Hardware accelerated gstreamer/nvvidconv convert from YUV* to RGB*?
I have a GMSL2 camera and it’s working as /dev/video0:
v4l2-ctl -d /dev/video0 -V
Format Video Capture:
	Width/Height      : 3840/2160
	Pixel Format      : 'YUYV'
	Field             : None
	Bytes per Line    : 7680
	Size Image        : 16588800
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Limited Range)
	Flags             :
Can I say its raw format is YUYV? (I’m not sure)
If I tested it with videoconvert like this, it works:
gst-launch-1.0 -v v4l2src device=/dev/video0 !
'video/x-raw, width=3840, height=2160, format=YUY2, framerate=30/1' !
videoconvert !
'video/x-raw, width=3840, height=2160, format=BGRx, framerate=30/1' !
appsink caps='video/x-raw,format=BGRx' max-buffers=1
Please note that the first cap filter format is YUY2 because the test result show that YUYV does not work, which seems to conflicts with v4l2-ctl -d /dev/video0 -V result.
from the -v log below, I can see it’s converted to BGRx.
/GstPipeline:pipeline0/GstAppSink:appsink0.GstPad:sink: caps = video/x-raw, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)BGRx
Now I want to use nvvidconv to do the format convert to RGB/BGR or similar format, to use the hardware acceleration.
I replaced videoconvert by nvvidconv, but it does not work
nvvidconv !
I have run gst-inspect-1.0 nvvidconv and verified that nvvidconv supports YUY2 as source format and BGRx as sink format.
I don’t know why nvvidconv can’t replace videoconvert.
Any mistake I have made?
Please try this sample and see if you can run it successfully:
V4l2src using OpenCV Gstreamer is not working in Jetson Xavier NX - #3 by DaneLLL
that example uses videoconvert, which is working fine here,
but I want to use nvvidconv.
You have to use software converter in this use-case. Hardware converter does not support BGR. Here’s a similar topic for reference:
[Gstreamer] nvvidconv, BGR as INPUT - #2 by DaneLLL
what if I convert to BGRx ? I see it’s supported, but I can’t make it work
How do I force the conversion from YUY2 to BGRx?
OpenCV doesn’t support BGRx, so we cannot send frame data in BGRx to appsink
I’m not useing full opencv’s gstreamer wrap, but GitHub - Myzhar/opencv_gstreamer_appsink: An useful class to acquire frame from a gstreamer pipeline and use them with OpenCV
the pipeline is open directly by gst_parse_launch( mPipelineStr.c_str(), &error );, and the appsink’s callback is handled by g_signal_connect( mSink, "new-sample", G_CALLBACK(on_new_sample_from_sink), this );, so OpenCV’s limitation doesnot apply in my case.
On the contrary, I have sucessfully got BGRx data from the callback (for videoconvert pipeline).
What I want now is to embed nvvidconv into my pipeline (to replace videoconvert)
Please try
nvvidconv ! 'video/x-raw(memory:NVMM),format=RGBx' ! nvvidconv !
The nvvidconv supports
video/x-raw ! nvvidconv ! video/x-raw(memory:NVMM)
video/x-raw(memory:NVMM) ! nvvidconv ! video/x-raw
Does not support
You may also try this patch:
Macrosilicon USB - #5 by DaneLLL
So that you can run like:
nvv4l2camerasrc ! 'video/x-raw(memory:NVMM),format=YUY2' ! nvvidconv ! video/x-raw,format=BGRx ! appsink
Never knew that! indeed, it’s my first time to hear about it!
