Having an issue applying the nvidia rtx gi patch
https://answers.unrealengine.com/questions/1004508/having-an-issue-applying-the-nvidia-rtx-gi-patch.html
this are the errors when I check the patch in the windows prompt by the command: git apply --check RTXGI-NvRTX4.26.1.patch
error: patch failed: Engine/Source/Runtime/Renderer/Private/DeferredShadingRenderer.cpp:272
error: Engine/Source/Runtime/Renderer/Private/DeferredShadingRenderer.cpp: patch does not apply
error: patch failed: Engine/Source/Runtime/Renderer/Private/DeferredShadingRenderer.h:32
error: Engine/Source/Runtime/Renderer/Private/DeferredShadingRenderer.h: patch does not apply
error: patch failed: Engine/Source/Runtime/Renderer/Private/IndirectLightRendering.cpp:342
error: Engine/Source/Runtime/Renderer/Private/IndirectLightRendering.cpp: patch does not apply
error: patch failed: Engine/Source/Runtime/Renderer/Private/RayTracing/RayTracingLighting.h:14
error: Engine/Source/Runtime/Renderer/Private/RayTracing/RayTracingLighting.h: patch does not apply
error: patch failed: Engine/Source/Runtime/Renderer/Private/SystemTextures.h:11
error: Engine/Source/Runtime/Renderer/Private/SystemTextures.h: patch does not apply
facing the exact same problem. No solution found on the internet. Please help.
same here please help
This worked for me “open the patch file in Notepad++, go to Edit->EOL Conversions, select Unix (LF), save the file, and then try to apply the patch.”
https://github.com/NVIDIAGameWorks/RTXGI/issues/35
