Hi, I tried to delete my Issacsim to make it as default settings/extensions.
But after delete and install isaacsim on the Omniverse launcher, There’re still my old settings.
How can I re-install with the fresh settings?
Hi. Un-installing Isaac Sim from the Launcher does not remove the config files. You can reset it by running with the --reset-user flag. You can use this via command line or in the Isaac Sim App Selector.
--reset-data will clear the shader cache.
