We are developing a product based on Jetson Xavier AGX and have some specific questions on the codecs (not the API to access them). The questions apply for H264 and H265:
Does the H264/H265 codec perform tone mapping in the input frame before encoding?
In case of bitrate, does the codec support CRF and not just CBR and VBR?
qp-range : Qunatization range for P, I and B frame,
Use string with values of Qunatization Range
in MinQpP-MaxQpP:MinQpI-MaxQpI:MinQpB-MaxQpB order, to set the property.
flags: readable, writable
String. Default: null
Please set the property and see if it gives the same function as CRF.
The function is supported in CBR mode. Not supported in VBR mode.
Yes, CRF is pretty similar to Variable Bitrate when you set a target quality or the same level of control that you achieve using the qp-range. Let me chat with the customer to see if these two modes are enough. In any case I believe are the only modes supported by Jetson at this point.
