I was setting up my Nsight IDE when I came up against this problem:
[b]“Now let’s work through the steps for setting up the host environment configuration by creating a build configuration and selecting the proper toolchain, so that the cmake4eclipse plugin will be used whenever you build the project within Nsight.
- Right click on “LaneNet” and select “Properties” from the Project Explorer window.”[/b]
I don’t have a “LaneNet” in my Project? I tried setting those properties for my Project, but I get a build failure:
cmake -DCMAKE_BUILD_TYPE:STRING=Debug -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=ON -G “Unix Makefiles” /home/patrick/samples-nsight
Cannot run program “cmake”: Unknown reason
Error: Program “cmake” not found in PATH
PATH=[/home/patrick/bin:/home/patrick/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda-10.0/bin:/usr/local/cuda-10.0/bin:/usr/local/cuda-10.0/bin]
Test_project de.marw.cdt.cmake.core.internal.BuildscriptGenerator Buildscript Generation Problem
Any help would be most appreciated.
