Having problems running the xavier nx 16gb deepstream6.0.1 example on the nvidia xavier nx 8gb devkit carrier board?
Thank you.
Can you elaborate your question in details?
Hello, @yingliu
Platform:
  • Hardware : xavier nx 16gb emmc module + xavier nx 8gb devkit carrier board
  • jetpack 4.6.1
  • deepstream 6.0.1
Command
deepstream-app -c source1_csi_dec_infer_resnet_int8.txt
In the custom carrier board, an error stating unknown embedded device came up when running this example.
I wonder if it runs without problems on the devkit carrier board.
Could you test it?
Thank you.
Dear @forumuser,
The fix is in JetPack 5.0.1. Could you test with Jetpack 5.0.1 and confirm if it is working?
Please replace the prebuilt libs and try again:
Runtime error with Deepstream 6.0.1 while executing examples - #16 by Amycao
