I am having trouble configuring my Ubuntu 16.04 machine with a NVIDIA NVS 450 graphics card.
As soon as I enable BaseMosaic mode in my xorg.conf file the system starts freezing upon reboot and is extremely unresponsive.
The only way to resolve this is to drop to the terminal (CTRL+ALT+F1) and either edit or remove the conf file and reboot.
Everything works fine for two displays, its only when I try to get all three going the problems start.
All is fine in Windows 10 - except that its windows.
I am using the NVIDIA binary driver version 340.102.
Any help/advice greatly received or am I flogging a dead horse. I know the card is old but I’m not looking to play games and I’m hesitant to purchase say an NVS 510 in case of similar issues.
Many thanks, Lee
Please run nvidia-bug-report.sh and attach output to your post.
Did you follow the guide at:
[url]How to configure MOSAIC on Linux | NVIDIA
Thanks for your reply.
I did follow the guide that you mentioned.
I have attached the bug report and a copy of my xorg.conf.
http://www.loonatic.com/nvidia-bug-report.log.gz
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 381.22 (buildd@lgw01-19) Tue May 9 21:38:53 UTC 2017
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL 2407WFP"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro NVS 450"
BusID "PCI:4:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "GPU-9c009c35-ce20-7c17-f85d-a92780a70cfd.GPU-0.DP-0: nvidia-auto-select +1280+0, GPU-9c009c35-ce20-7c17-f85d-a92780a70cfd.GPU-0.DP-1: nvidia-auto-select +3200+0, GPU-ca4cc24a-ea51-7930-03ee-da6f5a8fdcfd.GPU-1.DP-0: nvidia-auto-select +0+0"
Option "MultiGPU" "Off"
Option "SLI" "off"
Option "BaseMosaic" "on"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Many thanks, Lee
All logs are looking good, the xserver is set up right using all 3 monitors, no driver woes in dmesg. So it’s more likely that the wm i.e. unity is not getting it right.
Better replace
with
Option "nvidiaXineramaInfo" "FALSE"
Seeing anything specific in journal (journalctl -e)?
