When I press Z on the keyboard, I want the specified object to move by the value specified on the Z axis.
I am currently learning Omnigraph. I made Node as I thought, but there is no response even if I press Z.
What’s wrong with this?
Could you show me what I want to implement in Omnigraph?
Then I think it will be a good example and learning for others as well as me
The graph looks mostly right to me. I think you want to connect X and Y from the Break 3-Vector into the Make 3-Vector. The translation will be overwritten as a vector.
Also, keep in mind that this will only execute during simulation playback by default. Have you checked that? You need to press play first.
If that doesn’t help, please send the USD file with the graph and I can take a closer look.
