GTX 1650(notebook) - installed nvidia drivers does not work
I have notebook with Ryzen 5 and GTX1650. I installed the drivers nvidia-driver-430 for GTX1650 (notebook) using
sudo add-apt-repository ppa:graphics-drivers/ppa && sudo apt update
Selecting from the list in “Additional drivers”, reboot and it’s not working.
code: nvidia-smi
| NVIDIA-SMI 430.26       Driver Version: 430.26       CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 1650    Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   36C    P8     1W /  N/A |      0MiB /  3911MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
code: nvidia-settings
ERROR: Unable to load info from any available system
(nvidia-settings:10483): GLib-GObject-CRITICAL **: 11:19:08.245: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 11:19:08.248: PRIME: No offloading required. Abort
** Message: 11:19:08.248: PRIME: is it supported? no
When I am looking for drivers on GeForce,com it shows me for my GTX1650(notebooks) drivers 430.09 not 430.26. Can it be a reason that it does not work?
I’m a beginner and I will be grateful for any help. If you know the answer, tell me step by step what I should do. THX
nvidia-bug-report.log.gz (1.08 MB)
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
[url]https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/[/url]
It’s an Optimus system, meaning hybrid amd/nvidia graphics. Currently, the needed amd gpu is not working because it needs kernel 5.1, please install it http://www.theubuntumaniac.com/2019/07/how-to-install-linux-kernel-5116-stable.html
Please make sure nvidia-prime is installed
sudo apt install nvidia-prime
and switch to nvidia profile
sudo prime-select nvidia
then modify /usr/share/X11/xorg.conf.d/10-amdgpu.conf
replacing only
Driver "amdgpu"
with
Driver "modesetting"
and reboot.
Afterwards, please create a new nvidia-bug-report.log.
Forgot:
Also, please add
Option "PrimaryGPU" "Yes"
inside the OutputClass of /usr/share/X11/xorg.conf.d/10-nvidia.conf
