I’m considering using NFS over InfiniBand (and IPoIB). Since prices are more-less similar I wandering which of the two should I buy?
Hello Zbuntowany,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Below links will provide you the product capabilities for both adapters:
- https://www.mellanox.com/related-docs/prod_adapter_cards/PB_Connect-IB.pdf
- https://www.mellanox.com/related-docs/prod_adapter_cards/ConnectX3_VPI_Card.pdf
The Connect-IB is IB only. The ConnectX-3 VPI has the option to change the port type to IB or Ethernet.
Both adapters in general are EOL and majority of the ConnectX-3 models are EOS.
Our latest GA drivers, will not support Connect-IB anymore.
Recommendation would be to try to purchase a more recent adapter like the ConnectX-4 or 5 VPI, or even the ConnectX-6 VPI. All these VPI adapters will give you the opportunity to change the port type to IB or Ethernet so they will be more versatile to use.
Thank you and regards,
~NVIDIA Networking Technical Support
Thanks for a quick answer,
As I understand both are enough to run NFS over RDMA. So I don’t think I’ll spend money on anything better than Connect-IB. This is not for production but a kind of academic purpose.
Well, if you would like to donate some for our university…
