I see that the Xavier supports the H.264 High 4:4:4 Predictive Profile for video encoding. That profile supports a bit depth of 8 to 14 bits per sample. Does the Xavier support encoding 14-bit imagery? I have not been able to find documentation that answers that question.
Thank you for your reply. I am not a video expert, so I have to assume that the “_10LE” part of the I420_10LE format means it is 10 bit. I suggest it would be nice if you could explicitly call out in your documentation which bit depths are supported for which codecs. Seeing only the profiles that are supported led me (and maybe others) to believe that it was possible you supported higher bit depths.
