Hello! I now have an 8000 * 6000 camera.
I want to know Can I use the 8000 * 6000 camera on the Jetson TX2?
I tried to run this 8000 * 6000 camera with GStreamer, but there was no image display.
The line width Max supported is 6144. Maximum size is 20 MP
ok! Thank you!
excuse me, If I want to use an 8000 * 6000 pixel camera on Jetson, what’s the suggestion?
I think you can try usb or pcie interface.
Thank you for your prompt reply. I will try to these methods.
@ShaneCCC
Excuse me, I have a problem and need your help.
I tried to use the 4000 * 3000 onboard camera on the Jetson TX2.
When I used the GStreamer command to turn on the camera, there were a lot of errors.
nvidia@nvidia-desktop:~/$ gst-launch-1.0 --gst-debug-level=4 nvarguscamerasrc sensor-mode=3 sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)24/1' ! nvv4l2h265enc ! h265parse ! qtmux ! filesink location=test_h265.mp4 -e
0:00:00.000871776 26646 0x55accf40c0 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.002149729 26646 0x55accf40c0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.002687842 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.002924514 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.002961570 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.003015138 26646 0x55accf40c0 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.034531229 26646 0x55accf40c0 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin in 0.031453 seconds
0:00:00.034638973 26646 0x55accf40c0 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.039480929 26646 0x55accf40c0 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.039517857 26646 0x55accf40c0 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.039536257 26646 0x55accf40c0 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.039554145 26646 0x55accf40c0 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.039566753 26646 0x55accf40c0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.039634370 26646 0x55accf40c0 INFO GST_PIPELINE gstparse.c:337:gst_parse_launch_full: parsing pipeline description 'nvarguscamerasrc sensor-mode=3 sensor-id=0 ! video/x-raw(memory:NVMM),\ width=(int)4000,\ height=(int)3000,\ format=(string)NV12,\ framerate=(fraction)24/1 ! nvv4l2h265enc ! h265parse ! qtmux ! filesink location=test_h265.mp4 '
0:00:00.077589442 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so" loaded
0:00:00.077642050 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvarguscamerasrc"
0:00:00.078175075 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSrc@0x55acf98d50> adding pad 'src'
0:00:00.081718022 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so" loaded
0:00:00.081754822 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvv4l2h265enc"
0:00:00.082168934 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoEncoder@0x55acfa51e0> adding pad 'sink'
0:00:00.082209382 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoEncoder@0x55acfa51e0> adding pad 'src'
0:00:00.084822312 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so" loaded
0:00:00.084864072 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "h265parse"
0:00:00.085096328 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x55acfaafc0> adding pad 'sink'
0:00:00.085136361 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x55acfaafc0> adding pad 'src'
0:00:00.085190249 26646 0x55accf40c0 INFO baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:<GstH265Parse@0x55acfaafc0> PTS interpolation: no
0:00:00.087639051 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstisomp4.so" loaded
0:00:00.087677643 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "qtmux"
0:00:00.087985579 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstQTMux@0x55acfb8000> adding pad 'src'
0:00:00.089258668 26646 0x55accf40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.089308844 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "filesink"
0:00:00.089769100 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x55acfc1ff0> adding pad 'sink'
0:00:00.089901517 26646 0x55accf40c0 INFO filesink gstfilesink.c:294:gst_file_sink_set_location:<filesink0> filename : test_h265.mp4
0:00:00.089922349 26646 0x55accf40c0 INFO filesink gstfilesink.c:295:gst_file_sink_set_location:<filesink0> uri : file:///home/nvidia/Downloads/imx586_driver/raw-image/test_h265.mp4
0:00:00.089951917 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "pipeline"
0:00:00.090774029 26646 0x55accf40c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstNvArgusCameraSrc named nvarguscamerasrc0 to some pad of nvv4l2h265enc named nvv4l2h265enc0 (0/0) with caps "video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)24/1"
0:00:00.090805933 26646 0x55accf40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
0:00:00.090999758 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55acfc8140> adding pad 'sink'
0:00:00.091036366 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55acfc8140> adding pad 'src'
0:00:00.091292014 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.091332942 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.091363406 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.091393070 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvarguscamerasrc0:(any) to element capsfilter0:sink
0:00:00.091413582 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.091432654 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvarguscamerasrc0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.091651918 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvarguscamerasrc0:src and capsfilter0:sink
0:00:00.091684750 26646 0x55accf40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.091722254 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvarguscamerasrc0:src and capsfilter0:sink, successful
0:00:00.091738382 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.091753774 26646 0x55accf40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvarguscamerasrc0:src> Received event on flushing pad. Discarding
0:00:00.091784334 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element capsfilter0:src to element nvv4l2h265enc0:(any)
0:00:00.091804750 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.091827182 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link capsfilter0:src and nvv4l2h265enc0:sink
0:00:00.091866350 26646 0x55accf40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvv4l2h265enc0:src> pad has no peer
0:00:00.091920558 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: capsfilter0 and nvv4l2h265enc0 in same bin, no need for ghost pads
0:00:00.091946958 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link capsfilter0:src and nvv4l2h265enc0:sink
0:00:00.091980174 26646 0x55accf40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvv4l2h265enc0:src> pad has no peer
0:00:00.092018670 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked capsfilter0:src and nvv4l2h265enc0:sink, successful
0:00:00.092033742 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.092258671 26646 0x55accf40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.092317839 26646 0x55accf40c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of nvv4l2h265enc named nvv4l2h265enc0 to some pad of GstH265Parse named h265parse0 (0/0) with caps "(NULL)"
0:00:00.092339055 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvv4l2h265enc0:(any) to element h265parse0:(any)
0:00:00.092360751 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvv4l2h265enc0:src and h265parse0:sink
0:00:00.092398639 26646 0x55accf40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<h265parse0:src> pad has no peer
0:00:00.092425935 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvv4l2h265enc0 and h265parse0 in same bin, no need for ghost pads
0:00:00.092449615 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvv4l2h265enc0:src and h265parse0:sink
0:00:00.092471087 26646 0x55accf40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<h265parse0:src> pad has no peer
0:00:00.092496335 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvv4l2h265enc0:src and h265parse0:sink, successful
0:00:00.092510607 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.092525391 26646 0x55accf40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvv4l2h265enc0:src> Received event on flushing pad. Discarding
0:00:00.092557263 26646 0x55accf40c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstH265Parse named h265parse0 to some pad of GstQTMux named qtmux0 (0/0) with caps "(NULL)"
0:00:00.092575983 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element h265parse0:(any) to element qtmux0:(any)
0:00:00.092678895 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<qtmux0> adding pad 'video_0'
0:00:00.092709071 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: h265parse0 and qtmux0 in same bin, no need for ghost pads
0:00:00.092733679 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link h265parse0:src and qtmux0:video_0
0:00:00.092764335 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked h265parse0:src and qtmux0:video_0, successful
0:00:00.092778799 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.092794159 26646 0x55accf40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<h265parse0:src> Received event on flushing pad. Discarding
0:00:00.092824239 26646 0x55accf40c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstQTMux named qtmux0 to some pad of GstFileSink named filesink0 (0/0) with caps "(NULL)"
0:00:00.092842831 26646 0x55accf40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element qtmux0:(any) to element filesink0:(any)
0:00:00.092863375 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link qtmux0:src and filesink0:sink
0:00:00.092889807 26646 0x55accf40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: qtmux0 and filesink0 in same bin, no need for ghost pads
0:00:00.092918063 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link qtmux0:src and filesink0:sink
0:00:00.092945615 26646 0x55accf40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked qtmux0:src and filesink0:sink, successful
0:00:00.092959407 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.092974063 26646 0x55accf40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<qtmux0:src> Received event on flushing pad. Discarding
Setting pipeline to PAUSED ...
0:00:00.093303248 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filesink0> current NULL pending VOID_PENDING, desired next READY
0:00:00.093424208 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<filesink0> completed state change to READY
0:00:00.093448432 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<filesink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.093490672 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'filesink0' changed state to 2(READY) successfully
0:00:00.093516784 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<qtmux0> current NULL pending VOID_PENDING, desired next READY
0:00:00.093536496 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<qtmux0> completed state change to READY
0:00:00.093553776 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<qtmux0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.093577680 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'qtmux0' changed state to 2(READY) successfully
0:00:00.093600016 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<h265parse0> current NULL pending VOID_PENDING, desired next READY
0:00:00.093618384 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<h265parse0> completed state change to READY
0:00:00.093635824 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<h265parse0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.093658384 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'h265parse0' changed state to 2(READY) successfully
0:00:00.093680688 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvv4l2h265enc0> current NULL pending VOID_PENDING, desired next READY
Opening in BLOCKING MODE
0:00:00.098259604 26646 0x55accf40c0 INFO v4l2 v4l2_calls.c:622:gst_v4l2_open:<nvv4l2h265enc0:sink> Opened device '' (/dev/nvhost-msenc) successfully
0:00:00.098299540 26646 0x55accf40c0 INFO v4l2 v4l2_calls.c:723:gst_v4l2_dup:<nvv4l2h265enc0:src> Cloned device '' (/dev/nvhost-msenc) successfully
0:00:00.099314805 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1280:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:sink> got 4 format(s):
0:00:00.099382901 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:sink> YM12
0:00:00.099407253 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:sink> PM10
0:00:00.099427061 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:sink> NM12
0:00:00.099445525 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:sink> YM24
0:00:00.099484693 26646 0x55accf40c0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x55acfa6100 Failed to determine interlace mode
0:00:00.099523125 26646 0x55accf40c0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x55acfa6100 Failed to determine interlace mode
0:00:00.099557877 26646 0x55accf40c0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x55acfa6100 Failed to determine interlace mode
0:00:00.099627669 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:4464:gst_v4l2_object_probe_caps:<nvv4l2h265enc0:sink> probed caps: video/x-raw, format=(string)I420, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, format=(string)P010_10LE, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, format=(string)NV12, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.099655733 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1280:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:src> got 4 format(s):
0:00:00.099673461 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:src> VP90
0:00:00.099690197 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:src> VP80
0:00:00.099706261 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:src> H265
0:00:00.099722453 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:1286:gst_v4l2_object_fill_format_list:<nvv4l2h265enc0:src> H264
0:00:00.099751925 26646 0x55accf40c0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2h265enc0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.099814805 26646 0x55accf40c0 INFO v4l2 gstv4l2object.c:4464:gst_v4l2_object_probe_caps:<nvv4l2h265enc0:src> probed caps: video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.099849973 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2h265enc0> completed state change to READY
0:00:00.099871413 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvv4l2h265enc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.099906133 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvv4l2h265enc0' changed state to 2(READY) successfully
0:00:00.099938421 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.099959573 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.099976821 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.100004309 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.100028917 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current NULL pending VOID_PENDING, desired next READY
0:00:00.100048213 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to READY
0:00:00.100065845 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.100088405 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 2(READY) successfully
0:00:00.100116725 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.100135413 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.100176405 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.100215637 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filesink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.100250613 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func:<pipeline0> child 'filesink0' is changing state asynchronously to PAUSED
0:00:00.100274709 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<qtmux0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.100303894 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<qtmux0> completed state change to PAUSED
0:00:00.100322070 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<qtmux0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.100344886 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'qtmux0' changed state to 3(PAUSED) successfully
0:00:00.100367798 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<h265parse0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.100805302 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<h265parse0> completed state change to PAUSED
0:00:00.100837750 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<h265parse0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.100866870 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'h265parse0' changed state to 3(PAUSED) successfully
0:00:00.100891798 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvv4l2h265enc0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.100923542 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2h265enc0> completed state change to PAUSED
0:00:00.100942486 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvv4l2h265enc0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.100968726 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvv4l2h265enc0' changed state to 3(PAUSED) successfully
0:00:00.100991798 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.101019606 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:00.101037430 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.101059958 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.101081110 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.101123926 26646 0x55accf40c0 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek:<nvarguscamerasrc0> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.101161110 26646 0x55accf40c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x55acf9a200 on task 0x55acfac290
0:00:00.101179542 26646 0x55accf40c0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<nvarguscamerasrc0:src> created task 0x55acfac290
0:00:00.101331606 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PAUSED
0:00:00.101356758 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.101389078 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2997:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 3(PAUSED) successfully without preroll
0:00:00.101416534 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:00.101435542 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is live and does not need PREROLL ...
0:00:00.101927447 26646 0x55acfb5e80 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'sink' in element "nvarguscamerasrc0"
0:00:00.101979927 26646 0x55acfb5e80 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:<nvarguscamerasrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Setting pipeline to PLAYING ...
0:00:00.102212023 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.102255927 26646 0x55accf40c0 INFO bin gstbin.c:2783:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.102295511 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filesink0> current READY pending PAUSED, desired next PLAYING
0:00:00.102315447 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func:<pipeline0> child 'filesink0' is changing state asynchronously to PLAYING
0:00:00.102337623 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<qtmux0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.102357303 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<qtmux0> completed state change to PLAYING
0:00:00.102376631 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<qtmux0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.102401271 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'qtmux0' changed state to 4(PLAYING) successfully
0:00:00.102423607 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<h265parse0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.102443863 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<h265parse0> completed state change to PLAYING
0:00:00.102462967 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<h265parse0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.102487063 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'h265parse0' changed state to 4(PLAYING) successfully
0:00:00.102510903 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvv4l2h265enc0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.102532215 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2h265enc0> completed state change to PLAYING
0:00:00.102550359 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvv4l2h265enc0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.102573591 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvv4l2h265enc0' changed state to 4(PLAYING) successfully
0:00:00.102596151 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.102615223 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PLAYING
0:00:00.102632888 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.102661336 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.102687224 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PLAYING
0:00:00.102708440 26646 0x55accf40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.102733432 26646 0x55accf40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 4(PLAYING) successfully
New clock: GstSystemClock
0:00:00.119449222 26646 0x55acfb5e80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)24/1
0:00:00.119774214 26646 0x55acfb5e80 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:00:00.119832262 26646 0x55acfb5e80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)24/1
0:00:00.120152743 26646 0x55acfb5e80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)4000, height=(int)3000, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)24/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
0:00:00.120402983 26646 0x55acfb5e80 INFO v4l2 gstv4l2object.c:3146:gst_v4l2_object_setup_pool:<nvv4l2h265enc0:src> accessing buffers via mode 2
0:00:00.120890855 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:822:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:src> increasing minimum buffers to 2
0:00:00.121168839 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:835:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:src> reducing maximum buffers to 32
0:00:00.121193895 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:846:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:src> can't allocate, setting maximum to minimum
0:00:00.121556840 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:835:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:src> reducing maximum buffers to 32
0:00:00.121584360 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:846:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:src> can't allocate, setting maximum to minimum
Redistribute latency...
0:00:00.121831528 26646 0x55accf40c0 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.121960168 26646 0x55accf40c0 INFO bin gstbin.c:2783:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
0:00:00.125068139 26646 0x55acfb5e80 INFO v4l2 gstv4l2object.c:3973:gst_v4l2_object_set_format_full:<nvv4l2h265enc0:sink> Set output framerate to 24/1
0:00:00.125114315 26646 0x55acfb5e80 INFO v4l2 gstv4l2object.c:3146:gst_v4l2_object_setup_pool:<nvv4l2h265enc0:sink> accessing buffers via mode 5
0:00:00.125400395 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:822:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:sink> increasing minimum buffers to 2
0:00:00.125426603 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:829:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:sink> increasing minimum buffers to 4
0:00:00.125442443 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:835:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:sink> reducing maximum buffers to 32
0:00:00.125457099 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:846:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:sink> can't allocate, setting maximum to minimum
0:00:00.125470987 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:851:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:sink> adding needed video meta
0:00:00.248644597 26646 0x55acfb5e80 WARN v4l2bufferpool gstv4l2bufferpool.c:1062:gst_v4l2_buffer_pool_start:<nvv4l2h265enc0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.250046166 26646 0x55acfb5e80 INFO v4l2bufferpool gstv4l2bufferpool.c:846:gst_v4l2_buffer_pool_set_config:<nvv4l2h265enc0:pool:sink> can't allocate, setting maximum to minimum
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 8000 x 6000 FR = 6.410000 fps Duration = 156006240 ; Analog Gain range min 1.122018, max 15.848933; Exposure Range min 30000, max 660000000;
GST_ARGUS: 8000 x 6000 FR = 19.390000 fps Duration = 51572976 ; Analog Gain range min 1.122018, max 15.848933; Exposure Range min 30000, max 660000000;
GST_ARGUS: 4000 x 3000 FR = 24.800000 fps Duration = 40322580 ; Analog Gain range min 1.122018, max 63.095726; Exposure Range min 30000, max 660000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 3
Output Stream W = 4000 H = 3000
seconds to Run = 0
Frame Rate = 24.800000
GST_ARGUS: PowerService: requested_clock_Hz=126000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Done Success
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
Do you know how to solve this problem?
by the way, I use 4000 * 3000 mode in Sony imx586 camera .
Did you verify the by v4l2-ctl first?
v4l2-ctl --set-fmt-video=width=4000,height=3000 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video0
Please enable the trace log to get more informatio.
https://elinux.org/Jetson_TX2_Camera_BringUp
Yes, I have successfully obtained raw image through v4l2-ctl command.
Now, I’m looking for problems based on this forum.
I have a try below command:
nvidia@nvidia-desktop:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=4000,height=3000,format=(string)NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! nvoverlaysink sync=false -e
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
nvidia@nvidia-desktop:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=4000,height=3000,format=(string)NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! fakesink
nvidia@nvidia-desktop:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=4000,height=3000,format=(string)NV12' ! fakesink
Try install gstreamer by below command again.
And get more information.
nvidia@nvidia-desktop:~$ gst-launch-1.0 v4l2src --gst-debug=GST_DEBUG=*:3,v4l2src:5 device=/dev/video0 ! nvvidconv ! fakesink
0:00:00.089188397 10705 0x559c04a140 DEBUG v4l2src gstv4l2src.c:512:gst_v4l2src_negotiate:<v4l2src0> caps of src: EMPTY
0:00:00.089385006 10705 0x559c04a140 DEBUG v4l2src gstv4l2src.c:520:gst_v4l2src_negotiate:<v4l2src0> caps of peer: video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], format=(string){ I420, I420_10LE, P010_10LE, I420_12LE, UYVY, YUY2, YVYU, NV12, NV16, NV24, GRAY8, BGRx, RGBA }; video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], format=(string){ I420, UYVY, YUY2, YVYU, NV12, NV16, NV24, P010_10LE, GRAY8, BGRx, RGBA }
0:00:00.089413582 10705 0x559c04a140 DEBUG v4l2src gstv4l2src.c:526:gst_v4l2src_negotiate:<v4l2src0> intersect: EMPTY
Execution ended after 0:00:00.000721316
nvidia@nvidia-desktop:~$ gst-launch-1.0 v4l2src --gst-debug=GST_DEBUG=*:3,v4l2src:5 device=/dev/video0 ! 'video/x-raw,width=4000,height=3000,format=(string)NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! nvoverlaysink sync=false -e
0:00:00.121873547 10832 0x55a4edb770 DEBUG v4l2src gstv4l2src.c:512:gst_v4l2src_negotiate:<v4l2src0> caps of src: EMPTY
0:00:00.122066665 10832 0x55a4edb770 DEBUG v4l2src gstv4l2src.c:520:gst_v4l2src_negotiate:<v4l2src0> caps of peer: video/x-raw, width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.122097737 10832 0x55a4edb770 DEBUG v4l2src gstv4l2src.c:526:gst_v4l2src_negotiate:<v4l2src0> intersect: EMPTY
0:00:00.122380807 10832 0x55a4e73f60 WARN v4l2src gstv4l2src.c:692:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:00.000371102
But I still don’t understand where the specific problem lies.
I hope this information is useful.
Thank you very much!
Does your sensor output YUV format instead of bayer format?
Have a try below command for YUV sensor.
st-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw,width=4000,height=3000,format=(string)UYVY’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=(string)NV12’ ! queue ! nvvidconv ! nvoverlaysink -e
I tried to use this command, but there was no difference
nvidia@nvidia-desktop:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=4000,height=3000,format=(string)UYVY' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! queue ! nvvidconv ! nvoverlaysink -e
Thanks and Best Regards,
Have a check the pixel format for your driver by below command.
v4l2-ctl --list-formats-ext
nvidia@nvidia-desktop:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 8000x6000
Interval: Discrete 0.167s (6.000 fps)
Size: Discrete 4000x3000
Interval: Discrete 0.042s (24.000 fps)}vi
The pixel format is rg10. Is that right?
What do you think?
You can’t run the v4l2src for this Bayer format.
First confirm v4l2-ctl can capture data from sensor well, then run the gst-launch-1.0 nvarguscamerasrc … pipeline, If can’t capture no matter v4l2-ctl need to check the trace log.
sudo su
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Thank you for your prompt reply!
I can use v4l2 CTL to collect data from sensor wells.
But there is a problem.
I used mode 3 (4000 * 3000) to get images, but I got 8000 * 6000 resolution images.
I run this command
nvidia@nvidia-desktop:~/Downloads/imx586_driver/raw-image$ v4l2-ctl -V --set-fmt-video=width=4096,height=3000,pixelformat=RG10 --set-ctrl bypass_mode=0 --set-ctrl=sensor_mode=3 --stream-mmap --stream-count=1000 -d /dev/video0
<<<<<<<< 6.42 fps
<<<<<< 6.43 fps
<<<<<<< 6.43 fps
<<<<<< 6.41 fps
It should be 4000 * 3000 24fps,but no.
Run the v4l2 command to save the raw image. The image resolution format is 8000 * 6000
v4l2-ctl --set-fmt-video=width=4096,height=3000,pixelformat=RG10 --stream-mmap --set-ctrl=sensor_mode=3 --stream-count=1 --stream-to=imx586.raw -d /dev/video0
v4l2-ctl-10501 [005] … 1735.573691: tegra_channel_capture_setup: vnc_id 0 W 8000 H 6000 fmt 20.
root@nvidia-desktop:/home/nvidia# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 382/382 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/4:3-10166 [004] .... 1721.601483: rtos_queue_peek_from_isr_failed: tstamp:54083615192 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1721.769510: rtos_queue_peek_from_isr_failed: tstamp:54088615166 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1721.937494: rtos_queue_peek_from_isr_failed: tstamp:54093615172 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1722.105519: rtos_queue_peek_from_isr_failed: tstamp:54098615182 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1722.273508: rtos_queue_peek_from_isr_failed: tstamp:54103615186 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1722.441507: rtos_queue_peek_from_isr_failed: tstamp:54108615195 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1722.553500: rtos_queue_peek_from_isr_failed: tstamp:54113615198 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1722.721504: rtos_queue_peek_from_isr_failed: tstamp:54118615217 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1722.889620: rtos_queue_peek_from_isr_failed: tstamp:54123615252 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1723.057642: rtos_queue_peek_from_isr_failed: tstamp:54128615325 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1723.225522: rtos_queue_peek_from_isr_failed: tstamp:54133615242 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1723.393644: rtos_queue_peek_from_isr_failed: tstamp:54138615228 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1723.561659: rtos_queue_peek_from_isr_failed: tstamp:54143615343 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1723.673643: rtos_queue_peek_from_isr_failed: tstamp:54148615348 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1723.841519: rtos_queue_peek_from_isr_failed: tstamp:54153615254 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.009528: rtos_queue_peek_from_isr_failed: tstamp:54158615263 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.177640: rtos_queue_peek_from_isr_failed: tstamp:54163615374 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.345646: rtos_queue_peek_from_isr_failed: tstamp:54168615377 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.513526: rtos_queue_peek_from_isr_failed: tstamp:54173615280 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.681530: rtos_queue_peek_from_isr_failed: tstamp:54178615290 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.793577: rtos_queue_peek_from_isr_failed: tstamp:54183615299 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1724.961636: rtos_queue_peek_from_isr_failed: tstamp:54188615407 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1725.129534: rtos_queue_peek_from_isr_failed: tstamp:54193615308 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1725.297553: rtos_queue_peek_from_isr_failed: tstamp:54198615312 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1725.465543: rtos_queue_peek_from_isr_failed: tstamp:54203615320 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1725.633548: rtos_queue_peek_from_isr_failed: tstamp:54208615328 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1725.801579: rtos_queue_peek_from_isr_failed: tstamp:54213615336 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1725.913567: rtos_queue_peek_from_isr_failed: tstamp:54218615345 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1726.081566: rtos_queue_peek_from_isr_failed: tstamp:54223615349 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1726.249565: rtos_queue_peek_from_isr_failed: tstamp:54228615357 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1726.417565: rtos_queue_peek_from_isr_failed: tstamp:54233615361 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1726.585588: rtos_queue_peek_from_isr_failed: tstamp:54238615510 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1726.753674: rtos_queue_peek_from_isr_failed: tstamp:54243615480 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1726.921557: rtos_queue_peek_from_isr_failed: tstamp:54248615388 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1727.033560: rtos_queue_peek_from_isr_failed: tstamp:54253615393 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1727.089586: rtos_queue_peek_from_isr_failed: tstamp:54254223150 queue:0x0b4b4500
v4l2-ctl-10501 [004] .... 1735.476561: tegra_channel_open: vi-output, imx586 2-001a
v4l2-ctl-10501 [000] .... 1735.477587: tegra_channel_set_power: imx586 2-001a : 0x1
v4l2-ctl-10501 [000] .... 1735.477600: camera_common_s_power: status : 0x1
v4l2-ctl-10501 [004] .... 1735.478111: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-10501 [004] .... 1735.478114: csi_s_power: enable : 0x1
v4l2-ctl-10501 [005] .... 1735.573691: tegra_channel_capture_setup: vnc_id 0 W 8000 H 6000 fmt 20
vi-output, imx5-10502 [004] .... 1735.573798: tegra_channel_set_stream: enable : 0x1
vi-output, imx5-10502 [000] .... 1735.575458: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx5-10502 [000] .... 1735.575461: csi_s_stream: enable : 0x1
vi-output, imx5-10502 [000] .... 1735.575497: tegra_channel_set_stream: imx586 2-001a : 0x1
kworker/4:3-10166 [004] .... 1735.609655: rtos_queue_peek_from_isr_failed: tstamp:54520584557 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1735.609659: rtcpu_start: tstamp:54520585413
kworker/4:3-10166 [004] .... 1735.609660: rtos_queue_send_from_isr_failed: tstamp:54520594562 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1735.609661: rtos_queue_send_from_isr_failed: tstamp:54520594670 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1735.609661: rtos_queue_send_from_isr_failed: tstamp:54520594776 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1735.609662: rtos_queue_send_from_isr_failed: tstamp:54520594884 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1735.609663: rtos_queue_send_from_isr_failed: tstamp:54520594987 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1735.609663: rtos_queue_send_from_isr_failed: tstamp:54520595095 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1735.609664: rtos_queue_send_from_isr_failed: tstamp:54520595200 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1735.609665: rtos_queue_send_from_isr_failed: tstamp:54520595306 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1735.609667: rtos_queue_send_failed: tstamp:54520595764 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1735.609667: rtos_queue_send_from_isr_failed: tstamp:54520597578 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1735.609668: rtos_queue_send_from_isr_failed: tstamp:54520597684 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1735.609668: rtos_queue_send_from_isr_failed: tstamp:54520597791 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1735.609669: rtos_queue_send_from_isr_failed: tstamp:54520597897 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1735.609670: rtos_queue_send_from_isr_failed: tstamp:54520598001 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1735.609670: rtos_queue_send_from_isr_failed: tstamp:54520598104 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1735.609671: rtos_queue_send_from_isr_failed: tstamp:54520598208 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1735.609672: rtos_queue_send_from_isr_failed: tstamp:54520598315 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1735.609672: rtos_queue_send_failed: tstamp:54520599257 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1735.777674: rtos_queue_peek_from_isr_failed: tstamp:54525584891 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1735.945681: rtos_queue_peek_from_isr_failed: tstamp:54530584890 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1736.057755: rtos_queue_peek_from_isr_failed: tstamp:54535584896 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1736.164220: tegra_channel_capture_frame: sof:1736.58501285
kworker/4:3-10166 [004] .... 1736.169689: rtcpu_vinotify_event: tstamp:54539053608 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:54539053099 data:0x00000001
kworker/4:3-10166 [004] .... 1736.169691: rtcpu_vinotify_event: tstamp:54539053788 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:54539053102 data:0x00000000
kworker/4:3-10166 [004] .... 1736.169692: rtcpu_vinotify_event: tstamp:54539056525 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:3 vi_tstamp:54539056166 data:0x08000000
kworker/4:3-10166 [004] .... 1736.225689: rtos_queue_peek_from_isr_failed: tstamp:54540584909 queue:0x0b4b4500
vi-output, imx5-10502 [003] .... 1736.320291: tegra_channel_capture_frame: sof:1736.214499813
kworker/4:3-10166 [004] .... 1736.337727: rtcpu_vinotify_event: tstamp:54543880420 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:54543879762 data:0x176f0002
kworker/4:3-10166 [004] .... 1736.337733: rtcpu_vinotify_event: tstamp:54543880553 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:54543879777 data:0x00000000
kworker/4:3-10166 [004] .... 1736.337735: rtcpu_vinotify_event: tstamp:54543928544 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:54543928053 data:0x00000001
kworker/4:3-10166 [004] .... 1736.337737: rtcpu_vinotify_event: tstamp:54543928707 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:54543928056 data:0x00000000
kworker/4:3-10166 [004] .... 1736.337739: rtcpu_vinotify_event: tstamp:54543933825 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:4 vi_tstamp:54543933464 data:0x08000000
kworker/4:3-10166 [004] .... 1736.393709: rtos_queue_peek_from_isr_failed: tstamp:54545584921 queue:0x0b4b4500
vi-output, imx5-10502 [003] .... 1736.476309: tegra_channel_capture_frame: sof:1736.370498373
kworker/4:3-10166 [004] .... 1736.505751: rtcpu_vinotify_event: tstamp:54548755380 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:54548754716 data:0x176f0002
kworker/4:3-10166 [004] .... 1736.505759: rtcpu_vinotify_event: tstamp:54548755520 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:54548754731 data:0x00000000
kworker/4:3-10166 [004] .... 1736.505761: rtcpu_vinotify_event: tstamp:54548803505 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:54548803008 data:0x00000001
kworker/4:3-10166 [004] .... 1736.505763: rtcpu_vinotify_event: tstamp:54548803668 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:54548803011 data:0x00000000
kworker/4:3-10166 [004] .... 1736.505765: rtcpu_vinotify_event: tstamp:54548809473 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:5 vi_tstamp:54548809117 data:0x08000000
kworker/4:3-10166 [004] .... 1736.561717: rtos_queue_peek_from_isr_failed: tstamp:54550584923 queue:0x0b4b4500
vi-output, imx5-10502 [005] .... 1736.632218: tegra_channel_capture_frame: sof:1736.526496869
kworker/4:3-10166 [004] .... 1736.673697: rtcpu_vinotify_event: tstamp:54553630330 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:54553629670 data:0x176f0002
kworker/4:3-10166 [004] .... 1736.673701: rtcpu_vinotify_event: tstamp:54553630455 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:54553629685 data:0x00000000
kworker/4:3-10166 [004] .... 1736.673701: rtcpu_vinotify_event: tstamp:54553678454 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:54553677961 data:0x00000001
kworker/4:3-10166 [004] .... 1736.673702: rtcpu_vinotify_event: tstamp:54553678616 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:54553677965 data:0x00000000
kworker/4:3-10166 [004] .... 1736.673702: rtcpu_vinotify_event: tstamp:54553681497 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:6 vi_tstamp:54553681141 data:0x08000000
kworker/4:3-10166 [004] .... 1736.729698: rtos_queue_peek_from_isr_failed: tstamp:54555584931 queue:0x0b4b4500
vi-output, imx5-10502 [005] .... 1736.788209: tegra_channel_capture_frame: sof:1736.682495429
kworker/4:3-10166 [004] .... 1736.841705: rtcpu_vinotify_event: tstamp:54558505282 tag:CHANSEL_PXL_EOF channel:0x00 frame:6 vi_tstamp:54558504624 data:0x176f0002
kworker/4:3-10166 [004] .... 1736.841708: rtcpu_vinotify_event: tstamp:54558505407 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:54558504639 data:0x00000000
kworker/4:3-10166 [004] .... 1736.841708: rtcpu_vinotify_event: tstamp:54558553407 tag:CHANSEL_PXL_SOF channel:0x00 frame:7 vi_tstamp:54558552916 data:0x00000001
kworker/4:3-10166 [004] .... 1736.841709: rtcpu_vinotify_event: tstamp:54558553570 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:54558552919 data:0x00000000
kworker/4:3-10166 [004] .... 1736.841709: rtcpu_vinotify_event: tstamp:54558556220 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:7 vi_tstamp:54558555862 data:0x08000000
kworker/4:3-10166 [004] .... 1736.897709: rtos_queue_peek_from_isr_failed: tstamp:54560584942 queue:0x0b4b4500
vi-output, imx5-10502 [003] .n.. 1736.944267: tegra_channel_capture_frame: sof:1736.838493957
kworker/4:3-10166 [004] .... 1736.953718: rtcpu_vinotify_event: tstamp:54563380236 tag:CHANSEL_PXL_EOF channel:0x00 frame:7 vi_tstamp:54563379579 data:0x176f0002
kworker/4:3-10166 [004] .... 1736.953721: rtcpu_vinotify_event: tstamp:54563380360 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:54563379593 data:0x00000000
kworker/4:3-10166 [004] .... 1736.953721: rtcpu_vinotify_event: tstamp:54563428364 tag:CHANSEL_PXL_SOF channel:0x00 frame:8 vi_tstamp:54563427870 data:0x00000001
kworker/4:3-10166 [004] .... 1736.953722: rtcpu_vinotify_event: tstamp:54563428525 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:54563427873 data:0x00000000
kworker/4:3-10166 [004] .... 1736.953722: rtcpu_vinotify_event: tstamp:54563433924 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:8 vi_tstamp:54563433557 data:0x08000000
kworker/4:3-10166 [004] .... 1737.065690: rtos_queue_peek_from_isr_failed: tstamp:54565584944 queue:0x0b4b4500
vi-output, imx5-10502 [005] .... 1737.100214: tegra_channel_capture_frame: sof:1736.994492485
kworker/4:3-10166 [004] .... 1737.121700: rtcpu_vinotify_event: tstamp:54568255205 tag:CHANSEL_PXL_EOF channel:0x00 frame:8 vi_tstamp:54568254532 data:0x176f0002
kworker/4:3-10166 [004] .... 1737.121703: rtcpu_vinotify_event: tstamp:54568255328 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:54568254547 data:0x00000000
kworker/4:3-10166 [004] .... 1737.121704: rtcpu_vinotify_event: tstamp:54568303318 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:54568302824 data:0x00000001
kworker/4:3-10166 [004] .... 1737.121705: rtcpu_vinotify_event: tstamp:54568303479 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:54568302827 data:0x00000000
kworker/4:3-10166 [004] .... 1737.121705: rtcpu_vinotify_event: tstamp:54568306366 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:9 vi_tstamp:54568306008 data:0x08000000
kworker/4:3-10166 [004] .... 1737.177687: rtos_queue_peek_from_isr_failed: tstamp:54570584950 queue:0x0b4b4500
vi-output, imx5-10502 [005] .... 1737.256209: tegra_channel_capture_frame: sof:1737.150491013
kworker/4:3-10166 [004] .... 1737.289699: rtcpu_vinotify_event: tstamp:54573130157 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:54573129486 data:0x176f0002
kworker/4:3-10166 [004] .... 1737.289702: rtcpu_vinotify_event: tstamp:54573130280 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:54573129502 data:0x00000000
kworker/4:3-10166 [004] .... 1737.289702: rtcpu_vinotify_event: tstamp:54573178269 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:54573177778 data:0x00000001
kworker/4:3-10166 [004] .... 1737.289703: rtcpu_vinotify_event: tstamp:54573178432 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:54573177781 data:0x00000000
kworker/4:3-10166 [004] .... 1737.289703: rtcpu_vinotify_event: tstamp:54573181189 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:10 vi_tstamp:54573180831 data:0x08000000
kworker/4:3-10166 [004] .... 1737.345712: rtos_queue_peek_from_isr_failed: tstamp:54575584961 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1737.412231: tegra_channel_capture_frame: sof:1737.306489573
kworker/4:3-10166 [004] .... 1737.457700: rtcpu_vinotify_event: tstamp:54578005101 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:54578004441 data:0x176f0002
kworker/4:3-10166 [004] .... 1737.457704: rtcpu_vinotify_event: tstamp:54578005224 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:54578004456 data:0x00000000
kworker/4:3-10166 [004] .... 1737.457705: rtcpu_vinotify_event: tstamp:54578053226 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:54578052733 data:0x00000001
kworker/4:3-10166 [004] .... 1737.457705: rtcpu_vinotify_event: tstamp:54578053388 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:54578052736 data:0x00000000
kworker/4:3-10166 [004] .... 1737.457706: rtcpu_vinotify_event: tstamp:54578056863 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:11 vi_tstamp:54578056504 data:0x08000000
kworker/4:3-10166 [004] .... 1737.513717: rtos_queue_peek_from_isr_failed: tstamp:54580584960 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1737.568210: tegra_channel_capture_frame: sof:1737.462488069
kworker/4:3-10166 [004] .... 1737.569698: rtcpu_vinotify_event: tstamp:54582880053 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:54582879395 data:0x176f0002
kworker/4:3-10166 [004] .... 1737.569699: rtcpu_vinotify_event: tstamp:54582880176 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:54582879410 data:0x00000000
kworker/4:3-10166 [004] .... 1737.569700: rtcpu_vinotify_event: tstamp:54582928176 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:54582927686 data:0x00000001
kworker/4:3-10166 [004] .... 1737.569700: rtcpu_vinotify_event: tstamp:54582928338 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:54582927690 data:0x00000000
kworker/4:3-10166 [004] .... 1737.569701: rtcpu_vinotify_event: tstamp:54582931199 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:54582930841 data:0x08000000
kworker/4:3-10166 [004] .... 1737.681734: rtos_queue_peek_from_isr_failed: tstamp:54585584973 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1737.724199: tegra_channel_capture_frame: sof:1737.618486597
kworker/4:3-10166 [004] .... 1737.737709: rtcpu_vinotify_event: tstamp:54587755007 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:54587754349 data:0x176f0002
kworker/4:3-10166 [004] .... 1737.737712: rtcpu_vinotify_event: tstamp:54587755135 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:54587754364 data:0x00000000
kworker/4:3-10166 [004] .... 1737.737712: rtcpu_vinotify_event: tstamp:54587803133 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:54587802640 data:0x00000001
kworker/4:3-10166 [004] .... 1737.737713: rtcpu_vinotify_event: tstamp:54587803302 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:54587802643 data:0x00000000
kworker/4:3-10166 [004] .... 1737.737713: rtcpu_vinotify_event: tstamp:54587805893 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:13 vi_tstamp:54587805536 data:0x08000000
kworker/4:3-10166 [004] .... 1737.849709: rtos_queue_peek_from_isr_failed: tstamp:54590584976 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1737.880196: tegra_channel_capture_frame: sof:1737.774485157
kworker/4:3-10166 [004] .... 1737.909730: rtcpu_vinotify_event: tstamp:54592629964 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:54592629303 data:0x176f0002
kworker/4:3-10166 [004] .... 1737.909733: rtcpu_vinotify_event: tstamp:54592630090 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:54592629317 data:0x00000000
kworker/4:3-10166 [004] .... 1737.909733: rtcpu_vinotify_event: tstamp:54592678089 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:54592677595 data:0x00000001
kworker/4:3-10166 [004] .... 1737.909734: rtcpu_vinotify_event: tstamp:54592678251 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:54592677598 data:0x00000000
kworker/4:3-10166 [004] .... 1737.909734: rtcpu_vinotify_event: tstamp:54592680772 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:14 vi_tstamp:54592680413 data:0x08000000
kworker/4:3-10166 [004] .... 1738.021730: rtos_queue_peek_from_isr_failed: tstamp:54595584997 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1738.036280: tegra_channel_capture_frame: sof:1737.930483653
kworker/4:3-10166 [004] .... 1738.077718: rtcpu_vinotify_event: tstamp:54597504941 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:54597504257 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.077721: rtcpu_vinotify_event: tstamp:54597505064 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:54597504272 data:0x00000000
kworker/4:3-10166 [004] .... 1738.077721: rtcpu_vinotify_event: tstamp:54597553045 tag:CHANSEL_PXL_SOF channel:0x00 frame:15 vi_tstamp:54597552548 data:0x00000001
kworker/4:3-10166 [004] .... 1738.077722: rtcpu_vinotify_event: tstamp:54597553205 tag:ATOMP_FS channel:0x00 frame:15 vi_tstamp:54597552552 data:0x00000000
kworker/4:3-10166 [004] .... 1738.077722: rtcpu_vinotify_event: tstamp:54597558610 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:15 vi_tstamp:54597558253 data:0x08000000
kworker/4:3-10166 [004] .... 1738.133714: rtos_queue_peek_from_isr_failed: tstamp:54600584996 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1738.192194: tegra_channel_capture_frame: sof:1738.86482213
kworker/4:3-10166 [004] .... 1738.245708: rtcpu_vinotify_event: tstamp:54602379872 tag:CHANSEL_PXL_EOF channel:0x00 frame:15 vi_tstamp:54602379212 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.245712: rtcpu_vinotify_event: tstamp:54602379995 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:54602379227 data:0x00000000
kworker/4:3-10166 [004] .... 1738.245712: rtcpu_vinotify_event: tstamp:54602427995 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:54602427503 data:0x00000001
kworker/4:3-10166 [004] .... 1738.245713: rtcpu_vinotify_event: tstamp:54602428157 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:54602427506 data:0x00000000
kworker/4:3-10166 [004] .... 1738.245714: rtcpu_vinotify_event: tstamp:54602430713 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:16 vi_tstamp:54602430355 data:0x08000000
kworker/4:3-10166 [004] .... 1738.301703: rtos_queue_peek_from_isr_failed: tstamp:54605584997 queue:0x0b4b4500
vi-output, imx5-10502 [005] .... 1738.348203: tegra_channel_capture_frame: sof:1738.242480741
kworker/4:3-10166 [004] .... 1738.357697: rtcpu_vinotify_event: tstamp:54607254826 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:54607254166 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.357700: rtcpu_vinotify_event: tstamp:54607254949 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:54607254180 data:0x00000000
kworker/4:3-10166 [004] .... 1738.357701: rtcpu_vinotify_event: tstamp:54607302951 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:54607302457 data:0x00000001
kworker/4:3-10166 [004] .... 1738.357702: rtcpu_vinotify_event: tstamp:54607303113 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:54607302460 data:0x00000000
kworker/4:3-10166 [004] .... 1738.357702: rtcpu_vinotify_event: tstamp:54607306011 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:17 vi_tstamp:54607305654 data:0x08000000
kworker/4:3-10166 [004] .... 1738.473690: rtos_queue_peek_from_isr_failed: tstamp:54610585007 queue:0x0b4b4500
vi-output, imx5-10502 [005] .... 1738.504197: tegra_channel_capture_frame: sof:1738.398479269
kworker/4:3-10166 [004] .... 1738.529714: rtcpu_vinotify_event: tstamp:54612129780 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:54612129119 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.529717: rtcpu_vinotify_event: tstamp:54612129905 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:54612129134 data:0x00000000
kworker/4:3-10166 [004] .... 1738.529718: rtcpu_vinotify_event: tstamp:54612177903 tag:CHANSEL_PXL_SOF channel:0x00 frame:18 vi_tstamp:54612177411 data:0x00000001
kworker/4:3-10166 [004] .... 1738.529718: rtcpu_vinotify_event: tstamp:54612178066 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:54612177415 data:0x00000000
kworker/4:3-10166 [004] .... 1738.529719: rtcpu_vinotify_event: tstamp:54612180806 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:18 vi_tstamp:54612180449 data:0x08000000
kworker/4:3-10166 [004] .... 1738.641751: rtos_queue_peek_from_isr_failed: tstamp:54615585010 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1738.660191: tegra_channel_capture_frame: sof:1738.554477797
kworker/4:3-10166 [004] .... 1738.697705: rtcpu_vinotify_event: tstamp:54617004732 tag:CHANSEL_PXL_EOF channel:0x00 frame:18 vi_tstamp:54617004074 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.697709: rtcpu_vinotify_event: tstamp:54617004860 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:54617004089 data:0x00000000
kworker/4:3-10166 [004] .... 1738.697710: rtcpu_vinotify_event: tstamp:54617052857 tag:CHANSEL_PXL_SOF channel:0x00 frame:19 vi_tstamp:54617052365 data:0x00000001
kworker/4:3-10166 [004] .... 1738.697710: rtcpu_vinotify_event: tstamp:54617053018 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:54617052368 data:0x00000000
kworker/4:3-10166 [004] .... 1738.697711: rtcpu_vinotify_event: tstamp:54617055614 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:19 vi_tstamp:54617055256 data:0x08000000
kworker/4:3-10166 [004] .... 1738.809713: rtos_queue_peek_from_isr_failed: tstamp:54620585017 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1738.816205: tegra_channel_capture_frame: sof:1738.710476357
kworker/4:3-10166 [004] .... 1738.865708: rtcpu_vinotify_event: tstamp:54621879689 tag:CHANSEL_PXL_EOF channel:0x00 frame:19 vi_tstamp:54621879028 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.865711: rtcpu_vinotify_event: tstamp:54621879812 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:54621879043 data:0x00000000
kworker/4:3-10166 [004] .... 1738.865712: rtcpu_vinotify_event: tstamp:54621927810 tag:CHANSEL_PXL_SOF channel:0x00 frame:20 vi_tstamp:54621927320 data:0x00000001
kworker/4:3-10166 [004] .... 1738.865712: rtcpu_vinotify_event: tstamp:54621927975 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:54621927323 data:0x00000000
kworker/4:3-10166 [004] .... 1738.865713: rtcpu_vinotify_event: tstamp:54621931083 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:20 vi_tstamp:54621930725 data:0x08000000
vi-output, imx5-10502 [005] .... 1738.972190: tegra_channel_capture_frame: sof:1738.866474853
kworker/4:3-10166 [004] .... 1738.977724: rtos_queue_peek_from_isr_failed: tstamp:54625585023 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1738.977727: rtcpu_vinotify_event: tstamp:54626754640 tag:CHANSEL_PXL_EOF channel:0x00 frame:20 vi_tstamp:54626753982 data:0x176f0002
kworker/4:3-10166 [004] .... 1738.977728: rtcpu_vinotify_event: tstamp:54626754765 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:54626753997 data:0x00000000
kworker/4:3-10166 [004] .... 1738.977728: rtcpu_vinotify_event: tstamp:54626802768 tag:CHANSEL_PXL_SOF channel:0x00 frame:21 vi_tstamp:54626802273 data:0x00000001
kworker/4:3-10166 [004] .... 1738.977729: rtcpu_vinotify_event: tstamp:54626802929 tag:ATOMP_FS channel:0x00 frame:21 vi_tstamp:54626802277 data:0x00000000
kworker/4:3-10166 [004] .... 1738.977729: rtcpu_vinotify_event: tstamp:54626805618 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:21 vi_tstamp:54626805261 data:0x08000000
vi-output, imx5-10502 [005] .... 1739.128195: tegra_channel_capture_frame: sof:1739.22473413
kworker/4:3-10166 [004] .... 1739.145719: rtos_queue_peek_from_isr_failed: tstamp:54630585031 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1739.145724: rtcpu_vinotify_event: tstamp:54631629599 tag:CHANSEL_PXL_EOF channel:0x00 frame:21 vi_tstamp:54631628936 data:0x176f0002
kworker/4:3-10166 [004] .... 1739.145725: rtcpu_vinotify_event: tstamp:54631629724 tag:ATOMP_FE channel:0x00 frame:21 vi_tstamp:54631628951 data:0x00000000
kworker/4:3-10166 [004] .... 1739.145726: rtcpu_vinotify_event: tstamp:54631677719 tag:CHANSEL_PXL_SOF channel:0x00 frame:22 vi_tstamp:54631677228 data:0x00000001
kworker/4:3-10166 [004] .... 1739.145727: rtcpu_vinotify_event: tstamp:54631677886 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:54631677231 data:0x00000000
kworker/4:3-10166 [004] .... 1739.145727: rtcpu_vinotify_event: tstamp:54631680766 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:22 vi_tstamp:54631680409 data:0x08000000
kworker/4:3-10166 [004] .... 1739.257757: rtos_queue_peek_from_isr_failed: tstamp:54635585038 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1739.284184: tegra_channel_capture_frame: sof:1739.178471941
kworker/4:3-10166 [004] .... 1739.313769: rtcpu_vinotify_event: tstamp:54636504552 tag:CHANSEL_PXL_EOF channel:0x00 frame:22 vi_tstamp:54636503891 data:0x176f0002
kworker/4:3-10166 [004] .... 1739.313774: rtcpu_vinotify_event: tstamp:54636504678 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:54636503905 data:0x00000000
kworker/4:3-10166 [004] .... 1739.313776: rtcpu_vinotify_event: tstamp:54636552676 tag:CHANSEL_PXL_SOF channel:0x00 frame:23 vi_tstamp:54636552182 data:0x00000001
kworker/4:3-10166 [004] .... 1739.313777: rtcpu_vinotify_event: tstamp:54636552838 tag:ATOMP_FS channel:0x00 frame:23 vi_tstamp:54636552185 data:0x00000000
kworker/4:3-10166 [004] .... 1739.313778: rtcpu_vinotify_event: tstamp:54636555401 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:23 vi_tstamp:54636555044 data:0x08000000
kworker/4:3-10166 [004] .... 1739.425713: rtos_queue_peek_from_isr_failed: tstamp:54640585045 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1739.440211: tegra_channel_capture_frame: sof:1739.334470469
kworker/4:3-10166 [004] .... 1739.481738: rtcpu_vinotify_event: tstamp:54641379501 tag:CHANSEL_PXL_EOF channel:0x00 frame:23 vi_tstamp:54641378844 data:0x176f0002
kworker/4:3-10166 [004] .... 1739.481741: rtcpu_vinotify_event: tstamp:54641379625 tag:ATOMP_FE channel:0x00 frame:23 vi_tstamp:54641378860 data:0x00000000
kworker/4:3-10166 [004] .... 1739.481742: rtcpu_vinotify_event: tstamp:54641427637 tag:CHANSEL_PXL_SOF channel:0x00 frame:24 vi_tstamp:54641427136 data:0x00000001
kworker/4:3-10166 [004] .... 1739.481742: rtcpu_vinotify_event: tstamp:54641427799 tag:ATOMP_FS channel:0x00 frame:24 vi_tstamp:54641427140 data:0x00000000
kworker/4:3-10166 [004] .... 1739.481743: rtcpu_vinotify_event: tstamp:54641431281 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:24 vi_tstamp:54641430922 data:0x08000000
kworker/4:3-10166 [004] .... 1739.593710: rtos_queue_peek_from_isr_failed: tstamp:54645585054 queue:0x0b4b4500
vi-output, imx5-10502 [004] .... 1739.596189: tegra_channel_capture_frame: sof:1739.490468997
kworker/4:3-10166 [004] .... 1739.649726: rtcpu_vinotify_event: tstamp:54646254457 tag:CHANSEL_PXL_EOF channel:0x00 frame:24 vi_tstamp:54646253799 data:0x176f0002
kworker/4:3-10166 [004] .... 1739.649729: rtcpu_vinotify_event: tstamp:54646254580 tag:ATOMP_FE channel:0x00 frame:24 vi_tstamp:54646253814 data:0x00000000
kworker/4:3-10166 [004] .... 1739.649730: rtcpu_vinotify_event: tstamp:54646302583 tag:CHANSEL_PXL_SOF channel:0x00 frame:25 vi_tstamp:54646302090 data:0x00000001
kworker/4:3-10166 [004] .... 1739.649730: rtcpu_vinotify_event: tstamp:54646302746 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:54646302093 data:0x00000000
kworker/4:3-10166 [004] .... 1739.649731: rtcpu_vinotify_event: tstamp:54646305514 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:25 vi_tstamp:54646305159 data:0x08000000
vi-output, imx5-10502 [004] .... 1739.752184: tegra_channel_capture_frame: sof:1739.646467525
kworker/4:3-10166 [004] .... 1739.761744: rtos_queue_peek_from_isr_failed: tstamp:54650585064 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1739.761747: rtcpu_vinotify_event: tstamp:54651129413 tag:CHANSEL_PXL_EOF channel:0x00 frame:25 vi_tstamp:54651128753 data:0x176f0002
kworker/4:3-10166 [004] .... 1739.761748: rtcpu_vinotify_event: tstamp:54651129540 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:54651128767 data:0x00000000
kworker/4:3-10166 [004] .... 1739.761749: rtcpu_vinotify_event: tstamp:54651177538 tag:CHANSEL_PXL_SOF channel:0x00 frame:26 vi_tstamp:54651177044 data:0x00000001
kworker/4:3-10166 [004] .... 1739.761749: rtcpu_vinotify_event: tstamp:54651177719 tag:ATOMP_FS channel:0x00 frame:26 vi_tstamp:54651177047 data:0x00000000
kworker/4:3-10166 [004] .... 1739.761750: rtcpu_vinotify_event: tstamp:54651180364 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:26 vi_tstamp:54651180008 data:0x08000000
vi-output, imx5-10502 [004] .... 1739.908185: tegra_channel_capture_frame: sof:1739.802466053
kworker/4:3-10166 [004] .... 1739.929783: rtos_queue_peek_from_isr_failed: tstamp:54655585064 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1739.929791: rtcpu_vinotify_event: tstamp:54656004374 tag:CHANSEL_PXL_EOF channel:0x00 frame:26 vi_tstamp:54656003707 data:0x176f0002
kworker/4:3-10166 [004] .... 1739.929792: rtcpu_vinotify_event: tstamp:54656004490 tag:ATOMP_FE channel:0x00 frame:26 vi_tstamp:54656003722 data:0x00000000
kworker/4:3-10166 [004] .... 1739.929794: rtcpu_vinotify_event: tstamp:54656052500 tag:CHANSEL_PXL_SOF channel:0x00 frame:27 vi_tstamp:54656051998 data:0x00000001
kworker/4:3-10166 [004] .... 1739.929796: rtcpu_vinotify_event: tstamp:54656052667 tag:ATOMP_FS channel:0x00 frame:27 vi_tstamp:54656052002 data:0x00000000
kworker/4:3-10166 [004] .... 1739.929798: rtcpu_vinotify_event: tstamp:54656055443 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:27 vi_tstamp:54656055086 data:0x08000000
vi-output, imx5-10502 [004] .... 1740.064195: tegra_channel_capture_frame: sof:1739.958464613
kworker/4:3-10166 [004] .... 1740.097745: rtos_queue_peek_from_isr_failed: tstamp:54660585072 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1740.097749: rtcpu_vinotify_event: tstamp:54660879315 tag:CHANSEL_PXL_EOF channel:0x00 frame:27 vi_tstamp:54660878661 data:0x176f0002
kworker/4:3-10166 [004] .... 1740.097750: rtcpu_vinotify_event: tstamp:54660879432 tag:ATOMP_FE channel:0x00 frame:27 vi_tstamp:54660878676 data:0x00000000
kworker/4:3-10166 [004] .... 1740.097751: rtcpu_vinotify_event: tstamp:54660927448 tag:CHANSEL_PXL_SOF channel:0x00 frame:28 vi_tstamp:54660926953 data:0x00000001
kworker/4:3-10166 [004] .... 1740.097751: rtcpu_vinotify_event: tstamp:54660927611 tag:ATOMP_FS channel:0x00 frame:28 vi_tstamp:54660926956 data:0x00000000
kworker/4:3-10166 [004] .... 1740.097752: rtcpu_vinotify_event: tstamp:54660930765 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:28 vi_tstamp:54660930408 data:0x08000000
vi-output, imx5-10502 [004] .... 1740.220199: tegra_channel_capture_frame: sof:1740.114463141
kworker/4:3-10166 [004] .... 1740.265772: rtos_queue_peek_from_isr_failed: tstamp:54665585079 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1740.265777: rtcpu_vinotify_event: tstamp:54665754271 tag:CHANSEL_PXL_EOF channel:0x00 frame:28 vi_tstamp:54665753616 data:0x176f0002
kworker/4:3-10166 [004] .... 1740.265777: rtcpu_vinotify_event: tstamp:54665754397 tag:ATOMP_FE channel:0x00 frame:28 vi_tstamp:54665753630 data:0x00000000
kworker/4:3-10166 [004] .... 1740.265778: rtcpu_vinotify_event: tstamp:54665802398 tag:CHANSEL_PXL_SOF channel:0x00 frame:29 vi_tstamp:54665801907 data:0x00000001
kworker/4:3-10166 [004] .... 1740.265779: rtcpu_vinotify_event: tstamp:54665802560 tag:ATOMP_FS channel:0x00 frame:29 vi_tstamp:54665801910 data:0x00000000
kworker/4:3-10166 [004] .... 1740.265779: rtcpu_vinotify_event: tstamp:54665805901 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:29 vi_tstamp:54665805544 data:0x08000000
vi-output, imx5-10502 [004] .... 1740.376180: tegra_channel_capture_frame: sof:1740.270461637
kworker/4:3-10166 [004] .... 1740.377750: rtos_queue_peek_from_isr_failed: tstamp:54670585088 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1740.377753: rtcpu_vinotify_event: tstamp:54670629236 tag:CHANSEL_PXL_EOF channel:0x00 frame:29 vi_tstamp:54670628569 data:0x176f0002
kworker/4:3-10166 [004] .... 1740.377754: rtcpu_vinotify_event: tstamp:54670629355 tag:ATOMP_FE channel:0x00 frame:29 vi_tstamp:54670628584 data:0x00000000
kworker/4:3-10166 [004] .... 1740.377754: rtcpu_vinotify_event: tstamp:54670677354 tag:CHANSEL_PXL_SOF channel:0x00 frame:30 vi_tstamp:54670676860 data:0x00000001
kworker/4:3-10166 [004] .... 1740.377755: rtcpu_vinotify_event: tstamp:54670677519 tag:ATOMP_FS channel:0x00 frame:30 vi_tstamp:54670676864 data:0x00000000
kworker/4:3-10166 [004] .... 1740.377755: rtcpu_vinotify_event: tstamp:54670680266 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:30 vi_tstamp:54670679909 data:0x08000000
vi-output, imx5-10502 [004] .... 1740.532174: tegra_channel_capture_frame: sof:1740.426460197
kworker/4:3-10166 [004] .... 1740.545757: rtcpu_vinotify_event: tstamp:54675504178 tag:CHANSEL_PXL_EOF channel:0x00 frame:30 vi_tstamp:54675503523 data:0x176f0002
kworker/4:3-10166 [004] .... 1740.545760: rtcpu_vinotify_event: tstamp:54675504303 tag:ATOMP_FE channel:0x00 frame:30 vi_tstamp:54675503538 data:0x00000000
kworker/4:3-10166 [004] .... 1740.545760: rtcpu_vinotify_event: tstamp:54675552306 tag:CHANSEL_PXL_SOF channel:0x00 frame:31 vi_tstamp:54675551815 data:0x00000001
kworker/4:3-10166 [004] .... 1740.545761: rtcpu_vinotify_event: tstamp:54675552468 tag:ATOMP_FS channel:0x00 frame:31 vi_tstamp:54675551818 data:0x00000000
kworker/4:3-10166 [004] .... 1740.545762: rtcpu_vinotify_event: tstamp:54675555117 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:31 vi_tstamp:54675554759 data:0x08000000
kworker/4:3-10166 [004] .... 1740.545764: rtos_queue_peek_from_isr_failed: tstamp:54675585088 queue:0x0b4b4500
v4l2-ctl-10501 [000] .... 1740.619580: tegra_channel_close: vi-output, imx586 2-001a
vi-output, imx5-10502 [000] .... 1740.688166: tegra_channel_capture_frame: sof:1740.582458757
kworker/4:3-10166 [004] .... 1740.713743: rtcpu_vinotify_event: tstamp:54680379139 tag:CHANSEL_PXL_EOF channel:0x00 frame:31 vi_tstamp:54680378478 data:0x176f0002
kworker/4:3-10166 [004] .... 1740.713747: rtcpu_vinotify_event: tstamp:54680379262 tag:ATOMP_FE channel:0x00 frame:31 vi_tstamp:54680378492 data:0x00000000
kworker/4:3-10166 [004] .... 1740.713748: rtcpu_vinotify_event: tstamp:54680427261 tag:CHANSEL_PXL_SOF channel:0x00 frame:32 vi_tstamp:54680426770 data:0x00000001
kworker/4:3-10166 [004] .... 1740.713749: rtcpu_vinotify_event: tstamp:54680427425 tag:ATOMP_FS channel:0x00 frame:32 vi_tstamp:54680426773 data:0x00000000
kworker/4:3-10166 [004] .... 1740.713749: rtcpu_vinotify_event: tstamp:54680430366 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:32 vi_tstamp:54680430009 data:0x08000000
kworker/4:3-10166 [004] .... 1740.713752: rtos_queue_peek_from_isr_failed: tstamp:54680585093 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1740.881746: rtcpu_vinotify_event: tstamp:54685254091 tag:CHANSEL_PXL_EOF channel:0x00 frame:32 vi_tstamp:54685253432 data:0x176f0002
kworker/4:3-10166 [004] .... 1740.881750: rtcpu_vinotify_event: tstamp:54685254214 tag:ATOMP_FE channel:0x00 frame:32 vi_tstamp:54685253447 data:0x00000000
kworker/4:3-10166 [004] .... 1740.881752: rtcpu_vinotify_event: tstamp:54685302216 tag:CHANSEL_PXL_SOF channel:0x00 frame:33 vi_tstamp:54685301723 data:0x00000001
kworker/4:3-10166 [004] .... 1740.881752: rtcpu_vinotify_event: tstamp:54685302378 tag:ATOMP_FS channel:0x00 frame:33 vi_tstamp:54685301727 data:0x00000000
kworker/4:3-10166 [004] .... 1740.881755: rtos_queue_peek_from_isr_failed: tstamp:54685585100 queue:0x0b4b4500
v4l2-ctl-10501 [003] .... 1740.906096: tegra_channel_capture_setup: vnc_id 0 W 8000 H 6000 fmt 20
v4l2-ctl-10501 [003] .... 1740.906125: tegra_channel_capture_done: eof:0.-266613294424
v4l2-ctl-10501 [003] .... 1740.906331: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-10501 [003] .... 1740.906333: tegra_channel_set_stream: imx586 2-001a : 0x0
v4l2-ctl-10501 [000] .... 1740.908255: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-10501 [000] .... 1740.908259: csi_s_stream: enable : 0x0
kworker/4:3-10166 [004] .... 1740.937736: rtos_queue_send_from_isr_failed: tstamp:54687212736 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937739: rtos_queue_send_from_isr_failed: tstamp:54687212855 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1740.937740: rtos_queue_send_from_isr_failed: tstamp:54687212962 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1740.937741: rtos_queue_send_from_isr_failed: tstamp:54687213070 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1740.937741: rtos_queue_send_from_isr_failed: tstamp:54687213176 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1740.937742: rtos_queue_send_from_isr_failed: tstamp:54687213284 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1740.937743: rtos_queue_send_from_isr_failed: tstamp:54687213388 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1740.937743: rtos_queue_send_from_isr_failed: tstamp:54687213491 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1740.937745: rtcpu_vinotify_event: tstamp:54687215329 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:33 vi_tstamp:54687213837 data:0x08000000
kworker/4:3-10166 [004] .... 1740.937746: rtcpu_vinotify_event: tstamp:54687215451 tag:CHANSEL_FAULT_FE channel:0x01 frame:33 vi_tstamp:54687213839 data:0x00000001
kworker/4:3-10166 [004] .... 1740.937746: rtcpu_vinotify_event: tstamp:54687215645 tag:ATOMP_FE channel:0x00 frame:33 vi_tstamp:54687213839 data:0x00000000
kworker/4:3-10166 [004] .... 1740.937748: rtos_queue_send_failed: tstamp:54687219341 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937749: rtos_queue_send_from_isr_failed: tstamp:54687223385 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937750: rtos_queue_send_from_isr_failed: tstamp:54687223493 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1740.937750: rtos_queue_send_from_isr_failed: tstamp:54687223599 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1740.937751: rtos_queue_send_from_isr_failed: tstamp:54687223705 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1740.937752: rtos_queue_send_from_isr_failed: tstamp:54687223809 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1740.937752: rtos_queue_send_from_isr_failed: tstamp:54687223914 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1740.937753: rtos_queue_send_from_isr_failed: tstamp:54687224019 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1740.937754: rtos_queue_send_from_isr_failed: tstamp:54687224135 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1740.937754: rtos_queue_send_failed: tstamp:54687224568 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937755: rtos_queue_send_from_isr_failed: tstamp:54687232938 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937756: rtos_queue_send_from_isr_failed: tstamp:54687233052 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1740.937756: rtos_queue_send_from_isr_failed: tstamp:54687233158 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1740.937757: rtos_queue_send_from_isr_failed: tstamp:54687233266 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1740.937758: rtos_queue_send_from_isr_failed: tstamp:54687233371 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1740.937759: rtos_queue_send_from_isr_failed: tstamp:54687233485 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1740.937759: rtos_queue_send_from_isr_failed: tstamp:54687233590 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1740.937760: rtos_queue_send_from_isr_failed: tstamp:54687233695 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1740.937761: rtos_queue_send_failed: tstamp:54687234127 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937761: rtos_queue_send_from_isr_failed: tstamp:54687236256 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937762: rtos_queue_send_from_isr_failed: tstamp:54687236371 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1740.937763: rtos_queue_send_from_isr_failed: tstamp:54687236478 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1740.937763: rtos_queue_send_from_isr_failed: tstamp:54687236584 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1740.937764: rtos_queue_send_from_isr_failed: tstamp:54687236689 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1740.937764: rtos_queue_send_from_isr_failed: tstamp:54687236798 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1740.937765: rtos_queue_send_from_isr_failed: tstamp:54687236903 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1740.937766: rtos_queue_send_from_isr_failed: tstamp:54687237009 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1740.937767: rtos_queue_send_failed: tstamp:54687237930 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937767: rtos_queue_send_from_isr_failed: tstamp:54687240737 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937768: rtos_queue_send_from_isr_failed: tstamp:54687240845 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1740.937768: rtos_queue_send_from_isr_failed: tstamp:54687240953 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1740.937769: rtos_queue_send_from_isr_failed: tstamp:54687241060 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1740.937770: rtos_queue_send_from_isr_failed: tstamp:54687241165 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1740.937770: rtos_queue_send_from_isr_failed: tstamp:54687241270 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1740.937771: rtos_queue_send_from_isr_failed: tstamp:54687241375 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1740.937772: rtos_queue_send_from_isr_failed: tstamp:54687241484 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1740.937772: rtos_queue_send_failed: tstamp:54687242034 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937773: rtos_queue_send_from_isr_failed: tstamp:54687243756 queue:0x0b4a7258
kworker/4:3-10166 [004] .... 1740.937774: rtos_queue_send_from_isr_failed: tstamp:54687243865 queue:0x0b4aad68
kworker/4:3-10166 [004] .... 1740.937774: rtos_queue_send_from_isr_failed: tstamp:54687243971 queue:0x0b4ac998
kworker/4:3-10166 [004] .... 1740.937775: rtos_queue_send_from_isr_failed: tstamp:54687244078 queue:0x0b4ae518
kworker/4:3-10166 [004] .... 1740.937776: rtos_queue_send_from_isr_failed: tstamp:54687244182 queue:0x0b4af2d8
kworker/4:3-10166 [004] .... 1740.937776: rtos_queue_send_from_isr_failed: tstamp:54687244290 queue:0x0b4b0098
kworker/4:3-10166 [004] .... 1740.937777: rtos_queue_send_from_isr_failed: tstamp:54687244395 queue:0x0b4b0e58
kworker/4:3-10166 [004] .... 1740.937778: rtos_queue_send_from_isr_failed: tstamp:54687244500 queue:0x0b4b1c18
kworker/4:3-10166 [004] .... 1740.937778: rtos_queue_send_failed: tstamp:54687244928 queue:0x0b4a7258
v4l2-ctl-10501 [003] .... 1740.961547: tegra_channel_set_power: imx586 2-001a : 0x0
v4l2-ctl-10501 [003] .... 1740.961561: camera_common_s_power: status : 0x0
v4l2-ctl-10501 [005] .... 1740.961756: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-10501 [005] .... 1740.961760: csi_s_power: enable : 0x0
kworker/4:3-10166 [004] .... 1741.049781: rtos_queue_peek_from_isr_failed: tstamp:54690585132 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1741.217766: rtos_queue_peek_from_isr_failed: tstamp:54695585121 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1741.385757: rtos_queue_peek_from_isr_failed: tstamp:54700585129 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1741.497836: rtos_queue_peek_from_isr_failed: tstamp:54705585136 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1741.665834: rtos_queue_peek_from_isr_failed: tstamp:54710585143 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1741.833772: rtos_queue_peek_from_isr_failed: tstamp:54715585148 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.001802: rtos_queue_peek_from_isr_failed: tstamp:54720585149 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.169754: rtos_queue_peek_from_isr_failed: tstamp:54725585162 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.337764: rtos_queue_peek_from_isr_failed: tstamp:54730585179 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.505789: rtos_queue_peek_from_isr_failed: tstamp:54735585176 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.617780: rtos_queue_peek_from_isr_failed: tstamp:54740585182 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.785762: rtos_queue_peek_from_isr_failed: tstamp:54745585189 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1742.953775: rtos_queue_peek_from_isr_failed: tstamp:54750585194 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1743.121772: rtos_queue_peek_from_isr_failed: tstamp:54755585203 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1743.289799: rtos_queue_peek_from_isr_failed: tstamp:54760585211 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1743.457794: rtos_queue_peek_from_isr_failed: tstamp:54765585215 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1743.625799: rtos_queue_peek_from_isr_failed: tstamp:54770585231 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1743.737803: rtos_queue_peek_from_isr_failed: tstamp:54775585227 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1743.905818: rtos_queue_peek_from_isr_failed: tstamp:54780585228 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1744.073866: rtos_queue_peek_from_isr_failed: tstamp:54785585247 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1744.241785: rtos_queue_peek_from_isr_failed: tstamp:54790585253 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1744.409823: rtos_queue_peek_from_isr_failed: tstamp:54795585255 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1744.577797: rtos_queue_peek_from_isr_failed: tstamp:54800585261 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1744.745866: rtos_queue_peek_from_isr_failed: tstamp:54805585272 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1744.857849: rtos_queue_peek_from_isr_failed: tstamp:54810585278 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.025789: rtos_queue_peek_from_isr_failed: tstamp:54815585286 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.193878: rtos_queue_peek_from_isr_failed: tstamp:54820585293 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.361875: rtos_queue_peek_from_isr_failed: tstamp:54825585300 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.529793: rtos_queue_peek_from_isr_failed: tstamp:54830585305 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.697801: rtos_queue_peek_from_isr_failed: tstamp:54835585308 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.865792: rtos_queue_peek_from_isr_failed: tstamp:54840585309 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1745.978023: rtos_queue_peek_from_isr_failed: tstamp:54845585325 queue:0x0b4b4500
kworker/4:3-10166 [004] .... 1746.033861: rtos_queue_peek_from_isr_failed: tstamp:54846233379 queue:0x0b4b4500
What do you think will lead to this problem? And will this have an impact on GStreamer?
Thanks and Best Regards!
Hellow!
I found the problem. The camera in 4000 * 3000 resolution mode is wrong due to my wrong register setting.
Now that the modification is complete, I can turn on the camera using the GStreamer command.
gst-launch-1.0 --gst-debug-level=4 nvarguscamerasrc sensor-mode=3 sensor_id=0 ! ‘video/x-raw(memory:NVMM),width=4000, height=3000, framerate=24/1’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=720, format=RGBA’ ! nvvidconv ! nvegltransform ! nveglglessink -e
