I am using a carrier board designed for TX2. (no devkit EV board, board with DP port added)
The dts file I used was “tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dts” and enabled the DP port.
However, when using nvpmodel 0 (CPU 2GHz, GPU 1.3GHz with Cooler on) to use the full performance of the system, it sometimes happens that CPU gets locked or Ubuntu skin is broken.
It seems as if the memory arbitor is not scheduling properly due to a lack of bandwidth.
This phenomenon did not occur in Jetpack 3.2 (4.4.38 tegra kernel: same usage condition).
Have you made any special changes to Jetpack 4.2?
Symptom is reproducible when both HDMI and DP are connected.
Thanks for report.
Could you share a photo of such error?
Did you see any kernel error in dmesg?
Did you hit this error with any special application running?
The rate at which the issue is reproduced is much more that the CPU stops, and there is no dmesg in the kernel at that time.
When the problem is reproduced, the system is stopped and any input (mouse event or Keyboard etc …) is not available and the recovery to normal operation is not possible except HW reset or Power off and on method.
I will try to reproduce the phenomenon that the display screen is broken and try to catch the error message.
Thanks. Actually we didn’t meet such issue before. Even our partners with custom carrier board (2 display usecase) don’t report such issue before. Thus, we need your information to show us how to reproduce this issue.
Also, are both display in 4k mode? Could you check what is the criteria (besides nvpmodel mode 0) to reproduce issue?
Is it possible that the HW settings are not correct?
Could the schematic of our newly designed carrier board go wrong?
If you give us your opinion, we will discuss with the HW person in charge of our company.
Can you clarify what’s the issue now?
The original issue is “CPU gets locked or Ubuntu skin is broken”, is this issue still exist?
If you have extend or new issue, please file new topic.
