Gym fails to import meshes in MJCF files if their path is set by the <compiler meshdir="/path"> tag
Unable to load MJCFs using <compiler meshdir="\path">
Hi all!
I am working with (complex) custom .mjcf models in Isaac Gym, which contain a lot of different mesh assets. To avoid repetition of paths and make assembling multi-level mjcfs with includes easier, .mjcf xml allows you to prepend a path to all of your meshes by setting the meshdir attribute of your compiler element. However, Isaac Gym does not seem to prepend these paths to the file attribute of mesh assets, and throws an error such as
[Error] [carb.gym.plugin] *** Failed to load '/home/someuser/isaac_gym_env/isaacgymenvs/tasks/../../assets/mjcf/somemodel.stl'!
I am right now working around this in a very rudimentary way - if anyone knows a more elegant approach, or, better yet, a fix, it would be great!
Minimal reproducing example
To reproduce this error, create a directory named mesh_test in the assets/mjcf folder of your IsaacGymEnvs repo, place an arbitrary stl file named base.stl in it, and modify nv_ant.xml as follows:
<mujoco model="ant">
  <custom>
    <numeric data="0.0 0.0 0.55 1.0 0.0 0.0 0.0 0.0 1.0 0.0 -1.0 0.0 -1.0 0.0 1.0" name="init_qpos"/>
  </custom>
  <default>
    <joint armature="0.01" damping="0.1" limited="true"/>
    <geom condim="3" density="5.0" friction="1.5 0.1 0.1" margin="0.01" rgba="0.97 0.38 0.06 1"/>
  </default>
  <compiler inertiafromgeom="true" angle="degree"/>
  <option timestep="0.016" iterations="50" tolerance="1e-10" solver="Newton" jacobian="dense" cone="pyramidal"/>
  <size nconmax="50" njmax="200" nstack="10000"/>
  <visual>
      <map force="0.1" zfar="30"/>
      <rgba haze="0.15 0.25 0.35 1"/>
      <quality shadowsize="2048"/>
      <global offwidth="800" offheight="800"/>
  </visual>
  <!-- Test: Does IsaacGym support the "meshdir" argument of the compiler? -->
  <!-- This should work, but crashes the simulation: -->
  <compiler meshdir="mesh_test"/>
  <asset>
        <mesh name="base" file="base.stl" scale="0.001 0.001 0.001"/>
  </asset>
  <!-- This works, but causes problems for large/multilevel models
  <asset>
        <mesh name="base" file="mesh_test/base.stl" scale="0.0001 0.0001 0.0001"/>
  </asset>
  <asset>
      <texture type="skybox" builtin="gradient" rgb1="0.3 0.5 0.7" rgb2="0 0 0" width="512" height="512"/>
      <texture name="texplane" type="2d" builtin="checker" rgb1=".2 .3 .4" rgb2=".1 0.15 0.2" width="512" height="512" mark="cross" markrgb=".8 .8 .8"/>
      <texture name="texgeom" type="cube" builtin="flat" mark="cross" width="127" height="1278"
          rgb1="0.8 0.6 0.4" rgb2="0.8 0.6 0.4" markrgb="1 1 1" random="0.01"/>
      <material name="matplane" reflectance="0.3" texture="texplane" texrepeat="1 1" texuniform="true"/>
      <material name="matgeom" texture="texgeom" texuniform="true" rgba="0.8 0.6 .4 1"/>
  </asset>
  <worldbody>
    <geom name="floor" pos="0 0 0" size="0 0 .25" type="plane" material="matplane" condim="3"/>
    <light directional="false" diffuse=".2 .2 .2" specular="0 0 0" pos="0 0 5" dir="0 0 -1" castshadow="false"/>
    <light mode="targetbodycom" target="torso" directional="false" diffuse=".8 .8 .8" specular="0.3 0.3 0.3" pos="0 0 4.0" dir="0 0 -1"/>
    <body name="torso" pos="0 0 0.75">
      <freejoint name="root"/>
      <geom mesh="base"/>
      <geom name="torso_geom" pos="0 0 0" size="0.25" type="sphere"/>
      <geom fromto="0.0 0.0 0.0 0.2 0.2 0.0" name="aux_1_geom" size="0.08" type="capsule" rgba=".999 .2 .1 1"/>
      <geom fromto="0.0 0.0 0.0 -0.2 0.2 0.0" name="aux_2_geom" size="0.08" type="capsule"/>
      <geom fromto="0.0 0.0 0.0 -0.2 -0.2 0.0" name="aux_3_geom" size="0.08" type="capsule"/>
      <geom fromto="0.0 0.0 0.0 0.2 -0.2 0.0" name="aux_4_geom" size="0.08" type="capsule" rgba=".999 .2 .02 1"/>
      <body name="front_left_leg" pos="0.2 0.2 0">
        <joint axis="0 0 1" name="hip_1" pos="0.0 0.0 0.0" range="-40 40" type="hinge"/>
        <geom fromto="0.0 0.0 0.0 0.2 0.2 0.0" name="left_leg_geom" size="0.08" type="capsule" rgba=".999 .2 .1 1"/>
        <body pos="0.2 0.2 0" name="front_left_foot">
          <joint axis="-1 1 0" name="ankle_1" pos="0.0 0.0 0.0" range="30 100" type="hinge"/>
          <geom fromto="0.0 0.0 0.0 0.4 0.4 0.0" name="left_ankle_geom" size="0.08" type="capsule" rgba=".999 .2 .1 1"/>
        </body>
      </body>
      <body name="front_right_leg" pos="-0.2 0.2 0">
        <joint axis="0 0 1" name="hip_2" pos="0.0 0.0 0.0" range="-40 40" type="hinge"/>
        <geom fromto="0.0 0.0 0.0 -0.2 0.2 0.0" name="right_leg_geom" size="0.08" type="capsule"/>
        <body pos="-0.2 0.2 0" name="front_right_foot">
          <joint axis="1 1 0" name="ankle_2" pos="0.0 0.0 0.0" range="-100 -30" type="hinge"/>
          <geom fromto="0.0 0.0 0.0 -0.4 0.4 0.0" name="right_ankle_geom" size="0.08" type="capsule"/>
        </body>
      </body>
      <body name="left_back_leg" pos="-0.2 -0.2 0">
        <joint axis="0 0 1" name="hip_3" pos="0.0 0.0 0.0" range="-40 40" type="hinge"/>
        <geom fromto="0.0 0.0 0.0 -0.2 -0.2 0.0" name="back_leg_geom" size="0.08" type="capsule"/>
        <body pos="-0.2 -0.2 0" name="left_back_foot">
          <joint axis="-1 1 0" name="ankle_3" pos="0.0 0.0 0.0" range="-100 -30" type="hinge"/>
          <geom fromto="0.0 0.0 0.0 -0.4 -0.4 0.0" name="third_ankle_geom" size="0.08" type="capsule"/>
        </body>
      </body>
      <body name="right_back_leg" pos="0.2 -0.2 0">
        <joint axis="0 0 1" name="hip_4" pos="0.0 0.0 0.0" range="-40 40" type="hinge"/>
        <geom fromto="0.0 0.0 0.0 0.2 -0.2 0.0" name="rightback_leg_geom" size="0.08" type="capsule" rgba=".999 .2 .1 1"/>
        <body pos="0.2 -0.2 0" name="right_back_foot">
          <joint axis="1 1 0" name="ankle_4" pos="0.0 0.0 0.0" range="30 100" type="hinge"/>
          <geom fromto="0.0 0.0 0.0 0.4 -0.4 0.0" name="fourth_ankle_geom" size="0.08" type="capsule" rgba=".999 .2 .1 1"/>
        </body>
      </body>
    </body>
  </worldbody>
  <actuator>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="hip_4" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="ankle_4" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="hip_1" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="ankle_1" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="hip_2" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="ankle_2" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="hip_3" gear="15"/>
    <motor ctrllimited="true" ctrlrange="-1.0 1.0" joint="ankle_3" gear="15"/>
  </actuator>
</mujoco>
This modification should crash python train.py task=Ant. You can also see that it loads correctly if you comment L24-L27 and uncomment L29-L32.
Current quick fix
Right now, I just modify all my paths to point to the right directory by hand (see the example above). This is problematic as:
  • It makes modifications longer/more prone to errors.
  • If I use a file from a submodule that is being modified all the time for other projects, I have to update the paths for all new versions.
Thanks in advance!
Ben
Do you solve this problem?? i got same thing…
