Gstreamer vanishing constantly on NVIDIA jetson NX
Hello, we’re trying to use Xavier NX on a drone and we planned to stream the video feed of the camera by opencv and gstreamer through logging on on a companion computer (ssh method)
We download gstreamer with opencv
We logging run the code, no video is streamed when we connect out jetson back to a monitor and run cv2.getBuildInformation we see gstreamer: NO, now note before everything the command is always gstreamer:YES
Its like jetson deletes our gstreamer Everytime we download it try to run the code, then error no gstreamer, or cannot open video writer, encoding failed Code sample
We use this code to receive streaming from running the code : gst-launch-1.0 -v udpsrc port=5000 caps=“application/x-rtp, media=video, encoding-name=H264, payload=96” ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink sync=false
We would love any help we can find or if anyone else is facing this problem
The default OpenCV package installed through SDKManager enables gstreamer. It looks like you later install another package which does not enable gstreamer. If the default one does not fit your use-case, you may try the script to manually build and install OpenCV:
JEP/script at master · AastaNV/JEP · GitHub
