we had to switch to L4T 35.6.2 due to the tegrabc kernel panic bug.
We tested everything and noticed that one thing doesn’t work anymore. The second display port.
It always shows displays as disconnected, no matter what we plug in.
In the previous L4T 35.4.1 it still works. Do you remember a breaking change which requires us to make specific adjustments in the device tree?
The patch is already included in L4T 35.6.2 as the document states.
If we revert the patch to get the second display back, we will also get the kernel panics on boot back? We switched from 35.4.1 to 35.6.2 to fix the kernel panics upon boot initially…
The powergate-bpmp.c patch is already included in our code, probably from a previous conversation we had. Just with this addition around it: + if (tegra_get_chip_id() == TEGRA194) {
Doubt that changes anything.
So we got all the patches included.
Anything else changed, which could lead to the second display suddenly not working anymore?
Our image won’t run on the devkit, so trying it on the devkit would be the standard Ubuntu without our device tree changes. I am quite sure that it will work there? Otherwise someone would have reported that?
No, I don’t get any report here. That does not matte actually.
The standard steps here are you need to try to reproduce on NV devkit first.
Using same monitor on NV devkit to exclude whether this issue is related to specific monitors.
Well, the issue is on all our boards with all the monitors we have. The issue is gone when I flash the old version again. And it must be bootloader related. Only changing the image does not remove the issue. So our old userland with the new bootloader does not work, even tough our old device tree is loaded then. So it must be an issue somewhere earlier in the nvidia specific bootloader part.
When you ask about the devkit, maybe I forgot an important bit:
Devkit has 1 HDMI and 1 DP.
We have 2x DP, so one HDMI is configured to become a DP.
Does that ring a bell maybe?
I noticed in the new kernel logs, that something can’t be loaded:
[0003.892] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0003.900] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0003.901] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0003.901] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0003.903] E> no valid display unit config found in dtb
[0003.907] W> display init failed
The device trees are identical except of the disable-seamless = <0x01>; being added and the max-link-speed = <0x03>; being removed from pcie@14160000, spmic interrupts changed.
This is not kernel log. This is bootloader log. Not part of what we should focus for now.
Both xrandr and xorg give out disconnected. I guess your pinmux got changed. It is probably a GPIO now but for a DP, it has to be SFIO. Please go back and check your pinmux.
Part bootloader/part kernel, whatever, it is different after the update now.
We did not change the pinmux, it is untouched. Is there something in the L4T that makes a pinmux update required? Did the xlsx change, which we generate the pinmux from?
