Having a problem installing my graphics card driver!
When the setup starts up, it stops at the first check point “System Check” it says: “Install cannot continue” → You must install Intel Driver first.
Anyone who got a solution? Because it seems to be impossible to find this “INTEL DRIVER” that I gotta install.
Cheers!
Found the Driver! :)
~ problem solved.
Could you please elaborate? I’ve got the same message and puzzled which driver meant?
Install cannot continue" → You must install Intel Driver first.
