Holoscan Sensor Bridge
How can I get description of how the sensor data is passing on the AXI bus between the sensor I/F to the HOLOLINK IP and how the sensor data is organized at the UDP packets at the AXI bus between the HOLOLINK IP and the HOST I/F?
Aharon
Hi the Holoscan Sensor Bridge userguide specifies the Dataplane, and UDP packets layout.
For details on the AXI4-stream protocol you may find more details here.
