We are currently working on a project that will be based on the AGX Xavier. I have been reviewing the technical documentation available and checking for the supported H265 (HEVC) encoding / decoding profiles.
As per described in the latest revision of the datasheet for the Xavier, it seems that Main and Main10 are the platform’s supported profiles. However, I have found some early non-NVIDIA’s commercial use documentation with some references to the Xavier supporting 12-bit Main 12 profile.
Just wanted to have some confirmation of what it is described in the datasheet (page 13-14).
Regards
Diego Chaverri
Embedded Software Engineer
