I followed the document
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/SD/Security/SecureBoot.html
to burn the fuses.
My fuse-configuration XML is
<genericfuse MagicId="0x45535546" version="2.0.0">
<fuse name="PublicKeyHash" size="64" value="0xa9xxxxxxxxxxx"/>
<fuse name="SecurityMode" size="4" value="0x0"/>
<fuse name="SecureBootKey" size="32" value="0xb0aexxxxxxxx"/>
<fuse name="OemK1" size="32" value="0xdxxxxxx"/>
</genericfuse>
After burning succeeded I read the fuses with
sudo Linux_for_Tegra/bootloader/tegrarcm_v2 --chip 0x23 --fuseinfo
The utility says
“Fuse reading is done. The fuse values have been saved in …/fuse_info.txt”
and the file only contains
PublicKeyHash: a96xxxxxxxx
BootSecurityInfo: 000001e0
ArmJtagDisable: 00000000
SecurityMode: 00000000
There is no OemK1 field.
How can I confirm whether OemK1 was really burned?
