I’m new to Isaac Sim and I’ve noticed that as I run and interact with my stage, the memory reported in the Process Memory view keeps climbing.
What I’ve observed: – Process Memory steadily increases over time as I work in my stage.– I currently free memory only by closing and re-opening the stage.
What I’d like to know: – Where is the Process Memory panel (or its replacement) in Isaac?– Is there a built‑in menu command or extension I need to enable?
Any guidance on how to manage or reset memory usage without restarting the entire application would be greatly appreciated.
Thank you for your reply! In the screenshot I uploaded, there are three lines of values in the top-right corner of the stage viewport, including the FPS. The third line—“Process Memory”—is what I’m referring to, and I believe it represents CPU memory.
Yes correct. Process memory is the same as cpu / system memory. And you are finding that this number is just increasing over time with the same scene open? If so, we call that a “memory leak” and we take it pretty seriously.
Hi, I face the same problems as mentioned above. It is definitely a memory leak as the number of process memory (which i believe is RAM) is just increasing over time with the same scene open and nothing else done. Can I ask when will there be a solution to this?
We will report this to the engineers and get back to you. In the meantime, unfortunately, the only way we know how to reset a memory leak is to restart the application.
In the meantime, would you mind evaluating the same memory leak in the older Isaac Sim 4.2? It would help us track the change. Are you using Replicator at the same time, or any specific extensions that are not loaded standard?
