_failed: tstamp:5416132310 queue:0x0b4aad68
kworker/0:2-3191 [000] .... 161.254594: rtos_queue_send_from_isr_failed: tstamp:5416132416 queue:0x0b4ac998
kworker/0:2-3191 [000] .... 161.254595: rtos_queue_send_from_isr_failed: tstamp:5416132522 queue:0x0b4ae518
kworker/0:2-3191 [000] .... 161.254597: rtos_queue_send_from_isr_failed: tstamp:5416132627 queue:0x0b4af2d8
kworker/0:2-3191 [000] .... 161.254597: rtos_queue_send_from_isr_failed: tstamp:5416132732 queue:0x0b4b0098
kworker/0:2-3191 [000] .... 161.254598: rtos_queue_send_from_isr_failed: tstamp:5416132837 queue:0x0b4b0e58
kworker/0:2-3191 [000] .... 161.254599: rtos_queue_send_from_isr_failed: tstamp:5416132949 queue:0x0b4b1c18
kworker/0:2-3191 [000] .... 161.254600: rtos_queue_send_failed: tstamp:5416133811 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.366615: rtcpu_vinotify_event: tstamp:5418785071 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:5418784645 data:0x00000001
kworker/0:2-3191 [000] .... 161.422621: rtos_queue_peek_from_isr_failed: tstamp:5421120539 queue:0x0b4b4500
vi-output, imx4-8384 [003] .... 161.511182: tegra_channel_capture_frame: sof:161.16532450
kworker/0:2-3191 [000] .... 161.534611: rtcpu_vinotify_event: tstamp:5424989108 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:5424988701 data:0x00000000
kworker/0:2-3191 [000] .... 161.534616: rtcpu_vinotify_event: tstamp:5425006550 tag:CHANSEL_PXL_SOF channel:0x00 frame:7 vi_tstamp:5425006161 data:0x00000001
kworker/0:2-3191 [000] .... 161.534618: rtcpu_vinotify_event: tstamp:5425011886 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:7 vi_tstamp:5425011494 data:0x08000000
vi-output, imx4-8384 [003] .... 161.544255: tegra_channel_capture_frame: sof:161.49620706
vi-output, imx4-8384 [003] .... 161.577363: tegra_channel_capture_frame: sof:161.82709026
kworker/0:2-3191 [000] .... 161.590628: rtcpu_vinotify_event: tstamp:5426014406 tag:CHANSEL_PXL_EOF channel:0x00 frame:7 vi_tstamp:5426013717 data:0x04480002
kworker/0:2-3191 [000] .... 161.590636: rtcpu_vinotify_event: tstamp:5426014597 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:5426013730 data:0x00000000
kworker/0:2-3191 [000] .... 161.590638: rtcpu_vinotify_event: tstamp:5426023106 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:5426022709 data:0x00000000
kworker/0:2-3191 [000] .... 161.590641: rtcpu_vinotify_event: tstamp:5426040558 tag:CHANSEL_PXL_SOF channel:0x00 frame:8 vi_tstamp:5426040169 data:0x00000001
kworker/0:2-3191 [000] .... 161.590643: rtcpu_vinotify_event: tstamp:5426045299 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:8 vi_tstamp:5426044904 data:0x08000000
kworker/0:2-3191 [000] .... 161.590649: rtos_queue_peek_from_isr_failed: tstamp:5426120545 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 161.590651: rtcpu_vinotify_event: tstamp:5427048415 tag:CHANSEL_PXL_EOF channel:0x00 frame:8 vi_tstamp:5427047727 data:0x04480002
kworker/0:2-3191 [000] .... 161.590653: rtcpu_vinotify_event: tstamp:5427048610 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:5427047740 data:0x00000000
kworker/0:2-3191 [000] .... 161.590655: rtcpu_vinotify_event: tstamp:5427057112 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:5427056718 data:0x00000000
kworker/0:2-3191 [000] .... 161.590658: rtcpu_vinotify_event: tstamp:5427074576 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:5427074179 data:0x00000001
kworker/0:2-3191 [000] .... 161.590660: rtcpu_vinotify_event: tstamp:5427079970 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:9 vi_tstamp:5427079573 data:0x08000000
vi-output, imx4-8384 [003] .... 161.610479: tegra_channel_capture_frame: sof:161.115797282
vi-output, imx4-8384 [003] .... 161.643564: tegra_channel_capture_frame: sof:161.148885570
kworker/0:2-3191 [000] .... 161.646614: rtcpu_vinotify_event: tstamp:5428082429 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:5428081735 data:0x04480002
kworker/0:2-3191 [000] .... 161.646619: rtcpu_vinotify_event: tstamp:5428082618 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:5428081748 data:0x00000000
kworker/0:2-3191 [000] .... 161.646622: rtcpu_vinotify_event: tstamp:5428091114 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:5428090726 data:0x00000000
kworker/0:2-3191 [000] .... 161.646624: rtcpu_vinotify_event: tstamp:5428108572 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:5428108187 data:0x00000001
kworker/0:2-3191 [000] .... 161.646626: rtcpu_vinotify_event: tstamp:5428117447 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:10 vi_tstamp:5428117036 data:0x08000000
kworker/0:2-3191 [000] .... 161.646628: rtcpu_vinotify_event: tstamp:5429116455 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:5429115744 data:0x04480002
kworker/0:2-3191 [000] .... 161.646630: rtcpu_vinotify_event: tstamp:5429116663 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:5429115757 data:0x00000000
kworker/0:2-3191 [000] .... 161.646633: rtcpu_vinotify_event: tstamp:5429125125 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:5429124736 data:0x00000000
kworker/0:2-3191 [000] .... 161.646635: rtcpu_vinotify_event: tstamp:5429142581 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:5429142196 data:0x00000001
kworker/0:2-3191 [000] .... 161.646637: rtcpu_vinotify_event: tstamp:5429148814 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:11 vi_tstamp:5429148404 data:0x08000000
vi-output, imx4-8384 [003] .... 161.676634: tegra_channel_capture_frame: sof:161.181973826
kworker/0:1-786 [000] .... 161.702693: rtcpu_vinotify_event: tstamp:5430150447 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:5430149752 data:0x04480002
kworker/0:1-786 [000] .... 161.702699: rtcpu_vinotify_event: tstamp:5430150636 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:5430149766 data:0x00000000
kworker/0:1-786 [000] .... 161.702701: rtcpu_vinotify_event: tstamp:5430159136 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:5430158744 data:0x00000000
kworker/0:1-786 [000] .... 161.702703: rtcpu_vinotify_event: tstamp:5430176601 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:5430176204 data:0x00000001
kworker/0:1-786 [000] .... 161.702706: rtcpu_vinotify_event: tstamp:5430182221 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:5430181820 data:0x08000000
vi-output, imx4-8384 [003] .... 161.709773: tegra_channel_capture_frame: sof:161.215062146
vi-output, imx4-8384 [003] .... 161.742838: tegra_channel_capture_frame: sof:161.248150402
kworker/0:2-3191 [000] .... 161.758656: rtos_queue_peek_from_isr_failed: tstamp:5431120747 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 161.758666: rtcpu_vinotify_event: tstamp:5431184726 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:5431183762 data:0x04480002
kworker/0:2-3191 [000] .... 161.758669: rtcpu_vinotify_event: tstamp:5431185297 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:5431183775 data:0x00000000
kworker/0:2-3191 [000] .... 161.758672: rtcpu_vinotify_event: tstamp:5431193286 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:5431192753 data:0x00000000
kworker/0:2-3191 [000] .... 161.758675: rtcpu_vinotify_event: tstamp:5431210758 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:5431210214 data:0x00000001
kworker/0:2-3191 [000] .... 161.758679: rtcpu_vinotify_event: tstamp:5431218318 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:13 vi_tstamp:5431217723 data:0x08000000
kworker/0:2-3191 [000] .... 161.758682: rtcpu_vinotify_event: tstamp:5432218653 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:5432217770 data:0x04480002
kworker/0:2-3191 [000] .... 161.758685: rtcpu_vinotify_event: tstamp:5432219150 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:5432217783 data:0x00000000
kworker/0:2-3191 [000] .... 161.758691: rtcpu_vinotify_event: tstamp:5432227302 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:5432226761 data:0x00000000
kworker/0:2-3191 [000] .... 161.758694: rtcpu_vinotify_event: tstamp:5432244769 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:5432244222 data:0x00000001
kworker/0:2-3191 [000] .... 161.758697: rtcpu_vinotify_event: tstamp:5432251612 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:14 vi_tstamp:5432251013 data:0x08000000
vi-output, imx4-8384 [003] .... 161.776008: tegra_channel_capture_frame: sof:161.281238690
vi-output, imx4-8384 [003] .... 161.809043: tegra_channel_capture_frame: sof:161.314326946
kworker/0:2-3191 [000] .... 161.814661: rtcpu_vinotify_event: tstamp:5433252659 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:5433251779 data:0x04480002
kworker/0:2-3191 [000] .... 161.814673: rtcpu_vinotify_event: tstamp:5433253155 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:5433251792 data:0x00000000
kworker/0:2-3191 [000] .... 161.814676: rtcpu_vinotify_event: tstamp:5433261304 tag:ATOMP_FS channel:0x00 frame:15 vi_tstamp:5433260771 data:0x00000000
kworker/0:2-3191 [000] .... 161.814679: rtcpu_vinotify_event: tstamp:5433278774 tag:CHANSEL_PXL_SOF channel:0x00 frame:15 vi_tstamp:5433278231 data:0x00000001
kworker/0:2-3191 [000] .... 161.814683: rtcpu_vinotify_event: tstamp:5433288531 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:15 vi_tstamp:5433287865 data:0x08000000
kworker/0:2-3191 [000] .... 161.814686: rtcpu_vinotify_event: tstamp:5434286666 tag:CHANSEL_PXL_EOF channel:0x00 frame:15 vi_tstamp:5434285788 data:0x04480002
kworker/0:2-3191 [000] .... 161.814689: rtcpu_vinotify_event: tstamp:5434287156 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:5434285801 data:0x00000000
kworker/0:2-3191 [000] .... 161.814692: rtcpu_vinotify_event: tstamp:5434295316 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:5434294779 data:0x00000000
kworker/0:2-3191 [000] .... 161.814696: rtcpu_vinotify_event: tstamp:5434312789 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:5434312239 data:0x00000001
kworker/0:2-3191 [000] .... 161.814699: rtcpu_vinotify_event: tstamp:5434320609 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:16 vi_tstamp:5434320019 data:0x08000000
vi-output, imx4-8384 [003] .... 161.842111: tegra_channel_capture_frame: sof:161.347415234
kworker/0:2-3191 [000] .... 161.870634: rtcpu_vinotify_event: tstamp:5435320676 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:5435319797 data:0x04480002
kworker/0:2-3191 [000] .... 161.870644: rtcpu_vinotify_event: tstamp:5435321168 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:5435319810 data:0x00000000
kworker/0:2-3191 [000] .... 161.870647: rtcpu_vinotify_event: tstamp:5435329322 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:5435328788 data:0x00000000
kworker/0:2-3191 [000] .... 161.870651: rtcpu_vinotify_event: tstamp:5435346789 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:5435346248 data:0x00000001
kworker/0:2-3191 [000] .... 161.870654: rtcpu_vinotify_event: tstamp:5435353955 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:17 vi_tstamp:5435353294 data:0x08000000
kworker/0:2-3191 [000] .... 161.870666: rtos_queue_peek_from_isr_failed: tstamp:5436120753 queue:0x0b4b4500
vi-output, imx4-8384 [003] .... 161.875197: tegra_channel_capture_frame: sof:161.380503522
vi-output, imx4-8384 [003] .... 161.908272: tegra_channel_capture_frame: sof:161.413591810
kworker/0:2-3191 [000] .... 161.926654: rtcpu_vinotify_event: tstamp:5436354685 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:5436353806 data:0x04480002
kworker/0:2-3191 [000] .... 161.926665: rtcpu_vinotify_event: tstamp:5436355175 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:5436353819 data:0x00000000
kworker/0:2-3191 [000] .... 161.926668: rtcpu_vinotify_event: tstamp:5436363341 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:5436362796 data:0x00000000
kworker/0:2-3191 [000] .... 161.926672: rtcpu_vinotify_event: tstamp:5436380791 tag:CHANSEL_PXL_SOF channel:0x00 frame:18 vi_tstamp:5436380257 data:0x00000001
kworker/0:2-3191 [000] .... 161.926675: rtcpu_vinotify_event: tstamp:5436387922 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:18 vi_tstamp:5436387253 data:0x08000000
kworker/0:2-3191 [000] .... 161.926678: rtcpu_vinotify_event: tstamp:5437388692 tag:CHANSEL_PXL_EOF channel:0x00 frame:18 vi_tstamp:5437387814 data:0x04480002
kworker/0:2-3191 [000] .... 161.926681: rtcpu_vinotify_event: tstamp:5437389186 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:5437387827 data:0x00000000
kworker/0:2-3191 [000] .... 161.926685: rtcpu_vinotify_event: tstamp:5437397363 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:5437396806 data:0x00000000
kworker/0:2-3191 [000] .... 161.926688: rtcpu_vinotify_event: tstamp:5437414801 tag:CHANSEL_PXL_SOF channel:0x00 frame:19 vi_tstamp:5437414266 data:0x00000001
kworker/0:2-3191 [000] .... 161.926692: rtcpu_vinotify_event: tstamp:5437424645 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:19 vi_tstamp:5437424050 data:0x08000000
v4l2-ctl-8379 [003] .... 161.973653: tegra_channel_capture_done: eof:0.0
v4l2-ctl-8379 [005] .... 161.974803: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-8379 [005] .... 161.974816: tegra_channel_set_stream: imx415 2-001a : 0x0
v4l2-ctl-8379 [000] .... 161.977044: tegra_channel_set_stream: 150c0000.nvcsi--2 : 0x0
v4l2-ctl-8379 [000] .... 161.977063: csi_s_stream: enable : 0x0
kworker/0:2-3191 [000] .... 161.983055: rtcpu_vinotify_event: tstamp:5438422780 tag:CHANSEL_PXL_EOF channel:0x00 frame:19 vi_tstamp:5438421823 data:0x04480002
kworker/0:2-3191 [000] .... 161.983064: rtcpu_vinotify_event: tstamp:5438423345 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:5438421836 data:0x00000000
kworker/0:2-3191 [000] .... 161.983067: rtcpu_vinotify_event: tstamp:5438431369 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:5438430814 data:0x00000000
kworker/0:2-3191 [000] .... 161.983071: rtcpu_vinotify_event: tstamp:5438448811 tag:CHANSEL_PXL_SOF channel:0x00 frame:20 vi_tstamp:5438448275 data:0x00000001
kworker/0:2-3191 [000] .... 161.983074: rtcpu_vinotify_event: tstamp:5439456739 tag:CHANSEL_PXL_EOF channel:0x00 frame:20 vi_tstamp:5439455831 data:0x04480002
kworker/0:2-3191 [000] .... 161.983077: rtcpu_vinotify_event: tstamp:5439457230 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:5439455844 data:0x00000000
kworker/0:2-3191 [000] .... 161.983095: rtos_queue_send_from_isr_failed: tstamp:5439466355 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.983102: rtos_queue_send_from_isr_failed: tstamp:5439466814 queue:0x0b4aad68
kworker/0:2-3191 [000] .... 161.983108: rtos_queue_send_from_isr_failed: tstamp:5439467277 queue:0x0b4ac998
kworker/0:2-3191 [000] .... 161.983113: rtos_queue_send_from_isr_failed: tstamp:5439467733 queue:0x0b4ae518
kworker/0:2-3191 [000] .... 161.983118: rtos_queue_send_from_isr_failed: tstamp:5439468213 queue:0x0b4af2d8
kworker/0:2-3191 [000] .... 161.983123: rtos_queue_send_from_isr_failed: tstamp:5439468667 queue:0x0b4b0098
kworker/0:2-3191 [000] .... 161.983128: rtos_queue_send_from_isr_failed: tstamp:5439469122 queue:0x0b4b0e58
kworker/0:2-3191 [000] .... 161.983132: rtos_queue_send_from_isr_failed: tstamp:5439469579 queue:0x0b4b1c18
kworker/0:2-3191 [000] .... 161.983145: rtos_queue_send_failed: tstamp:5439471776 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.983151: rtos_queue_send_from_isr_failed: tstamp:5439483974 queue:0x0b4a7258
kworker/0:2-3191 [000] .... 161.983157: rtos_queue_send_from_isr_failed: tstamp:5439484563 queue:0x0b4aad68
kworker/0:2-3191 [000] .... 161.983161: rtos_queue_send_from_isr_failed: tstamp:5439485014 queue:0x0b4ac998
kworker/0:2-3191 [000] .... 161.983166: rtos_queue_send_from_isr_failed: tstamp:5439485477 queue:0x0b4ae518
kworker/0:2-3191 [000] .... 161.983171: rtos_queue_send_from_isr_failed: tstamp:5439485983 queue:0x0b4af2d8
kworker/0:2-3191 [000] .... 161.983175: rtos_queue_send_from_isr_failed: tstamp:5439486444 queue:0x0b4b0098
kworker/0:2-3191 [000] .... 161.983180: rtos_queue_send_from_isr_failed: tstamp:5439486897 queue:0x0b4b0e58
kworker/0:2-3191 [000] .... 161.983185: rtos_queue_send_from_isr_failed: tstamp:5439487361 queue:0x0b4b1c18
kworker/0:2-3191 [000] .... 161.983190: rtos_queue_send_failed: tstamp:5439489219 queue:0x0b4a7258
v4l2-ctl-8379 [000] .... 161.987659: tegra_channel_close: vi-output, imx415 2-001a
v4l2-ctl-8379 [000] .... 161.992472: tegra_channel_set_power: imx415 2-001a : 0x0
v4l2-ctl-8379 [000] .... 161.992970: camera_common_s_power: status : 0x0
v4l2-ctl-8379 [000] .... 161.992998: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
v4l2-ctl-8379 [000] .... 161.993001: csi_s_power: enable : 0x0
kworker/0:2-3191 [000] .... 162.038765: rtos_queue_peek_from_isr_failed: tstamp:5441120765 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 162.206655: rtos_queue_peek_from_isr_failed: tstamp:5446120849 queue:0x0b4b4500
kworker/0:2-3191 [000] .... 162.374632: rtos_queue_peek_from_isr_failed: tstamp:5451120779 queue:0x0b4b4500
kworker/0:1-786 [000] .... 162.542618: rtos_queue_peek_from_isr_failed: tstamp:5456120862 queue:0x0b4b4500
But when I try to receive a data using gst-launch-1.0
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=0 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1’ ! nvoverlaysink -e
I don’t receive a data and have bad trace:
kworker/0:1-786 [000] .... 167.022440: rtos_queue_peek_from_isr_failed: tstamp:5596121056 queue:0x0b4b4500
kworker/0:1-786 [000] .... 167.190341: rtos_queue_peek_from_isr_failed: tstamp:5601120976 queue:0x0b4b4500
kworker/0:1-786 [000] .... 167.358389: rtos_queue_peek_from_isr_failed: tstamp:5606121068 queue:0x0b4b4500
kworker/0:1-786 [000] .... 167.414400: rtos_queue_peek_from_isr_failed: tstamp:5608243340 queue:0x0b4b4500
nvargus-daemon-8450 [003] .... 213.900233: tegra_channel_open: vi-output, imx415 2-001a
nvargus-daemon-8450 [003] .... 213.901206: tegra_channel_set_power: imx415 2-001a : 0x1
nvargus-daemon-8450 [003] .... 213.901457: camera_common_s_power: status : 0x1
nvargus-daemon-8450 [003] .... 213.901580: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8450 [003] .... 213.901582: csi_s_power: enable : 0x1
nvargus-daemon-8450 [003] .... 213.903240: tegra_channel_close: vi-output, imx415 2-001a
nvargus-daemon-8450 [003] .... 213.903247: tegra_channel_set_power: imx415 2-001a : 0x0
nvargus-daemon-8450 [000] .... 213.904966: camera_common_s_power: status : 0x0
nvargus-daemon-8450 [000] .... 213.905015: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8450 [000] .... 213.905018: csi_s_power: enable : 0x0
nvargus-daemon-8450 [000] .... 213.910337: tegra_channel_open: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.910346: tegra_channel_set_power: imx415 2-001a : 0x1
nvargus-daemon-8450 [000] .... 213.911711: camera_common_s_power: status : 0x1
nvargus-daemon-8450 [000] .... 213.911842: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8450 [000] .... 213.911844: csi_s_power: enable : 0x1
nvargus-daemon-8450 [000] .... 213.911954: tegra_channel_close: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.911955: tegra_channel_set_power: imx415 2-001a : 0x0
nvargus-daemon-8450 [000] .... 213.912192: camera_common_s_power: status : 0x0
nvargus-daemon-8450 [000] .... 213.912206: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8450 [000] .... 213.912207: csi_s_power: enable : 0x0
nvargus-daemon-8450 [000] .... 213.941753: tegra_channel_open: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.941761: tegra_channel_set_power: imx415 2-001a : 0x1
nvargus-daemon-8450 [000] .... 213.942006: camera_common_s_power: status : 0x1
nvargus-daemon-8450 [000] .... 213.942139: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8450 [000] .... 213.942141: csi_s_power: enable : 0x1
nvargus-daemon-8450 [000] .... 213.942166: tegra_channel_close: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.942169: tegra_channel_set_power: imx415 2-001a : 0x0
nvargus-daemon-8450 [000] .... 213.942412: camera_common_s_power: status : 0x0
nvargus-daemon-8450 [000] .... 213.942434: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8450 [000] .... 213.942435: csi_s_power: enable : 0x0
nvargus-daemon-8450 [000] .... 213.942644: tegra_channel_open: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.942646: tegra_channel_set_power: imx415 2-001a : 0x1
nvargus-daemon-8450 [000] .... 213.942869: camera_common_s_power: status : 0x1
nvargus-daemon-8450 [000] .... 213.942999: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8450 [000] .... 213.943001: csi_s_power: enable : 0x1
nvargus-daemon-8450 [000] .... 213.943098: tegra_channel_close: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.943099: tegra_channel_set_power: imx415 2-001a : 0x0
nvargus-daemon-8450 [000] .... 213.943316: camera_common_s_power: status : 0x0
nvargus-daemon-8450 [000] .... 213.943329: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8450 [000] .... 213.943329: csi_s_power: enable : 0x0
nvargus-daemon-8450 [000] .... 213.943552: tegra_channel_open: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.943557: tegra_channel_set_power: imx415 2-001a : 0x1
nvargus-daemon-8450 [000] .... 213.943780: camera_common_s_power: status : 0x1
nvargus-daemon-8450 [000] .... 213.943898: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8450 [000] .... 213.943899: csi_s_power: enable : 0x1
nvargus-daemon-8450 [000] .... 213.943955: tegra_channel_close: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.943957: tegra_channel_set_power: imx415 2-001a : 0x0
nvargus-daemon-8450 [000] .... 213.944179: camera_common_s_power: status : 0x0
nvargus-daemon-8450 [000] .... 213.944191: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8450 [000] .... 213.944192: csi_s_power: enable : 0x0
nvargus-daemon-8450 [000] .... 213.951197: tegra_channel_open: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.951206: tegra_channel_set_power: imx415 2-001a : 0x1
nvargus-daemon-8450 [000] .... 213.951450: camera_common_s_power: status : 0x1
nvargus-daemon-8450 [000] .... 213.951583: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
nvargus-daemon-8450 [000] .... 213.951586: csi_s_power: enable : 0x1
nvargus-daemon-8450 [000] .... 213.951611: tegra_channel_close: vi-output, imx415 2-001a
nvargus-daemon-8450 [000] .... 213.951615: tegra_channel_set_power: imx415 2-001a : 0x0
nvargus-daemon-8450 [000] .... 213.951853: camera_common_s_power: status : 0x0
nvargus-daemon-8450 [000] .... 213.951876: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x0
nvargus-daemon-8450 [000] .... 213.951877: csi_s_power: enable : 0x0
kworker/0:1-786 [000] .... 214.004672: rtos_queue_peek_from_isr_failed: tstamp:7063863160 queue:0x0b4b4500
kworker/0:1-786 [000] .... 214.004677: rtcpu_start: tstamp:7063864121
kworker/0:1-786 [000] .... 214.004678: rtos_queue_send_from_isr_failed: tstamp:7063872694 queue:0x0b4a7258
kworker/0:1-786 [000] .... 214.004679: rtos_queue_send_from_isr_failed: tstamp:7063872802 queue:0x0b4aad68
kworker/0:1-786 [000] .... 214.004679: rtos_queue_send_from_isr_failed: tstamp:7063872909 queue:0x0b4ac998
kworker/0:1-786 [000] .... 214.004680: rtos_queue_send_from_isr_failed: tstamp:7063873017 queue:0x0b4ae518
kworker/0:1-786 [000] .... 214.004680: rtos_queue_send_from_isr_failed: tstamp:7063873122 queue:0x0b4af2d8
kworker/0:1-786 [000] .... 214.004681: rtos_queue_send_from_isr_failed: tstamp:7063873226 queue:0x0b4b0098
kworker/0:1-786 [000] .... 214.004682: rtos_queue_send_from_isr_failed: tstamp:7063873329 queue:0x0b4b0e58
kworker/0:1-786 [000] .... 214.004682: rtos_queue_send_from_isr_failed: tstamp:7063873433 queue:0x0b4b1c18
kworker/0:1-786 [000] .... 214.004684: rtos_queue_send_failed: tstamp:7063873892 queue:0x0b4a7258
kworker/0:1-786 [000] .... 214.116654: rtos_queue_peek_from_isr_failed: tstamp:7068863508 queue:0x0b4b4500
kworker/0:1-786 [000] .... 214.288653: rtos_queue_peek_from_isr_failed: tstamp:7073863524 queue:0x0b4b4500
kworker/0:1-786 [000] .... 214.460640: rtos_queue_peek_from_isr_failed: tstamp:7078863511 queue:0x0b4b4500
kworker/0:1-786 [000] .... 214.628636: rtos_queue_peek_from_isr_failed: tstamp:7083863519 queue:0x0b4b4500
kworker/0:1-786 [000] .... 214.796621: rtos_queue_peek_from_isr_failed: tstamp:7088863527 queue:0x0b4b4500
kworker/0:1-786 [000] .... 214.964634: rtos_queue_peek_from_isr_failed: tstamp:7093863534 queue:0x0b4b4500
kworker/0:1-786 [000] .... 215.076625: rtos_queue_peek_from_isr_failed: tstamp:7098863546 queue:0x0b4b4500
kworker/0:1-786 [000] .... 215.244623: rtos_queue_peek_from_isr_failed: tstamp:7103863548 queue:0x0b4b4500
kworker/0:1-786 [000] .... 215.412611: rtos_queue_peek_from_isr_failed: tstamp:7108863558 queue:0x0b4b4500
kworker/0:1-786 [000] .... 215.580611: rtos_queue_peek_from_isr_failed: tstamp:7113863560 queue:0x0b4b4500
kworker/0:1-786 [000] .... 215.748610: rtos_queue_peek_from_isr_failed: tstamp:7118863568 queue:0x0b4b4500
kworker/0:1-786 [000] .... 215.916601: rtos_queue_peek_from_isr_failed: tstamp:7123863575 queue:0x0b4b4500
kworker/0:1-786 [000] .... 216.084610: rtos_queue_peek_from_isr_failed: tstamp:7128863582 queue:0x0b4b4500
kworker/0:1-786 [000] .... 216.198476: rtos_queue_peek_from_isr_failed: tstamp:7133863587 queue:0x0b4b4500
kworker/0:1-786 [000] .... 216.364595: rtos_queue_peek_from_isr_failed: tstamp:7138863598 queue:0x0b4b4500
kworker/0:1-786 [000] .... 216.536599: rtos_queue_peek_from_isr_failed: tstamp:7143863600 queue:0x0b4b4500
kworker/0:1-786 [000] .... 216.704577: rtos_queue_peek_from_isr_failed: tstamp:7148863614 queue:0x0b4b4500
Additional I found strange errors in the debug messages of the Libargus:
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 106)
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[7860]: Connection established (7F741511D0)Thread 1 getting next capture
Thread 1 is waiting
Thread 2 getting next capture
Thread 2 is waiting
Thread 4 getting next capture
Thread 4 is waiting
Thread 3 getting next capture
Thread 3 is waiting
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 getting next capture
Thread 6 is waiting
Thread 7 getting next capture
Thread 7 is waiting
Thread 8 getting next capture
Thread 8 is waiting
Thread 9 getting next capture
Thread 9 is waiting
Thread 10 getting next capture
Thread 11 getting next capture
Thread 10 is waiting
Thread 11 is waiting
Thread 12 getting next capture
Thread 12 is waiting
Starting services...
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7f6c73a800)
subscribe: SensorType(gyroscope)
subscribe: create SensorType(gyroscope) sensor(0x7f6c6d4290)
subscribe: SensorType(accelerometer)
subscribe: create SensorType(accelerometer) sensor(0x7f6c7422b0)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
Services are started
NvPclSetHotplugCallback: ++++++++++++++++++++++
---- Imager: Calibration blob file handling supported in this build ----
NvPclHwGetModuleList: OFParserListModules Succeeded
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition -- Name: imx415_bottom
NvPclHwPrintModuleDefinition -- Position: 0
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx415 2-001a
NvPclHwPrintModuleDefinition -- Name: imx415_top
NvPclHwPrintModuleDefinition -- Position: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx415 2-0010
NvPclModuleListInitialize: NvPclModule list[0]: imx415_bottom position0
NvPclModuleListInitialize: NvPclModule list[1]: imx415_top position1
NvPclHwScanExternalCameras -- adding video0 to discover list
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd='1'
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 0 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c681850
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c6d6490
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c688c10
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c405e30
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c692a90
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c692a00
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16
CheckOverridesPermissions: stat(/Calib/camera_override.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/camera_overrides.isp] 2/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/camera_overrides.isp] 5/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx415_bottom.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx415_bottom.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx415_bottom.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx415_bottom.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx415_bottom.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx415_bottom.isp) call failed
---- imager: No override file found. ----
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/vendor/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/vendor/nvcam/settings/imx415_bottom.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx415_bottom.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx415_bottom.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
OFDPropertyCopyToLong: could not read property [has-eeprom]
loadBinaryBlob: Binary read 2
OFDPropertyGetString: could not read property [type]
loadSubType: Sensor type missing in DT, 206
OFDPropertyCopyToLong: could not read property [set_mode_delay_ms]
OFDPropertyCopyToLong: could not read property [mode0.vc_id]
OFDPropertyCopyToLongLong: could not read property [mode0.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode0.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode0.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode0.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode0.x_start]
OFDPropertyGetString: could not read property [mode0.y_start]
OFDPropertyGetString: could not read property [mode0.x_end]
OFDPropertyGetString: could not read property [mode0.y_end]
OFDPropertyGetString: could not read property [mode0.h_scaling]
OFDPropertyGetString: could not read property [mode0.v_scaling]
initialize: Loaded Driver: 1 Modes Available--------------
NvPclInitializeDrivers: v4l2_sensor ------------------
NvPclOpen: ----------------------
LSC: LSC surface is not based on full res!
NvPclStateControllerOpen: Found GUID 1 match at index[1]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6cb435d0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6cb1d340
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c770700
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c798770
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c799e60
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f6c799b60
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx415_top.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx415_top.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx415_top.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx415_top.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx415_top.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx415_top.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx415_top.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx415_top.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx415_top.bin] 4/16
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f6c798770
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f6c799e60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f6c799b60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f6cb435d0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f6cb1d340
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f6c770700
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
NvPclStateControllerClose: Module imx415_top closed
NvPclOpen: PCL Open Failed. Error: 0xf
NvPclClose: ++++++++++++++++++++++
NvPclClose: ----------------------
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 582)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 295)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 458)
Acquiring SCF Camera device source via index 1 has failed. === gst-launch-1.0[7860]: CameraProvider initialized (0x7f6c79ae30)sourceRegistry[0] assigned
ispRegistry[0] assigned
Using Source GUID 0
Worker thread ViCsiHw frameComplete start
Worker thread ViCsiHw frameStart start
NvPclPowerOn: +++++++++++
NvPclPowerOn: -----------
Using ISP A
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=2, m_value=4294967295, m_timeout_ms=1000
No library found, disabling AC plugin.
Worker thread CaptureDispatcher start
Session::updatePerfHints()
updatePerfHints(): guid=0ll, CaptureIntent=1
updatePerfHints(): NvCameraCoreUseCase_Preview
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=1, m_value=30, m_timeout_ms=1000
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=15, m_value=0, m_timeout_ms=1000
SCF: Error BadParameter: (in src/components/ClipHelper.cpp, function setInSize(), line 76)
SCF: Error BadParameter: (propagating from src/components/GraphHelper.cpp, function setupClipHelper(), line 150)
SCF: Error BadParameter: (propagating from src/components/GraphHelper.cpp, function initialize(), line 134)
SCF: Error BadParameter: (propagating from src/components/CaptureSetupEngineImpl.cpp, function genInstructionsBayerSource(), line 926)
SCF: Error BadParameter: (propagating from src/components/CaptureSetupEngineImpl.cpp, function doGetInstructions(), line 2211)
SCF: Error BadParameter: (propagating from src/components/CaptureSetupEngine.cpp, function getInstructionList(), line 300)
SCF: Error BadParameter: (propagating from src/components/CaptureSetupEngine.cpp, function setupCC(), line 214)
SCF: Error BadParameter: (propagating from src/api/Session.cpp, function capture(), line 815)
disposing CC 0 Session 0
(Argus) Error BadParameter: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
What might be the problem?
