how can i compile Tegra_multimedia_api smples and run on Tx2 developing board? still use Nsight? i try to build new project and import those Tegra_multimedia_api smples code ,then compile…but fails… what is right way to compile Tegra_multimedia_api smples?
You can install the samples via Jetpack and they will be compiled on TX2.
i have install these samples in Tx2 board. can you give details command for compile …or details description how to run
Tegra_multimedia_api samples…let’s says samples 10.camera_recording…
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-1
[L4T Multimedia API Reference Documentation] -> [Sample Applications] -> [Building and Running]
thanks…really helpful…
